Rough Idle While Parked
Discussion in '3rd Gen Tundras (2022+)' started by Greyhound, Jun 6, 2024.
  1. Jun 6, 2024 at 8:52 AM
    Greyhound
    Greyhound [OP] New Member
    Stock
    I do a lot of sitting in my truck at a jobsite for work, and when it's hot/cold out I run the AC/heat to stay comfortable.
    I've noticed just sitting in Park the engine idle is a rough, it's more noticeable than my Chevy Colorado with 212,000 miles.
    Is that normal? Should I not be doing that with this truck because it has turbos?
  2. Jun 6, 2024 at 9:10 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Yeah, its not the smoothest idling engine
  3. Jun 6, 2024 at 9:24 AM
    Greyhound
    Stock
    Dang, thought it was something I could avoid.
  4. Jun 6, 2024 at 10:07 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Mine is very very smooth when Idling. Only makes slight noise while waiting at some traffic lights, but that's probably direct injection doing its cleaning
  5. Jun 6, 2024 at 10:13 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Isn't it the port injection that keeps the valves clean?? The direct injection is noisy when it is in operation tho.
  6. Jun 6, 2024 at 10:15 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Lol I'm not sure, one of those.. Always forget
  7. Jun 6, 2024 at 10:20 AM
    Nm6300'asl
    2022 DC SR5 4x4
    It is the port, the fuel sprayed on the valve keeps the carbon that the direct injection causes from building up.
    Kap1 likes this.
  8. Jun 6, 2024 at 10:48 AM
    Greyhound
    Stock
    So it is the Port Injectors causing the rough idle to keep the valves clean?
  9. Jun 6, 2024 at 10:52 AM
    Nm6300'asl
    2022 DC SR5 4x4
    No the direct does that.
    Pay attention on a cold start first thing in the morning, the truck will be in direct injection mode and noisy, about 15-20 seconds later as the idle levels out and engine "smooths" out it changed over to port injection.
    Greyhound[OP] and Kap1 like this.
  10. Jun 6, 2024 at 1:20 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Can you try to get video of it and idle sound near the front wheel wells? So we can hear it.
    Port injection causes idle to run little bit rough, for maybe 5 seconds or so when Idling, and this only happens every 10-15 min or so... Usually I can notice it when waiting on red lights and can see rpm slightly fluctuate. It's a very slightly engine sound difference
  11. Jun 6, 2024 at 3:40 PM
    Greyhound
    Stock
    It's more of a vibration than a sound. I just took it to the dealership for a window trim issue and asked about the idling, he said it's normal and his Tacoma does it too. Idk, I haven't owned a Toyota in almost 10 years but I feel like a brand new vehicle shouldn't vibrate oddly just sitting still.
    Kap1[QUOTED] likes this.
  12. Jun 6, 2024 at 4:36 PM
    malveman
    malveman New Member
    New jersey
    2022 Limited long bed MGM
    I notice when I’m at a light it idles at say 600 rpms and if I push the break harder the idel drop even lower to like 500 rpm that’s when I notice a little more roughness
    eddiefromcali and Greyhound[OP] like this.
  13. Jun 6, 2024 at 7:58 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Yes, I got this same slight vibration when waiting on the traffic lights. Occurs every 5-10min approximately and vibration lasts about 5 seconds...
    Just by making educating guess, we all think that it has to be port injection. Car nut describes some of such symptoms for other Toyotas and supposedly it's normal. Nobody had dealer do anything about it yet in the past two years on this forum.
    Greyhound[QUOTED][OP] likes this.
  14. Jun 6, 2024 at 8:33 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    These trucks seem to like to be worked and when they are idling they don’t like it. I agree they are not the smoothest idlers. They sure run nice when under load.
    Tom976 and Greyhound[OP] like this.
  15. Jun 6, 2024 at 9:23 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I've had a hemi prior for ten years, and that was NOT a smooth idler! Lots of knocks, ticks, marble rolling around, and the fun part that it varies on a monthly basis. This Tundra engine is amazingly smooth idler
    Tundrastruck91 likes this.
  16. Jun 6, 2024 at 10:23 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Yup I’m amazed mine is extremely smooth and quiet!
  17. Jun 6, 2024 at 11:05 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Doesn't it sound like a Camry or a Lexus? So quiet... It's amazing that it's actually a truck!
    It's a shame that we got this recall thing now...
  18. Jun 7, 2024 at 1:00 AM
    blenton
    blenton New Member
    What octane fuel are you running?
  19. Jun 11, 2024 at 6:07 PM
    Greyhound
    Stock
    91
  20. Jun 11, 2024 at 6:22 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I rented a 3.5 Ecoboost F150 and was surprised how rough it idled too, per owners comments its a v6 side effect since it’s not balanced/offset. Would imagine the Toyota 3.4 is similar. My FJ and 4Runner though were not as rough as that F150 so dunno.
  21. Jun 12, 2024 at 6:11 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    When your in park is the truck on any incline?
    Putting any stress on the parking claw will transmit alot of feed back to the cab. Use the parking brake let of foot brake then put into park.
  22. Jun 12, 2024 at 6:33 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Just a guess here. The 2018 is my 1st Tundra. Even with the V-8 I do notice a slight vibration when the AC compressor engages while idling at stops. I live in Florida so the AC gets run quite a bit.
    I haven't researched the function but when I put it in MAX AC which I assume keeps the compressor on, I don't notice it. When not in MAX I can feel it when the compressor turns on and off.
  23. Jun 13, 2024 at 7:49 PM
    Greyhound
    Stock
    No it was about as flat as it could have been when I noticed the vibration.
  24. Jun 13, 2024 at 8:39 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Huge bummer and I hope it gets resolved quickly for ya'll.
