Rough Country light bar rocker switch wiring ?
Discussion in 'Lighting' started by scpete24, May 6, 2021.
  1. May 6, 2021 at 4:56 PM
    scpete24
    scpete24 [OP] Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Should be an easy question for you electrical lighting guys, but just want to make sure. Recently bought a RC bumper light bar that came with a push button switch. I bought the rocker switch and just want to know which wire is what on the original. Original switch has white, blue, and black running to a relay. New rocker has negative, positive and out. I know someone has done this previously.
    Black to -
    White to +
    Blue to out
    Is that correct?
  2. May 6, 2021 at 5:02 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    scpete24[OP] likes this.
  3. May 6, 2021 at 5:12 PM
    scpete24
    Orange County, CA
    Thanks, based on that vid I think I have it correct
  4. May 6, 2021 at 5:15 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah it sounded right, but I was too lazy to watch the video lol.
    scpete24[QUOTED][OP] likes this.
  5. May 6, 2021 at 5:55 PM
    I didn't like that original button switch either. I had an extra Rigid harness so I used that. The only thing I didn't like was the big round plug that is on the light bar itself.
  6. Feb 1, 2022 at 2:56 PM
    rob_541_
    rob_541_ New Member
    So If you buy the cali raised switch will it be the same connections on the RC light bar?
  7. Feb 1, 2022 at 2:59 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pretty sure I cut the button off and wired to switch using my own wiring
  8. Feb 1, 2022 at 2:59 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The switch from CR will be a 4 wire switch: source, backlight, power indicator, ground. You can wire that up any number of ways, depending on your needs.
    rob_541_[QUOTED] likes this.
  9. Feb 1, 2022 at 3:06 PM
    rob_541_
    rob_541_ New Member
    Okay, I’m really dumb when it comes to wiring. I just got the RC 30in light bar and was gonna buy the CR oem switch. Just wanted to see if that video is basically the same wiring instructions for the RC light bar. Don’t wanna mess anything up.
    TRDFerguson likes this.
  10. Feb 1, 2022 at 3:11 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep. You can use that video and it’ll work just fine.
  11. Feb 1, 2022 at 3:12 PM
    rob_541_
    rob_541_ New Member
    Thank you!!!
  12. Feb 1, 2022 at 3:20 PM
    Yes most light bar wiring is standard across the brands.
    rob_541_ likes this.
  13. Feb 1, 2022 at 3:24 PM
    rob_541_
    rob_541_ New Member
    Thank you! Never installed one before so just making sure before I start.
  14. Mar 4, 2023 at 4:34 PM
    Stevegibson
    Stevegibson New Member
    Ok so this is great but I am trying to use the “plug and play illumination harness” from Cali raised and they only have 2 leads coming from the switch after you install them.
    https://caliraisedled.com/products/plug-and-play-switch-illumination-harness?variant=39506469453866
    so if my RC switch has 3 leads how should I be wiring up the two from the switch to the 3 on the light harness? The video does not show that wiring setup. Do I have to cut and splice into one of the others that is fixed in the illumination harness?
