Running Boards - Factory Toyota
Discussion in '2.5 Gen Tundras (2014-2021)' started by kws129, Sep 26, 2018.
  1. Sep 26, 2018 at 5:36 AM
    kws129
    kws129 [OP] New Member
    Kevin
    2018 Tundrs TRD Sport
    2018Tundra likes this.
  2. Sep 26, 2018 at 9:59 AM
    nodak67
    nodak67 New Member
    JR
    that doesn't look the same as the "KG" option I have on mine
  3. Sep 26, 2018 at 10:10 AM
    nodak67
    nodak67 New Member
    JR
    Prostar 190 likes this.
  4. Sep 27, 2018 at 4:36 PM
    Glockman19
    Glockman19 New Member
    Looks awesome same color as mine
  5. Sep 27, 2018 at 6:47 PM
    Blueknights75
    Ron
    Clayton, NC
  6. Sep 27, 2018 at 6:54 PM
    These are the same ones I have on my limited.
  7. Sep 28, 2018 at 6:31 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Those are one option for the running boards. Keep in mind, none of the Tundras come with running boards straight from the factory. The dealership that orders the truck can elect to have a set of them installed before they come to the dealership. That's a port installed option or PPO.
    BamaMan44 likes this.
  8. Sep 30, 2018 at 8:26 AM
    KirthGersen
    KirthGersen New Member
    So Calif
    2018 SR5 Crewmax
    Do those stick out far enough, to provide some door ding protection in parking lots?
    My 2018 came with the tubular nerf bar/ steps, but dont like them ... Too close to body for a secure foothold, and they dont extend wider than the door sheet metal.
  9. Sep 30, 2018 at 10:30 AM
    curt37
    curt37 New Member
    FRESNO, CA
    2018 Tundra Limited Crew Cab white
    SNUGTOP BED COVER
    Looks like the ones on my 2018 Limited
  10. Oct 1, 2018 at 8:21 AM
    nodak67
    nodak67 New Member
    JR
    for our use its more of snow/slush protection than door dings since we have winter about 6-9 months of the year.
  11. Oct 27, 2018 at 10:56 AM
    akaguyver
    akaguyver New Member
    2014 5.7 mag grey
    5" zone life coachbuilder shackles 35" nitto trail grapplers 20" xd rims
    looks better then my rbp triple steps
  12. Nov 22, 2018 at 11:51 AM
    Mr Badwrench
    Mr Badwrench New Member
    Do any of you guys have (or know someone who does) Ranch Hand running boards?
    I have looked at dozens of options for running boards, but since I don't have a lift kit, I want them to be somewhat low-profile. I am curious how low the Ranch Hand running boards drop beneath the rocker panels.
  13. Nov 22, 2018 at 3:33 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    That's just wrong!!! As pricey as RBP products are you'd think they would hold up better than that.
  14. Nov 23, 2018 at 11:53 AM
    tundras00
    tundras00 New Member
    I had the stock runners on my 1794. They don't provide ding protection. I opted for RB20's and they provide nice protection from doors.
  15. Nov 23, 2018 at 12:45 PM
    KirthGersen
    So Calif
    2018 SR5 Crewmax
    Since making that Post in September, I also opted for RB20s. They were a bit fussy to install evenly & level, but am pleased with RB20 function & appearance.
    tundras00[QUOTED] likes this.
  16. May 26, 2020 at 11:27 AM
    a_double
    a_double New Member
    Hi, what's the "KG" option?
  17. May 27, 2020 at 4:48 AM
    nodak67
    nodak67 New Member
    JR
    its the option code for the oem black running boards, see profile pic.
  18. May 27, 2020 at 8:07 AM
    a_double
    a_double New Member
    Ah, ok. Thanks.
    I'm considering those!...and shopping around at the moment.
  19. Jun 2, 2020 at 5:17 PM
    mhott
    mhott New Member
    2018 Tundra TRD Sport
    none yet
    Hi nodak67,
    Did you go with these? If so are you happy with them, also can you provide a link to the site that you found them on?
    Thanks!
  20. Jun 3, 2020 at 3:54 AM
    nodak67
    nodak67 New Member
    JR
    KG option code is the factory option for the oem black running boards. it was ordered with them installed from the factory and part of the msrp pricing.
    if you build a tundra on the toyota website, its $345 option by itself or part of the sunroof package for $1195 on the platinum trim.
  21. Jun 3, 2020 at 6:40 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    fyi, the OEM black running boards that I see coming through on trucks today - including my 2020 1794 - are not the same as on nodak67's truck. I specifically sent my dealer a pic of those boards on nodak's truck, but my truck came in with different boards. (the ones on currently on the Toyota site).
    they are fine for my purposes, but not as nice looking as the older OEM boards in my opinion.
  22. Jun 4, 2020 at 4:41 AM
    nodak67
    nodak67 New Member
    JR
    just to add to the convo, if you are in GST/SET region you may not get the same toyota usa oem running boards. the ones being sold as KG option on toyota usa currently (june-2020) are the same ones i have on my 2018 (black running boards for $345) from the pics on the vehicle when you select that option. low hump in the front and raised hump in the back (the humps are for the option to add running board lights which is not available in the usa market for toyota)
    also dont confuse the black step bars as running boards (some dealers call them running boards). they are full length like the running boards but they have a gap between the steps and truck body. i think the double cab has a different look than the crew cab versions.
    non oem manufacturers like iconic makes one almost the same and westin makes one almost identical but with lights in the front/rear hump.
  23. Jun 4, 2020 at 6:14 AM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I just installed the ones in the OP’s post. I like em
    WFD473 likes this.
  24. Jun 4, 2020 at 8:42 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    do you have a link for that? I don't see anything other than the "classic black" running boards on the Toyota site. That's what came through on my truck - same as pictured immediately above by thomasbus337. I'm in MA if that matters.
  25. Jun 4, 2020 at 9:05 AM
    thomasbus337
    2020 TRD Sport DC
  26. Jun 4, 2020 at 9:17 AM
    a_double
    a_double New Member
    I just installed the classics but now that I see the KG option, I like those better. Are they available for purchase? What's the PN for DC?
  27. Dec 29, 2020 at 1:57 PM
    bernenbush
    bernenbush New Member
    Hello- does anyone know where I can purchase a set of boards like Nodak67's? I just saw them on a new Tundra Sport at the dealer and they were put on at the port, not the dealer. How do I get a set for my 16 Pro-Max?
    Thanks
  28. Dec 30, 2020 at 8:20 AM
    nodak67
    nodak67 New Member
    JR
  29. Dec 30, 2020 at 9:12 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Check with Roman maybe he can order you a pair
  30. Nov 9, 2021 at 5:43 PM
    Joe Mamma
    Joe Mamma New Member
    Bakersfield CA
    2021 Tundra TRD Pro Crewmax MGM
    Do you still have these running boards? If so how are they holding up (the plastic finish)? I really like the clean look and true cab length with no brackets hanging down. Sparks parts was nice enough to send me an exploded view drawing and parts list, put together an order that totals $1,650. My big question now is if the Toyota quality and fit is worth that much money.
