Rock lights help!
Discussion in 'Lighting' started by 510Krish, Oct 16, 2018.
  1. Oct 16, 2018 at 9:46 PM
    510Krish
    510Krish [OP] New Member
    2018 Toyota Tundra Platinum 4x4
    Hey guys, I have a 18 tundra and I recently installed some rocks lights. A few days ago my truck battery was flat when I tired to start it. It turns out it was my rock lights the made it flat since it’s controlled through Bluetooth and I may have accedently turned it on. So currently, the Power running to the battery with a fuse and the ground is running to the fender bolt near the battery. So what I want to do is connect the power wire to the positive wire on the cargo lights. I need some help locating the power wire for the cargo lights (3rd brake lamp). I’m not trying to unbolt my dash or nothing like that. Is there any wires going though the door jam on the driver side where I can connect the power wire for my rock lights that is controlled from the cargo light switch? If so can someone tell me where to find it and maybe attach a picture
  2. Oct 16, 2018 at 9:54 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    On my '16 there's a very small brown wire beneath the driver door sill. I tapped into that to run puddle lights under my truck that turn on and off with the courtesy lights. Not sure if that's what you're trying to achieve.
    SpeshulED and dcsleeper408 like this.
  3. Oct 16, 2018 at 10:07 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Why not get a harness with relay and fuse and switch that way u avoid the hassle of turning on by accident. U add a switch and once it’s on control with Bluetooth. Easy peasy
  4. Oct 16, 2018 at 10:10 PM
    fisherman951
    Tony
    2017 crewmax 4x4
  5. Oct 16, 2018 at 10:45 PM
    510Krish
    I don’t want to run a separate switch since I don’t want to drill holes into my dash. I need a wire that will turn on the rock lights when I turn on the cargo lights. What I need is a wire I can tap into from the driver side door jam
  6. Oct 17, 2018 at 7:06 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Damn right it was a great recommendation 'cause I learned it from you Ron!
  7. Oct 17, 2018 at 7:14 AM
    510Krish
    So are these wires in the wire lume?
  8. Oct 17, 2018 at 8:30 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Just riding on your coat tails Ron. :D
    NewImprovedRon likes this.
  9. Oct 20, 2018 at 4:37 PM
    510Krish
    Does anyone know the exact wire on this shit? I’ve been trying to find the right color for the last 3h
  10. Oct 20, 2018 at 4:51 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    What year?
  11. Oct 20, 2018 at 4:52 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    NM. I see 2018. It's a pink wire under the driver side sill.
  12. Oct 20, 2018 at 5:08 PM
    510Krish
    There is like a 100 pink wires
    oems1794 likes this.
  13. Oct 21, 2018 at 10:47 PM
    510Krish
    Has anyone done this yet with a 18 tundra crewmax. Still can’t figure it out
  14. Oct 21, 2018 at 11:03 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  15. Oct 25, 2018 at 7:31 AM
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    On the 18 in the wire bundle under the driver's door sill, it is the pink wire. I'll try to take a pic later. i think it's the bright pink one
    831Tun likes this.
  16. Oct 28, 2018 at 1:21 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Far right meaning the black wire?
    831Tun likes this.
  17. Nov 12, 2018 at 2:52 PM
    510Krish
    Ok, so I’m tapping into the rear scuff plate. Does anyone know how to route the wire from under the truck to the rear surf plate without drilling? My control box is mounted in the frame rail under the driver and I need to get the 18 gauge wire somehow into the cabin to the rear scuff plate. Does anyone know how to do it???
  18. Nov 12, 2018 at 5:45 PM
    510Krish
    Can you please attach some pictures? Of the drip edge drain hole and where to fish the wire through. I wasted my whole day today to find a way to fish it through. And yes I’m going to use a inline fuse
  19. Nov 12, 2018 at 7:10 PM
    510Krish
    Can you also attach a picture of where the wire comes out from?
  20. Nov 13, 2018 at 5:00 AM
    War Machine
    War Machine SSEM # 5 3MW
    I’ve been wanting to get these for quite a while, but figured I’d screw up trying to wire them.
    Sunsun Upgrade Led Light Illuminated Door Sill Scuff Plate Guard Sills Protector Trim Cover for 2008-2017 Toyota Tundra ¡ https://www.amazon.com/dp/B07HC8VMQ1/ref=cm_sw_r_cp_tai_sQS6BbE7X0EE9
