Rock Warrior lift questions
Discussion in 'Suspension' started by WoodyOrDiddy, Nov 27, 2019.
  1. Nov 27, 2019 at 10:59 AM
    WoodyOrDiddy
    WoodyOrDiddy [OP] New Member
    2011 TRD Rock Warrior CM
    3" lift, 35" MTs, M1 bumpers w/16k winch, pocket flares, bolt on breathables, Air Ride air bags w/ compressor
    I've scoured these forums for the last 2 days and cant seem to find the answers I am looking for. My 11 Rock Warrior has the 17" forged wheels. I have a cheaper lift that alters my factory geometry, and it has done a serious number to my front end. And I'm not just talking ball joints and tie rod ends. But it actually destroyed my rack last year (not a cheap fix). So I am trying to fix this, and I assume the easiest and least expensive way to do this is with lift spindles. Problem is: every one I see says it wont work for RW's because they wont fit in the 17" wheels. So my questions essentially are: Is anyone aware of this being true, and if so, do you know of a product that will work? Am I even leading myself down the right path to correct my issue, or do I just need to junk my lift and start fresh? If the latter: What is a decently priced ($1500-2000) full kit for someone who really doesn't do any SERIOUS off-roading? Any help is appreciated and if this thread already exists somewhere, feel free to tag me in it and accept my apology for a duplicate post. Thanks!
  2. Nov 27, 2019 at 11:08 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Let me save you some possible headache.
    Spindles will not work with 4x4.
    If you are 4wd, problem solved.
    If not, the discussion will need to continue.
    WoodyOrDiddy[OP] likes this.
  3. Nov 27, 2019 at 11:12 AM
    WoodyOrDiddy
    Well I am 4x4 (as I believe all RWs are). So I guess the discussion of lift spindles is squashed. So the discussion I guess goes to, what the heck can I do?
  4. Nov 27, 2019 at 11:51 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Can you go into what lift you had and more details on your problems with it please, may help with my follow up responses
  5. Nov 27, 2019 at 11:51 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    For what it's worth seventeen's well fit with a spindle left you just need to have the proper offset and/or wheel spacers to push it out otherwise your tie rod at its will be contacting the inner surface of your wheel
  6. Nov 27, 2019 at 11:55 AM
    WoodyOrDiddy
    I have a 3/1 skyjacker leveling kit. Its basically just front struts with the spring plate mounted higher, I believe. Blocks in the back. Id like to resolve this cheaply, but half of me wants to just dump a couple k into a better 6" lift. lol
  7. Nov 27, 2019 at 12:00 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    So you currently have a 6"?
    I ask because that's $ to come back from for a basic coilover 3" lift kit. Drop brackets require frame cutting and refitting a member isn't cheap. So if you have already cut, you'll probably want to stick with a drop bracket.
  8. Nov 27, 2019 at 12:15 PM
    WoodyOrDiddy
    No. I currently have the 3". Was thinking about going bigger.
  9. Nov 27, 2019 at 12:16 PM
    WoodyOrDiddy
    And I do have spacers on my wheels
