Rolling Bowling Ball Sound
Discussion in 'General Tundra Discussion' started by JSmiff17, Apr 29, 2020.
  1. Apr 29, 2020 at 11:15 AM
    JSmiff17
    JSmiff17 [OP] New Member
    Justin
    Tundra TRD Pro
    I have a 2016 Tundra TRD PRO with a 3.5" lift and 35" wheels. Lately I have noticed a rolling type sound when Im braking at slow speeds or taking a slow right turn, best way to describe it is imagine a loose bowling ball rolling around in the bed. The sound is not always consistent and only happens in those instances when it does, it seems like its coming from the rear. Its not a wheel bearing. I'm at a loss for what it might be, Im just hoping its not indicative of something semi-serious deteriorating with the drivetrain.
  2. Apr 29, 2020 at 11:38 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Have you pulled the rear diff plug and checked for metal chunks and fluid?
    I’d check that next.
    (eta - never mind, didn’t notice slow right turn).
    I’d listen to Sean on the dust shields.
  3. Apr 29, 2020 at 11:39 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Needle bearing....or wheel bearing...
  4. Apr 29, 2020 at 11:40 AM
    15whtrd
    15whtrd Mr. Blonde
    Check the dust shields for the brake rotors and make sure they aren’t rubbing the rotor. That can happen. It only takes a small tweak for them to rub when going around the corner.
  5. Apr 29, 2020 at 1:51 PM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Did you check in the bed. Maybe your friends put a bowling ball in there.
    In all seriousness, check the spare tire to make sure it's snugged up and not hanging loose where it can bang around.
    Good luck.
    Tundyfundy likes this.
