Reset ECM and TCM
Discussion in '3rd Gen Tundras (2022+)' started by pyoung62, Jan 24, 2024.
  1. Jan 24, 2024 at 9:00 AM
    pyoung62
    pyoung62 [OP] Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    Has anyone found a way to reset the ECM and TCM? I tried a search and only found disconnecting the battery. But I don’t want to have to reset everything.
    I wish we had the Ford equivalent of Forscan. In addition to hundreds of customizations, even tire diameter for the odometer and speedometer, you can reset each of the control modules individually. I found this very helpful with my F150 after towing a very heavy trailer through the mountains for about 1000 miles to “unlearn” the transmission adjustments.
  2. Feb 5, 2024 at 4:37 AM
    Handyman MD
    Handyman MD New Member
    2022 Tundra SR5 4X4 double cab
    K&N air filters, side grill DRL (3 vertices LEDs), in bumper off road LED light bar, BFG all terrain tires, blow off valves for the turbos.
    I have a 2022 Tundra Sr5. I have made several modifications and I would like to reset my the truck so it can relearn with all the mods I have done. I don't think it is recognizing things correctly and fully adjusting to fully use all the mods capabilities.
    I have heard that on Toyotas it's not good to disconnect the battery and let all power drain. It's bad for all systems to loose total power like that.
    Anyone know about this stuff. We would like to know.
  3. Feb 5, 2024 at 4:52 PM
    Handyman MD
    Thanks for the confirmation.
    So, do I have to just disconnect the negative? Or positive too and then connect the battery lead together to loop the system and drain it all?
    How long should I disconnect whatever/whichever for how long... Wow I think I just confused myself... Lol
  4. Feb 5, 2024 at 4:55 PM
    Handyman MD
    Oh... And is this resetting the ECU not the ECM OR TCM.... Whatever those are... Lol
  5. Feb 5, 2024 at 6:18 PM
    xc_tc
    xc_tc New Member
    ECU = electronic control unit or engine control unit
    ECM = electronic control module or engine control module
    TCM = engine control module
    basically all the same, any ECU with a powered RAM memory function will be cleared.
    https://en.m.wikipedia.org/wiki/Electronic_control_unit
    Take off the negative terminal and wait 30-60 sec.
  6. Feb 6, 2024 at 2:00 PM
    Handyman MD
    Couple questions to follow up.
    1. How long does it take for the ecu, or anything that has had the memory cleared, to relearn?
    2. Assume use normal driving habits... No hot rod runs?
    3. I have a JB4 in it and I run premium gas. What is the procedure with the JB4? Should I disconnect it and let the ecu learn without it so the JB4 is maximized when plugged in? Should I stop the premium gas and fill up with regular? How many tanks?
    4. I also have a peddle tuner, should I set it to stock?
    5. Additional mods are Burger Motor Sports blow off valves, S&D CIAs, AFE charge pipes and Flow Master FK exhaust.
    So, now those are the mods. Hope you can speak in to what the process should be to maximize the mods and the ECU learning with the JB4 tuner.
    Thanks
