Retrax Pro XR Bed Cover
Discussion in '3rd Gen Tundras (2022+)' started by 3Gen4x4, May 31, 2022.
  1. May 31, 2022 at 8:37 PM
    3Gen4x4
    3Gen4x4 [OP] New Member
    22 Tundra SR5 TRD OR
    Just have a quick question. Anybody install a retrax system on their new tundra yet? I’m curious where the drain plugs go? Is it something I would have to drill holes into my bed to install?
  2. May 31, 2022 at 8:57 PM
    BayRunner
    2017 Tundra Platinum
    I don’t have a gen 3 but are there little plastic plugs on the forward cabin facing bed wall? If so you drill through those plastic plugs.
  3. May 31, 2022 at 9:00 PM
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    please read this thread, plenty of people have installed
    https://www.tundras.com/threads/2022-tonneau-covers.101527/unread
    22PlatWCP likes this.
  4. May 31, 2022 at 9:06 PM
    3Gen4x4
    I don’t see any
  5. May 31, 2022 at 9:09 PM
    Brums
    Brums New Member
    Bethel, OH
  6. Jun 1, 2022 at 1:56 PM
    AustinTexas
    AustinTexas New Member
    I had an off road shop install mine.
    They just dropped them straight down using two of the four existing drain holes in the bed floor.
    When you write plugs, I'm assuming you are referring to the drain tubes.
  7. Jun 1, 2022 at 2:54 PM
    3Gen4x4
    Yeah I just noticed today there are four drain holes. They were so small I almost didn’t notice them. Do you know if they had to still use a drill to make those holes in the bed bigger? Or were there attachments to fit those small holes?
  8. Jun 1, 2022 at 3:56 PM
    AustinTexas
    yes they definitely used a drill to make the holes a little bigger and the drain tube then goes into the hole
  9. Jun 4, 2022 at 5:06 AM
    AustinTexas
    I also got a Tundra OEM bed mat. Got it the dealership for $162
    I made two little notches in it so it would fit around the drain tubes.
    The OEM bed mat works great.
    I highly recommend.
    Jojoma2016 likes this.
