Replacing one tire or all four?
Discussion in 'Wheels & Tires' started by Kenisaw, Feb 1, 2020.
  1. Feb 1, 2020 at 1:54 PM
    Kenisaw
    Kenisaw [OP] New Member
    2015 Tundra 5.7L
    Had a tire blow on my 2015 5.7L Tundra the other day. Some folks (including one that used to own and run a tire shop) are telling me that I need to replace all 4 tires on my truck, because the new tire will have a different tread depth which will cause that wheel to roll at a different RPM than the other three. What is everyone's opinion on this? I'm not sure if the differential on the rear axle is open, limited slip, or locked, and I assume that would make a difference as to the answer to the question.
  2. Feb 1, 2020 at 1:59 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Depends on mileage on the tires.
  3. Feb 1, 2020 at 2:08 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    If tires are low mileage, just get the one. If the tire is high mileage and tire is on the rear, get 2, unless it is 4wd then I would probably get 4.
    RitcheyRch, Toyotoholic and 1lowlife like this.
  4. Feb 1, 2020 at 2:10 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    I think you wanted to buy 4 new tires anyway and just wanted us to talk you into it...
    I would agree with the posts above.
  5. Feb 1, 2020 at 2:20 PM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Replace with 4
  6. Feb 1, 2020 at 2:24 PM
    Kenisaw
    2015 Tundra 5.7L
    LOL just the opposite actually. The tires aren't very old, and the difference in tread depth wouldn't be very much. The issue for me is that I don't know how to validate the claim that two tires with different tread thickness can beat up a differential. The more I think about it, it doesn't make sense that a differential couldn't handle the difference in RPMs between the two tires. Roads aren't always level, tires often have different pressures in them, and every time you turn a corner one tire is going to rotate way more than the other....so if those things aren't blowing differentials up, would the tread depth thing really be that big a deal?
    1lowlife[QUOTED] likes this.
  7. Feb 1, 2020 at 2:44 PM
    Jota21
    Jota21 New Member
    never done it, but i've heard that tire shops can actually shave down the tread depth on the one new tire to match the others to eliminate this problem
  8. Feb 1, 2020 at 2:54 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    How many miles and what tires are they?
  9. Feb 1, 2020 at 3:31 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    I have one tire with 17000 miles on it and the other three are close to the wear bars (mileage unk) and due to be replaced. I have had no issues or drivability problems. All four are Michelin LTX M/S2
  10. Feb 1, 2020 at 3:53 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    We need more info to be objective. Including age, brand, mileage and tread depth of current tires to make a reasonable recommendation.
    I changed all my wife’s awd pilot’s tires after a “blow out” with 13k miles on them. I also did not like the original tires, and it was an awd. Either 4wd or 2wd will be more compliant with differences in diameter.
  11. Feb 1, 2020 at 6:46 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    The difference is all those things you mentioned are variable. Replacing one tire with different diameter is constant.
    That said, if the tires only have a few thousand miles just replace the one. If they have 10K+ on them replace all four if 4WD.
    There are more systems at play than just the mechanicals. Your VSC, Speed Sensor and others depend on all tires being close to the same diameter.
    Your call though. What do I know...
  12. Feb 1, 2020 at 8:53 PM
    Sunnier
    Sunny
    San Diego, CA
    Maybe I missed how many miles on the good three?
    What I’d probably do (again, what’s the mileage?), is buy a new tire and put it on the front with your new, never used, full-size spare. Rotate the other (good, nearly new-?) out to use as a spare.
  13. Feb 1, 2020 at 8:59 PM
    Buy one tire and find new friends.
    JohnLakeman, Sunnier, 15whtrd and 3 others like this.
  14. Feb 1, 2020 at 9:03 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    1 tire. Tundras ride like shit anyway I doubt if you'll notice.
  15. Feb 2, 2020 at 7:47 AM
    Can’t it cause strain on the drive shaft with diff tread depths?
  16. Feb 2, 2020 at 8:41 AM
    15whtrd
    15whtrd Mr. Blonde
    The OP could put the new on the right rear, and shave it down himself with a few smoky tire fires.
  17. Feb 3, 2020 at 5:03 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    If it did it would only be when running in 4wd right? And if you're in 4wd it should be in conditions where it's slippery and a little slip is already expected so it wouldn't matter.
    The rear differential already lets the left and right side tires turn at different speeds so it wouldn't matter if one is slightly larger than the other.
    I say just buy one tire and be done with it unless the other 3 are almost at end of service life.
    sourdough44 and Skey44 like this.
  18. Feb 3, 2020 at 5:10 AM
    ddact
    ddact New Member
    Almost all 4wd trucks have a limited slip differential. It's definitely not a locked. If you try to go around a turn on pavement in a truck with a locked differential, you'll know (It won't want to turn...at all).
  19. Feb 3, 2020 at 6:17 AM
    On an AWD this is actually pretty critical.
    With an open differential like on our trucks, this really isn't going to be a factor.
    T-Rex266 likes this.
  20. Feb 3, 2020 at 12:21 PM
    JDHolliday27
    JDHolliday27 New Member
    2018 CM
    I did exactly this. Had a similar scenario a while back and ended up only replacing the one tire that had a blowout. Swapped the full size unused spare tire onto one of the other wheels and put the used tire on the spare wheel. BTW - some tire shops will not shave a tire over a certain size, so this was the easiest and cheapest vs. replacing all 4 tires.
    Sunnier[QUOTED] likes this.
  21. May 25, 2021 at 7:00 PM
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    Do you mean it depends on the wear or diameter? Mileage alone shouldn’t be a factor, but a tire with more mileage is likely to be smaller in diameter. Is that wha you meant?
  22. May 26, 2021 at 9:24 AM
    Keithbickford
    Keith
    Seattle
    I did some math. It looks like at 4/32” wear on one 33” tire, the rotational speed would be 0.04 revolutions per second more on the worn tire. 02D7524A-AD7F-4985-9D64-B9472BBD760A.jpg
  23. May 26, 2021 at 9:30 AM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    replace all 4, use the best one of the old set as your spare.
