Reverse Signal Wire - 2015 Sequoia Limited
Discussion in 'Audio & Video' started by sequoiadad08, Jul 21, 2022.
  1. Jul 21, 2022 at 1:50 PM
    sequoiadad08
    sequoiadad08 [OP] New Member
    2015 Sequoia Limited 4x4
    Hello! I am trying to connect the reverse signal wire on an aftermarket Pioneer head unit so my rear camera will automatically display in reverse. Can someone please confirm the EXACT location of the reverse signal wire on my 2015 Sequoia Limited (non-JBL) 4x4? I have been following Tundra instructions from the forum, but I recently read something which mentioned looking in the the driver side kick panel for the Sequoia.
    Thanks in advance for your help!
    (If convenient, a pic of the wiring harness would be amazing!)
  2. Jul 21, 2022 at 2:24 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
  3. Jul 21, 2022 at 3:24 PM
    sequoiadad08
    Thanks for the info and the quick reply! Is the 28 pin harness behind the radio or in a kick panel? If kick panel, which side?
  4. Jul 21, 2022 at 3:25 PM
    BrandonL812
    Brandon
    Behind radio. should look like this. It is the one on the right with the purple and white stripe wire coming out if it. The purple and white stripe is the reverse wire on the Meastro TO2 harness.
    NewImprovedRon likes this.
