Roof Rack compatibility
Discussion in '2.5 Gen Tundras (2014-2021)' started by TonyNCo, Aug 22, 2020.
  1. Aug 22, 2020 at 9:23 AM
    TonyNCo
    TonyNCo [OP] New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Does anyone know if the TRD Pro racks from the 2019/2020 4runners will work on the Tundras? There is one on Craigslist that is a good deal.
    I am thinking there might be a width issue. When roof racks are mounted, I assume the screwed in areas tend to be more robust areas of the roof.
    Thx
  2. Aug 22, 2020 at 10:01 AM
    Sunnier
    Sunny
    San Diego, CA
    Yep, not the same width. Typically drilled into the rain gutter.
  3. Aug 22, 2020 at 10:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You should search this site, there was a recent post about the installation of a roof rack. Mounting locations are critical as there are air bags, wiring, etc that can easily be damaged if you drill in the wrong location.
  4. Aug 22, 2020 at 11:05 AM
    kevine0001
    kevine0001 New Member
    Kevin
    I wanted to go with a hard mounted roof rack. Ended up ordering an INNO off of autoanything.com. It's the clamp style that clamps onto the roof/door jams. Locking and perfect for my fishing kayak. And no holes drilled. They had a 10% discount that may still apply. $443 shipped to my door.
