Running board brackets
Discussion in '2.5 Gen Tundras (2014-2021)' started by Striperfishing, Jan 10, 2025.
  1. Jan 10, 2025 at 9:26 AM
    Striperfishing
    Striperfishing [OP] New Member
    Just recently bought used running boards and noticed all the bolts on the brackets to the running boards are rusted out and need to be replaced. I noticed that there’s no threading or bolts in the running boards. Are there supposed to be threads or nuts on the inside of the running board to attach to? And if not how do the brackets attach. I assume they’re shot as there’s no way of threading in a bolt without drilling a hole over the top to get a nut onto the bolt on the underside.
  2. Jan 10, 2025 at 10:00 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    first need to know what you purchased. What is the brand and model of running boards? Maybe post a few pics?
    Generally, most steps are all similar, brackets attach to the truck- in factory set threads and the steps/boards sit on the brackets....and yes there are typically threads in the bottom of the steps/boards so they can be bolted to the bracket. It is a very easy install, no drilling or fuss.
    https://www.youtube.com/watch?v=to6KA5d6-TQ
    1lowlife likes this.
  3. Jan 10, 2025 at 10:24 AM
    Tundra family
    Tundra family New Member
    Do they have slots for T-bolts? Some of em have slotted bottoms so they can be adjusted fore and aft, then they are tightened down to the bracket with a T-bolts and nuts
  4. Jan 10, 2025 at 10:38 AM
    Striperfishing
    Those are the running boards plus the mounting holes I am having issues with.
  5. Jan 10, 2025 at 11:18 AM
    Tundra family
  6. Jan 10, 2025 at 11:23 AM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
  7. Jan 10, 2025 at 11:24 AM
    Striperfishing
    Yes but they all come out looking like this or worse regardless of how I have removed them.
  8. Jan 10, 2025 at 12:14 PM
    frichco228
    You need new hardware to attach. Nutserts/rivnuts slip into the holes on bottom of the steps and then bolts matching the threads of the inserts to attach the step to the brackets.
    1lowlife and Tundra family like this.
  9. Jan 10, 2025 at 3:20 PM
    Striperfishing
    I used the rivnuts and they worked perfectly thanks for the help.
    Tundra family likes this.
