Replacing brake pads myself. Got rear done, front is impossible
Discussion in '2.5 Gen Tundras (2014-2021)' started by Maddog94, Apr 20, 2024.
  1. Apr 20, 2024 at 6:44 PM
    Maddog94
    Maddog94 [OP] New Member
    Help, if you can.
    I've done brakes on other vehicles many times before. The fronts should be really easy on these trucks (mine is a 2016) since you just pop 2 pins out and slide the pads in and out.
    So I am able to squeeze the pistons on the inside enough to shoe-horn the inner pad in, but the outside pistons are impossible. I can get them about halfway pushed in but no more.
    And wow, it's also a struggle to keep them even (as you push one in the other pushes out) but using the old pad to exert force on both evenly, I'm able to do that.
    It almost seems like the pads are too thick but I know that's not really the case here. What's the trick / what am I missing here?
  2. Apr 20, 2024 at 6:54 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Try inserting the old pads back in, then use a large pry bar between them to force the pistons back in place, that's how I usually do it. Good luck.
    equin, 1lowlife and FrenchToasty like this.
  3. Apr 20, 2024 at 6:55 PM
    Maddog94
    That's exactly what I did.
  4. Apr 20, 2024 at 6:59 PM
    TILLY
    Massachusetts
    So you have the pistons all the way in and the pads are still not fitting?, or am I still not understanding.
  5. Apr 20, 2024 at 7:11 PM
    40man
    40man New Member
    AZBoatHauler, 1lowlife and chugs like this.
  6. Apr 20, 2024 at 7:17 PM
    Maddog94
    The pistons won't go all the way in. I get 2 of 4 all the way in. In my case, I forced the inside pair all the way in but the outside ones would only go halfway.
  7. Apr 20, 2024 at 7:34 PM
    TILLY
    Massachusetts
    OK, try this. Remove the cap on the brake fluid reservoir and slowly try to push the outers in while keeping the inside secure somehow, go slow or the fluid may squirt out and make a mess.
    equin and 1lowlife like this.
  8. Apr 20, 2024 at 7:50 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    This is a bad idea, but I’ve done it a couple times successfully. If the caliper is seized, disconnect the brake line so you can put it in a vise. Put some pressure on the seized side, then heat the outside of the caliper evenly as you can. Then apply more pressure with the vise. If it doesn’t move, let it sit and cool, repeat.
    This can break things…so understand you may end up replacing your caliper.
  9. Apr 21, 2024 at 6:09 AM
    Maddog94
    The caliper is not seized. It's simply a matter of the pistons not all going in at one time.
  10. Apr 21, 2024 at 6:18 AM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    Interesting, so they travel fully in and out, but when you push one in the other moves out?
  11. Apr 21, 2024 at 6:30 AM
    Maddog94
    Correct
  12. Apr 21, 2024 at 6:33 AM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    Is this with the brake line disconnected? It sounds like the outflow of fluid is plugged.
  13. Apr 21, 2024 at 6:35 AM
    Maddog94
    No I didn't disconnect anything. You are probably right it does feel (seem) like the fluid has nowhere to go to. I did pop the cap off the reservoir but that made no difference.
  14. Apr 21, 2024 at 6:45 AM
    coTony
    Tony
    Montrose, CO
    Anytime I do brakes for the past 40+ years I always remove the master cylinder cover, replace it back but on top but to not lock it. The excess air will work it’s way out. Go slow so you do not make a mess at the master cylinder
    equin likes this.
  15. Apr 21, 2024 at 6:55 AM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    disconnect the line and see if they go back correctly. Probably a good idea to flush the line before reconnecting it, there’s probably something in the line or caliper. You can do this with a bleeding tool, or start the truck with the line disconnected and pump the brakes (two ppl required). Make sure you keep the brake fluid topped up as you do this and bleed all the lines under pressure when done with the job.
    coTony and Maddog94[QUOTED][OP] like this.
