Replacing coolant and heater hoses
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1st Tun, Dec 11, 2023.
  1. Dec 11, 2023 at 6:45 PM
    1st Tun
    1st Tun [OP] New Member
    2019 Gray Tundra
    Hello to all, looking to change out coolant in my 2019 and wanting to changeout all hoses associated with heater, radiator and any others associated with system. Appreciate any schematic drawings on hose locations.
  2. Dec 11, 2023 at 7:01 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Go to https://www.sparksparts.com/ and enter your VIN# in the search than you can pull up all the schematics with part#s down to every nut, bolt and fastner. Click on "Cooling System". That should be what your looking for
  3. Dec 11, 2023 at 7:04 PM
    TacomaTRD4x402
    Southern California
  4. Dec 11, 2023 at 7:07 PM
    1st Tun
    2019 Gray Tundra
    Will check the sites out. Thanks Tacoma TRD
    TacomaTRD4x402 likes this.
  5. Dec 11, 2023 at 7:08 PM
    TacomaTRD4x402
    Southern California
    :thumbsup:
  6. Dec 11, 2023 at 7:24 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I would not change hoses unless they are stiff, cracked or leaking. OEM hoses are good quality and can last 20 yrs or more
  7. Dec 11, 2023 at 8:07 PM
    Retired...finally
    I agree. You might do more harm than good because of so much plastic parts used in modern cars.
    WILLINH and AZBoatHauler like this.
  8. Dec 12, 2023 at 5:50 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Why are you changing all your hoses on a 2019? My 2014's hoses are still very pliable with no signs of excess wear after 170k miles. They are not really a routine maintenance part on these trucks.
    WILLINH likes this.
  9. Mar 5, 2024 at 12:48 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    I would swap the hoses out especially if you’re installing a brand new radiator. Better to replace everything once, than having to go back because you waited 10 years to replace them. HPS hoses are good quality made of silicon 3-ply and withstand heat up to 300 degrees. I doubt those rubber hoses OEM do.
    juanpsi likes this.
