Rough Country lift switch to BDS?
Discussion in 'Suspension' started by famouzstarz, Sep 19, 2017.
  1. Sep 19, 2017 at 9:04 AM
    famouzstarz
    famouzstarz [OP] Da illest!
    ABQ,NM
    Platinum Tundy!
    20" Fuel Wheels, 7" BDS Suspension, Tint, etc..
    looking at purchasing a tundra with a rcx lift 6" but would like to switch to a bds 7" has anyone done this before?
  2. Sep 19, 2017 at 9:19 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I haven't on a Tundra but I did do the same swap a couple of weeks ago on a '15 Chevy. 6" RC to a 6.5" BDS with Fox's. Customer bought the truck used and had money to burn. Pretty cut and dried, basically swapping parts for parts. The only thing I ran into was needing a few factory bolts that the RC kit had eliminated.
  3. Sep 19, 2017 at 9:20 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Do it !!
  4. Sep 19, 2017 at 9:21 AM
    famouzstarz
    ABQ,NM
    Platinum Tundy!
    Thanks for the info, seems pretty doable then just the overall cost and time.
    Jsena likes this.
  5. Sep 19, 2017 at 9:25 AM
    duece292
    Greg
    Green Bay, WI
    Definitely doable :thumbsup:. I think I had about 7 hrs into the swap and some of that was cleaning up someone else's sloppy workmanship.
    Jsena likes this.
  6. Sep 19, 2017 at 11:25 AM
    Isn't your rear cross member cut? With a BDS? Rough Country are...can he do?
    Jsena[QUOTED] likes this.
  7. Sep 19, 2017 at 11:27 AM
    Rear crossmember is cut on a RC 6" unless BDS system does same process..I don't see why not???
  8. Sep 19, 2017 at 12:20 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Mine is not cut because I'm 2wd, if he's 4wd then it will be cut with BDS also
  9. Sep 19, 2017 at 12:24 PM
    Post #8
  10. Sep 19, 2017 at 12:42 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    definitely a solid upgrade!
    Jsena likes this.
  11. Sep 19, 2017 at 2:32 PM
    famouzstarz
    ABQ,NM
    Platinum Tundy!
    Well nevermind purchased a different truck already with a bds lift but thanks for the quick input and response!
    TheBeast and Jsena like this.
  12. Sep 19, 2017 at 2:43 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Pictures???? :worthless:
    TheBeast likes this.
  13. Sep 19, 2017 at 4:42 PM
    famouzstarz
    ABQ,NM
    Platinum Tundy!
    Pics
    CJ21, duece292 and Jsena like this.
  14. Sep 19, 2017 at 4:44 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Just like mine.. I still need to do the chrome clean up... what size tres and rims
  15. Sep 19, 2017 at 4:46 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    If you want a good sturdy Tundra Insert for the back tailgate.. go to Amazon. Tuffskinz are super durable.. a little more pricey than the others but worth it
  16. Sep 19, 2017 at 4:51 PM
    famouzstarz
    ABQ,NM
    Platinum Tundy!
    20" wheels not sure on the backspace right now, 35x12.5 tires im 10 hrs away from the truck so hopefully ill have it sat upon delivery!
  17. Sep 19, 2017 at 5:09 PM
    A whitey tighty Tundy!
  18. Sep 19, 2017 at 5:10 PM
    famouzstarz
    ABQ,NM
    Platinum Tundy!
    haha for now....
    Jsena likes this.
  19. Sep 19, 2017 at 5:44 PM
    Just playing with ya
  20. Sep 19, 2017 at 6:22 PM
    famouzstarz
    ABQ,NM
    Platinum Tundy!
    It's all good this is what I came from...just another whitey tightey
    CJ21 and Jsena like this.
  21. Nov 3, 2017 at 12:02 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    Jsena likes this.
