Replacing hard to reach plugs
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, Aug 9, 2023.
  1. Aug 9, 2023 at 11:30 AM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    I've done plugs on other trucks, including my 2000 LC. I've watched some videos and as usual, those two against the fire wall look like a PITA, especially passenger side.
    Wondering if anyone has any tips or tricks to get those two replaced. Long 1/4" socket extension? links to jointed socket extension? etc.
    Thank you.
  2. Aug 9, 2023 at 12:26 PM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    Did mine a few months ago and it was non-eventful. For the back cylinders, I just drop in the socket + extension first then attach the ratchet.
    It was more of a pain in the ass to get the connectors off the coils then anything else with the change.
    HulkSmurf14 and kevine0001[OP] like this.
  3. Aug 9, 2023 at 1:20 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Not too bad of a job. But Watch out for counterfeit plugs. Don’t buy from Amazon or eBay
  4. Aug 9, 2023 at 1:26 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    100% CORRECT!!
  5. Aug 9, 2023 at 1:28 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    5.7 I use the spark plug socket to remove the plug and i use a piece of rubber tube to Install the plug then take the rubber plug out and tighten them up. I also use a little anti seize on plug and dielectric grease on rubber boots and electrical connections
    TXBrit, 2mchfun and kevine0001[OP] like this.
  6. Aug 9, 2023 at 1:39 PM
    kevine0001
    Kevin
    Yeah i have anti-seize and grease. rubber tube is smart. so i thought removing the connectors from the coils, just a plastic tab, pull off and then a 10 mm screw to remove coil from the motor?? that plastic tab?? I'll have to watch the videos again. I recall him using something, but I recall doing it on my Land Cruiser and other toyotas, and not being too bad.
  7. Aug 9, 2023 at 1:42 PM
    Vince
    Vince New Member
    Vincent
    It is just a push plug to remove unplug then take the 10mm off it is easier
  8. Aug 9, 2023 at 2:57 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    New spark plugs don’t need anti seize anymore they use special materials so it don’t rust or get seize.
    Joe333x and Jeffro22 like this.
  9. Aug 9, 2023 at 3:31 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    For the passenger side firewall plug(s) I think I (sorry, not looking inside the hood) unbolted a part and got better access.
    Be very careful of where you buy the plugs. Denso has a network of authorized resellers that their website will identify for you. Here's what the proper Denso box looks like (bought through bricks & mortar Advance Auto):
    kevine0001[OP] and ZappBrannigan like this.
  10. Aug 9, 2023 at 4:46 PM
    centex
    centex New Member
    Don’t trust it. Been bitten. I’ll stick to anti seize.
  11. Aug 9, 2023 at 4:58 PM
    blenton
    blenton New Member
    This.
    I feel this truck is one of the easiest vehicles to change spark plugs. I think it took me all of a leisurely 45 minutes to do all 8 plugs. One of the main wiring harness mounts slightly interferes with the back plug on the passengers side but you can easily bend it a 1/4” or so to make it easier to access the back plug.
    A combination of 3” and 6” extensions make life easy. Also, a magnetic pickup tool helps retrieve old plugs and and drop in new plugs without much fuss.
    kevine0001[OP] likes this.
  12. Aug 9, 2023 at 5:00 PM
    blenton
    blenton New Member
    +100000000000
    I ended up with counterfeit plugs last go round and one of the electrodes flat melted off the plug.
  13. Aug 9, 2023 at 5:25 PM
    Vince
    Vince New Member
    Vincent
    Rockauto Denson plugs cheapest place I found plugs at
  14. Aug 10, 2023 at 6:09 AM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    How is rockauto? The prices seem too good to be true.
  15. Aug 10, 2023 at 6:27 AM
    fallen0
    fallen0 New Member
    Minnesota
    They are great! Only downside is shipping cost, which negates the part cost savings. Especially from different distribution locations. Try to match locations to make shipping cheaper.
  16. Aug 10, 2023 at 7:15 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    That's exactly what I did as well. It helps a ton to remove the airbox. My daughter was handing me tools while I was hanging over the fender working the plugs out, and all in all it took an hour or so of my time to swap out the 8 buggers.
    Leo's first likes this.
  17. Aug 10, 2023 at 7:20 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    But, you cant...
  18. Aug 10, 2023 at 7:26 AM
    drpheta
    drpheta New Member
    On the anti-seize aspect, the reason you shouldn't use anti-seize is because it affects the torque needed/applied to the spark plug. Do not use anti-seize. Direct from NGK (and I'm sure Denso is the same).
    5 Things You Should Know About Spark Plugs - NGK Spark Plugs
  19. Aug 10, 2023 at 7:31 AM
    fallen0
    fallen0 New Member
    Minnesota
    All in all, it was more of a pain to change plugs on my old 2.7 EcoBoost than the 5.7. Back cylinders are actually pretty open on our trucks.
  20. Aug 10, 2023 at 3:51 PM
    kevine0001
    Kevin
    Thank you for all the info. I got Denso plugs from a local family owned auto shop that's very reputable. Just about ever hot rod owner uses this shop and the are very knowledgeable. Now just debating on the anti-seize...crap
  21. Aug 10, 2023 at 3:53 PM
    blenton
    blenton New Member
    I didn’t use anti seize the firs go around. I used a tiny dab this go round but didn’t torque to spec, knowing it wouldn’t be accurate. So….
  22. Aug 10, 2023 at 3:56 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    It's not a Ford don't do it
  23. Aug 10, 2023 at 3:58 PM
    Jeffro22
    Jeffro22 New Member
    You don’t need the anti- seize if the plugs are genuine.
    good call on getting plugs from a local auto parts store. Sounds like your good to go
  24. Aug 11, 2023 at 2:29 PM
    kevine0001
    Kevin
    just need to find the time to do it. i'm slammed this entire month and archery deer season starts labor day weekend.
