Running rough and shaking at a complete stop and in reverse
Discussion in '1st Gen Tundras (2000-2006)' started by Mattd209, Mar 20, 2023.
  1. Mar 20, 2023 at 7:29 PM
    Mattd209
    Mattd209 [OP] New Member
    Matthew
    2000 white Toyota tundra V8
    I drove up to Reno and my check engine light came on for misfire on the number 8 spark plug. I replaced the ignition coil and spark plug however my truck is still running rough and shaking while at a complete stop and when I go in reverse
  2. Mar 20, 2023 at 7:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Only reverse?
  3. Mar 20, 2023 at 7:33 PM
    Mattd209
    Matthew
    No also when I'm in drive and I come to a complete stop, my truck starts to vibrate and feels like it wants to shut off
  4. Mar 20, 2023 at 7:34 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You might need to pull and check all your plugs and coil packs
    Tundra2 likes this.
  5. Mar 20, 2023 at 7:34 PM
    Vacuum leak?
    JasonC. and Tundra2 like this.
  6. Mar 20, 2023 at 7:35 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'd check the rest of them. Did you use denso coil packs?
    FrenchToasty likes this.
  7. Mar 20, 2023 at 7:37 PM
    Mattd209
    Matthew
    I believe it is a denso. I will have to check.
  8. Mar 21, 2023 at 5:52 AM
    You didn't buy it on scAmazon or fleaBay or WallyWorld, did you?
    Is your truck 2WD or 4WD?
    Do you live in a place where rodents exist and you also park outside?
    The issue you're seeing could be any number of things, vacuum leak, intake gasket leak, rodent chewing on something, bad ground, MAF needs to be cleaned, rodents got in your airbox to make a nest and a chunk of air filter got on the MAF, there's about a hundred more.
    first thing I'd do is rotate the plug and coil from #8 cylinder to the #6 cylinder next door, and see if the code follows. If not, you know it has nothing to do with the coil or plug, it's something else not right.
    Mattd209[QUOTED][OP] and JasonC. like this.
  9. Mar 21, 2023 at 8:01 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Could be water in the gas. I had the same issue when it wasn't bad enough to cause a misfire CEL. A bottle of dry gas fixed that problem.
    w666, shifty` and KNABORES like this.
  10. Mar 21, 2023 at 10:13 PM
    Mattd209
    Matthew
    I bought the coil and plug from auto zone and it's a 2wd
  11. Mar 21, 2023 at 10:47 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Is the plug ngk or denso as well? And was the coil denso?
  12. Mar 22, 2023 at 12:18 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Are you certain you replaced the number 8 spark plug and coil?
    I don't normally recommend autozone coils, and especially for these trucks but they usually work fine they just don't last.
    Aerindel likes this.
  13. Mar 22, 2023 at 6:12 AM
    I also don't recommend anything except OEM (i.e. Denso). Too many people have had issues with even from highly respected companies like MSD.
    And that's a good point about OP getting the cylinders backwards. Didn't dawn on me they could be pulling the coil closest to the brake MC (#7) or any others versus #8, closest to the glovebox.
