Ripped leather; what are my options?
Discussion in '2nd Gen Tundras (2007-2013)' started by Beau, Nov 15, 2020.
  1. Nov 15, 2020 at 7:01 PM
    Beau
    Beau [OP] De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Hi everyone, my 2nd gen sequoia that has a ripped leather passenger seat. The remaining leather in the rest of the truck is in great shape. Does this look like something that an upholstery shop can fix? Does anyone have a spare passenger seat with perforated graphite leather? Do they make a patch that I can cut and glue over the section? Any and all input is highly appreciated. Thanks.
  2. Nov 15, 2020 at 7:07 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You could check a pick n pull and get the whole seat.
  3. Nov 15, 2020 at 7:32 PM
    CEwing
    CEwing New Member
    Chuck
    2017 Crewmax Limited
    I had a torn leather seat on my previous motorcycle and I purchased a leather / Vinyl repair kit from Amazon. I had to mix the color to match the tan seat but did the trick and held up for a few years until I sold the bike and may still be holding.
    Beau[OP] likes this.
  4. Nov 15, 2020 at 7:49 PM
    Beau
    Beau
    Thanks fellas, I have been scouring the local pull it yard inventory as well as Ebay for possible solutions. @CEwing, I have attempted leather repair in the past with very poor results. Is there a user friendly kit that you would recommend? Also, this leather is perforated which may add to the complexity of the job.
  5. Nov 15, 2020 at 7:53 PM
  6. Nov 15, 2020 at 7:54 PM
  7. Nov 15, 2020 at 7:59 PM
    TheBeast The Beach
    any good auto upholstery shop could repair or replace it with a match imo. I have seen them do wonders.
    YardBird, FWD Tundra and Beau[OP] like this.
  8. Nov 15, 2020 at 11:36 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    YardBird likes this.
  9. Nov 15, 2020 at 11:47 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    X 3!
    Going to cost a little more than some patch crappy fix, but you should get a quality job.
  10. Nov 17, 2020 at 1:18 PM
    Beau
    Beau
    Thanks for all who chimed in. I called the local upholsterer and they want $500 to fix it. I think I’ll go with the option which @ColoradoTJ linked. Any idea if the seat shop has any coupon codes of BF sales?
    YardBird and ColoradoTJ like this.
  11. Nov 17, 2020 at 2:14 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    If diy, good time to clean the foam underneath and shopvac the water out. You can use twist ties in lieu of hog rings + tool. Check the Katzkin diy install threads here for tips. If you’re ambitious, you can even install seat heaters from Amazon.
  12. Nov 17, 2020 at 2:31 PM
    Elduder
    Elduder New Member
    Kind of an obscure option, but you could do a repair, then cover the fronts in a set of Clazzios or get a full set. You can email Clazzio, they do sell seat covers separately.
  13. Nov 18, 2020 at 10:14 AM
    Beau
    Beau
    I have heated and ventilated seats so I believe the only option will be the replacement seat leather and so I will be going that route. Thanks to all who have given advice; much appreciated! For now, this issue is resolved.
    Boerseun likes this.
  14. Nov 18, 2020 at 10:13 PM
    FWD Tundra
    Washington
    Good choice.
  15. Nov 19, 2020 at 12:37 AM
    school teacher
    school teacher New Member
    Edward
    Louisville Ky
    2002 Tundra Limited
    Leer Cap RAV/4 V-6
    I have a 2002 Tundra Limited with 272,000 miles on the clock. it has leather seats that have cracked from sunlight over the years in spite of using leather wipes from Armor All on a frequent basis. The Tundra is well maintained and in excellent mechanical condition.
    For the front seats I purchased Carhartt seat covers that are custom made for the Tundra. They are made of the same material as Carhartt work cloths and look and feel great. I will purchase a new Toyota some day and intend to put Carhartt seat covers on the vehicle from day 1.
    https://www.carcoverusa.com/carhart....php?msclkid=de02d8275c221c06691487916dcec955
    toyofan87 likes this.
  16. Nov 19, 2020 at 8:25 AM
    K0WALSKI
    K0WALSKI New Member
    Tom
    Up Nort'
    2020 Smoked Mesquite 1794 Edition
    Upholstery shop rates are far better than what I expected. While $500~ isn't exactly cheap, when you compare that to dealership labor rate for basic repsirs or one of my local spraying companies, fixing a high-quality leather seat (that you use and feel daily, mind you) is a steal at that price.
  17. Feb 28, 2021 at 3:28 PM
    Beau
    Beau
    I went with the seat shop and finally got around to installing it today. I think it came out great and is a very close match to the original. Thanks for everyones suggestions. It ended up being $183.20 with the Black Friday discount code.IMG_5159.jpgIMG_5157.jpg
  18. Feb 28, 2021 at 3:40 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    That's a much better deal than the $300-500 to buy a new OEM seat bottom cover.