  16. Apr 21, 2024 at 7:08 AM
    Squeezing the caliper sends the old, moisture contaminated fluid back into the lines. It also can mess with the ABS module. Crack the bleeder screw when compressing the pistons. It relieves the pressure and also pushes the old contaminated brake fluid out. Replace the old pads with the new, then top off the reservoir with fresh fluid and do a quick bleed on the calipers to clear all of the old, green, moisture contaminated fluid out. The piston seals unfortunately cannot keep all of the moisture out and it will contaminate the fluid in the caliper over time. I bleed the calipers every time I do brakes. Brake fluid is really, really, really cheap. ABS modules are not.
  17. Apr 21, 2024 at 7:14 AM
    Maddog94
    I've reached the limit of my ability. Don't know anything about the bleeder or messing with fluid. Thanks anyway though.
    Leo's first likes this.
  18. Apr 21, 2024 at 7:46 AM
    not that hard. Jump on YouTube university and educate yourself. Need at least 2-3 trusted sources to move forward with anything new to me.
  19. Apr 21, 2024 at 8:00 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    I understand but don't get overwhelmed so quickly You've just been bombarded with a lot of info
    At least try the simple thing first
    Open the bleeder screw and see if that does it for you not to be an ahole but if you don't know anything about bleeding brakes you probably shouldn't be working on them
    Good luck you can do this
  20. Apr 21, 2024 at 9:24 AM
    Maddog94
    You're probably right I shouldn't be doing this. Not that it's right but I've replaced brake pads on many vehicles in the past and never had to do anything more than squeeze the piston. I've never messed with any bleeders. That won't work in this case evidently.
    Leo's first[QUOTED] likes this.
  21. Apr 21, 2024 at 9:47 AM
    centex
    centex New Member
    Is there something special about these brakes than others? I’ve done plenty of 4 piston setups and never have had to open bleeder screws or undo brake lines to compress the pistons. I just stick a small pry bar against the old pad and just push both sides back a little at a time until they are compressed. You could try putting the old pads back in, starting the truck and press the brakes to try and reset the pistons and then try compressing them again. They aren’t complicated.
  22. Apr 21, 2024 at 9:50 AM
    Maddog94
    I don't know but I can't get them in far enough to fit the pads.
  23. Apr 21, 2024 at 10:09 AM
    40man
    40man New Member
    Having a caliper push out when compressing the other is not unheard of. Loosen the master cyl cap under the hood and do one of the following:
    Get 2 cheap C Clamps (any hardware store has them and two will be under $10) and compress both at the same time, get a tool as I linked above, or compress with the old pad still in, pushing on the middle so they both go in using a c clamp (preferred) or pry bar.
    Opening the bleeders will make it easier, but not required.
    TWJLee and coTony like this.
  24. Apr 21, 2024 at 1:28 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    . If pushing in without loosening the bleeder then remove master cylinder cap and watch for overflow..If you do try to loosen the bleeder be gentle so as not to snap it off.. Unusual that both outer pistons won't go all the way in.
  25. Apr 22, 2024 at 6:39 AM
    idAg9010
    idAg9010 New Member
    David
    2018 black cm TSS SR5 5.7
    Center console storage
    Yes, use two C-clamps. I just changed all four on my 2018 yesterday. I put the caliper on a 5-gallon bucket and used two small c-clamps with the old brake pads to push both sides in at the same time. Once you release the C-clamps the pistons should stay flush. You'll need to wiggle the pads a little but there's room (if you have the correct pads). Good luck!
    Maddog94[OP] likes this.
  26. Apr 22, 2024 at 7:45 AM
  27. Apr 22, 2024 at 7:46 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've gotta 6" C clamp and use an old pad to push the pistons back in evenly. Has never let me down.
    Terndrerrr likes this.
  28. Apr 23, 2024 at 9:28 AM
    40man
    40man New Member
    Were you able to get it squared away?
  29. Apr 23, 2024 at 9:56 AM
    Maddog94
    My next opportunity to work on it is Friday.
    40man[QUOTED] likes this.
  30. Apr 23, 2024 at 10:12 AM
    vlddo
    vlddo New Member
    Tundra 2020 SR5 4x4
    ooops - i just pushed the pistons in with C-clamps without bleeding/opening the screw. Worked well but hopefully i didnt mess anything up , guess we'll see:fingerscrossed:
