Rock sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by MidwestTundra81, Aug 25, 2022.
  1. Aug 25, 2022 at 8:14 PM
    MidwestTundra81
    MidwestTundra81 [OP] New Member
    Rob
    2020 Tundra TRD Pro
    None
    Hello all, new to the forum so I apologize if this has been covered. I am looking for rock sliders for my 2020 tundra trd pro but I don’t want to break the bank I’ve done research but I don’t know the strength differences between cold rolled, DOM, HREW, or aluminum? I’ve seen sliders go for as little has 350 to as much has 1700, I’m just not sure what the minimum wall thickness is I can get away with is, thank you for any advise you ask can give, I would like to add this is an overland build not a rock crawler so I don’t need anything extreme just want to make sure I have protection from the odd bolder or tree stump lol
  2. Aug 25, 2022 at 8:19 PM
    GODZILLA Introverted Troglodyte
    Wyoming
    2024 Ferd F150 XLT, 2019 Super Tenere
    Trying not to mod it
    A little more info on what you expect from the sliders would be helpful. Are you actually going to off road and might need them to support the weight of the truck, or are you just wanting the nice tucked look they provide with a bit of a step like utility?
    I'll say this, do not buy aluminum if you plan to actually use them. Aluminum is soft and won't slide. Rocks will dig into it and grip/gouge it.
  3. Aug 25, 2022 at 8:24 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
    It will be used for overlanding so I’m not looking to wheel out in Moab or anything extreme I’d just like protection from the unseen boulders or obstacles I might encounter
  4. Aug 25, 2022 at 8:34 PM
    Wyoming
    That's good info to start with. Overlanding is a kind of overused generic term, though. Some crawl out to remote locations with scrapes and bumps while others stick to established/maintained trails and both will call it overlanding.
    If you are in the latter group, you can use just about anything as an ablative layer. Had some nerf bars on an old Dodge and they saved me from a tree stump. They were cheap, and served their purpose, but did not survive the encounter.
    If you are in the first group that is a bit more off road you will want quality sliders that can support the weight of the truck. You'll also be looking for more coverage between the wheels. These aren't cheap. I have the RCI sliders and I have no intention of doing big off roading type things, but I did go on Imogene Pass. It's listed as an easy off road trail, has gorgeous views, and I got lazy and picked a bad line. One mistake and those thousand dollar sliders paid for themselves.
    The point is that you want more protection than you think you will use.
  5. Aug 25, 2022 at 8:46 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
    So avoid the 700 dollar smittybuilt and go for 1500 cali raised is what you are saying? I was afraid of that! But thank you for your advise, I am just getting into the hobby so I will be starting off with the gravel back road trails but the more experience I get I would like to just venture out to where the tundra can handle, thank you again
  6. Aug 25, 2022 at 8:48 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No one ever plans on using the sliders but trust me it’s worth the price. Mine have saved me around some narrow trails and tree stumps. I’ve got the westcott designs units.
    TheBeast, BlueRibbon4x4 and GODZILLA like this.
  7. Aug 25, 2022 at 8:49 PM
    Wyoming
    Honestly, the RCI are only around a $1000, so I wouldn't pay more than that. I would only go for ones that do not require drilling to be used as true sliders and can hold the weight of the truck. I also wouldn't pay to have them coated. Clean them up when you get them, and rattle can primer and paint on them. If you ding them up it's way easier to touch up something you did yourself. I was dumb and bedlined mine because I was sure I'd never hit anything. Now I have to strip them and paint them.
  8. Aug 25, 2022 at 8:54 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Steelit would be good for this.
  9. Aug 25, 2022 at 9:01 PM
    Wyoming
    There's already rust, so I have to strip it. Steel-it is a bit spendy compared to Rust-oleum. lol
  10. Aug 25, 2022 at 9:05 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
    I was thinking about line-x or rhino lining, so thank for that nugget of info, maybe I’ll just put that grip tape on top instead
    Kernal likes this.
  11. Aug 25, 2022 at 9:07 PM
    Wyoming
    Definitely a better way to go. You could just do a bedliner on top for grip as well. You just don't want it on any surface that a rock might dig into. It peels like a banana, as posted previously. It took the primer with it when it peeled.
  12. Aug 25, 2022 at 9:07 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
    I haven’t heard off westcott I’ll look those up too, thank you
  13. Aug 25, 2022 at 11:48 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Sliders 100% worth it. Just make sure to get the kickout on this giant truck. Mine saved me from alot of damage at the gas station when I turned too tight into a safety pole at the pump island. My cali raised kickout corrected my dumbassery. Instantly paid for themselves.
  14. Aug 25, 2022 at 11:53 PM
    AZBoatHauler
    So.Arizona
    I just cleared the bare steel and put grip tape on the step points. Super cheap and I’ve been happy. These are WKOR sliders and I love them. They’re rock solid and offer wheel to wheel protection. E2296B84-C246-4580-A645-6AC5EC3ED5BF.jpg
  15. Aug 26, 2022 at 12:13 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The WKOR that @AZBoatHauler pictured are, IMO, some of the best sliders out there. I ran All Pro for a couple of years and beat the snot out of 'em. Then I upgraded to the WKOR. SDHQ sliders are very solid too. I just prefer that little bit extra length of the WKOR. I haven't seen the RCI sliders but their skids took a lot of abuse before I changed them out.
  16. Aug 26, 2022 at 5:23 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    RCI Bolt on, Kickout, top-plate (for dog) DIY Por15 & Rustoleum Spray paint, just put them on a few months ago. They sit tight to the frame, high ground clearance but work well as a step.
    Install absolutely sucked, but it was worth it in the end. I have NOT drilled into the frame yet, just used the existing holes and RCI confirmed in writing they will be fine. Lots of great options in the USA, we were limited as to who would ship at a reasonable cost.
    They are basically used as steps for me with the added protection if needed.
    Love them.
    SLMw1TFRkfGit6c1z6nzAywT-7G2fBINpxVh9lbp_e7d04e6fa5578567c1d328d418752afc651ffc49.jpg
    K7D0zGSQMPYeZ67OUSDLCgh0LQZTAnB23IX051uc_3b4411418ac954474f57af9155c4d46a4f692b06.jpg
  17. Aug 26, 2022 at 7:47 AM
    MadMaxCanon
    For what is worth I think the cali raised are the best. Thick, heavy and they have a support bar in the back by the kickout. Plus their install is good and it has a full mounting plate instead of individual bolt mounting points.
    Sumo91 likes this.
  18. Aug 26, 2022 at 8:33 AM
    mpj76a
    mpj76a New Member
    I installed the cali raised sliders with step out and top plate. If anyone goes this route, pm me if you want some install tips.
    MadMaxCanon and BravoDeltaRomeo like this.
  19. Aug 26, 2022 at 3:48 PM
    Kernal
    Kernal New Member
    Kyle
    Charleston SC
    ‘18 4x4 4x4 DC
    WKOF are the best. They don’t protrude very far from the body though so if you’re looking for pinstripe protection these are not gonna cut it.
    I look at it this way, we’re all driving $50k+ trucks. I want mine to be dent free for a while so $1500 isn’t too costly for insurance.
  20. Aug 26, 2022 at 5:07 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I'm waiting on mine to come in the mail. They said around 2-3 week lead time. I'm excited to get them installed
    MadMaxCanon[QUOTED] likes this.
  21. Aug 26, 2022 at 7:12 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
    But when you are trying to build out the truck and the project manager(aka the wifey) controls the budget you have to be able to come up with something more cost effective, I can’t convince her I need to spend over a grand on everything I want to put on my truck, which is why I was asking about the different types of steel, why spend 1500 if a 700 dollar slider can perform about the same
  22. Aug 26, 2022 at 7:21 PM
    Wyoming
    Can you tell us what slider you found that is $700? I would like to see these.
    I'm a cynic so I'm going to guess the only way the can be sold that cheap is if they are not a true slider, but instead a slider style running board, or if they are made out of something like mild steel. Same kind of thing you see with aftermarket bumpers. Sure C4 Fab's bumper is twice the price of some of the others, but it's not put together poorly or made from heavy, soft steel.
    BravoDeltaRomeo likes this.
  23. Aug 26, 2022 at 7:26 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    If they make them for your truck, BFF are legit. Or White Knuckle.
    Tripleconpanna likes this.
  24. Aug 26, 2022 at 7:26 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
    On carid a brand called smittybuilt, they use cold rolled steel 3/16 diameter tubing, but this is where my questions are since a lot of products claim to be rock sliders when they are just nerf steps, how can you tell before buying if the steel will be strong enough to support the truck since not all brands include pics of forklifts lifting the truck up
  25. Aug 26, 2022 at 7:30 PM
    Wyoming
    Do you have a link you can post? Sorry, I'm at work and a little busy, but some you can tell by looking. Others you have to start asking questions.
  26. Aug 26, 2022 at 7:32 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
    I will try, I apologize I’m new to this forum stuff and I’m new to owning an iPhone
    GODZILLA[QUOTED] likes this.
  27. Aug 26, 2022 at 7:34 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
  28. Aug 26, 2022 at 7:36 PM
    alb1k
    Left Coast
    It's good
    They will look like this.
    2BADF08E-D7B7-40A9-94A0-CF136BB27016.jpg E6CD218C-B72E-4D37-9D33-695B54A4CC0F.jpg 031F38E2-31E9-4C40-8206-351D5D9849BB.jpg ECAB627C-4015-4DF1-95D6-5E2FD7B7AA66.jpg FF9AAB4B-569E-40E5-858F-F4E5BA747FA3.jpg
  29. Aug 26, 2022 at 7:43 PM
    MidwestTundra81
    Rob
    2020 Tundra TRD Pro
    None
    Did you weld those braces to the frame or are do they come that way from the factory? I haven’t been under my tundra yet I’ve only had it a few months
  30. Aug 26, 2022 at 7:45 PM
    alb1k
    Left Coast
    It's good
    Those look like 2 supports a side? Nothing about those says slider to me, although they look good. Call Brute Force Fab and wait 6-9 months or White Knucle if you want serious protection. Some of the other responses like RCI could be great as well, I just don't know them as a 1st Gen guy.
