Running truck idle all night.....
Discussion in '3rd Gen Tundras (2022+)' started by Treeviper, Oct 28, 2024.
  1. Oct 28, 2024 at 2:56 AM
    Treeviper
    Treeviper [OP] New Member
    Daniel
    2021 4runner
    Hybrid tires, mud flap delete, crossbars
    Not sure it's this is the right place to ask this but..... I'm moving into a 2025 tundra from a 4runner. I've had Tacomas in the past. When I go "camping" on the beach and desert, I tend to sleep in my vehicle and run it all night. It was never an issue in the past in any Tacoma or my 4runner, Does anyone see a problem doing this in the new Tundra with the dual turbos and no external transmission cooler?
  2. Oct 28, 2024 at 3:01 AM
    JayDee
    JayDee New Member
    I'm not sure the new Tundra will let you do that. It wants to turn off the engine when idling after 1hr if I remember correctly. You would likely have to tell the truck to keep running before the idle timer runs out.
    aj350925, nodak67 and Treeviper[OP] like this.
  3. Oct 28, 2024 at 5:02 AM
    nodak67
    nodak67 New Member
    JR
    its funny to watch vehicles in winter time in ND catch fire when people leave them running all the time. even when its -20F out, i have personally seen 1 car catch fire in a BK parking lot due to idling while the whole family was eating inside. sad to see but people dont realize how hot it gets under there with no airflow going over the plastics to cool them.
  4. Oct 28, 2024 at 5:21 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    If a tundra can't idle for long periods - then its useless to me. All my yotas can idle for hours with the A/C on in well over 105 degrees.
  5. Oct 28, 2024 at 5:23 AM
    JerseyGeorge
    JerseyGeorge New Member
    2024 Platinum
    Interesting. I never went camping with a vehicle running all night.
  6. Oct 28, 2024 at 5:36 AM
    jaxadam
    jaxadam New Member
    Then you’ve never been trampin’! (truck camping’)
  7. Oct 28, 2024 at 5:37 AM
    Treeviper
    Daniel
    2021 4runner
    That's why I wrote "camping". It's usually a case of I've been fishing all day, so I'm just not in the mood to set up a tent. Plus, it's so nice to get in to the A/C after being in the sun all day. Often, I'm out where there is literally no facilities, so all you have is your vehicle. And, as I've stated, never had an issue in any of my Tacomas or my 4runner.
  8. Oct 28, 2024 at 5:39 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    My wife’s 2022 4Runner shuts itself off after an hour. Im gonna guess that the gen 3 Tundras do as well.
    Tundrum74 likes this.
  9. Oct 28, 2024 at 6:04 AM
    DRP
    DRP Old Member
    Dave
    Information from that pesky owners manual....
    ■Automatic engine shut off fea-
    ture (except for New Caledonia)
    ●The vehicle is equipped with a
    feature that automatically shuts off
    the engine when the shift lever is
    in P with the engine running for an
    extended period.
    ●The engine will automatically shut
    off after approximately 1 hour if it
    has been left running while the
    shift lever is in P.
    ●The timer for the automatic engine
    shut off feature will reset if the
    brake pedal is depressed or if the
    shift lever is in a position other
    than P.
    ●After the vehicle is parked, if the
    door is locked with the door lock
    switch (P.114) from the inside or
    the mechanical key from the out-
    side, the automatic engine shut off
    feature will be disabled. The timer
    for the automatic engine shut off
    feature will be re-enabled if the
    driver’s door is opened.
  10. Oct 28, 2024 at 6:08 AM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Not sure if it would work but you could try switching it into neutral and then putting the emergency brake on?
    rphass17 likes this.
  11. Oct 28, 2024 at 6:09 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I get a prompt every time I switch into park to stop and idle at the mail box asking me to click yes to confirm shut off in an hour feature or no to keep on idling.
    Not sure I get the prompt in all situations however. Such as I occasionally go thru drive thru and park to eat while idling and not sure always get it. But possible I am not paying close attention since feature is of no value to me and prompt is a nuisance.
    Raven67 likes this.
  12. Oct 28, 2024 at 6:28 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I don’t consider that particularly funny….
  13. Oct 28, 2024 at 6:33 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I slept months in my truck. No engine idling, even in negative temps. No any heat in fact, besides what your body generates and couple of hands warmers for extra cold nights.
    Diesel heater is more efficient. $100 for Chinese, $1000 for brand name.
  14. Oct 28, 2024 at 6:45 AM
    CRFL82
    CRFL82 New Member
    SWFL
    2023 Lunar Rock SR5/TRD Sport
    I had mine running overnight a couple of weeks ago when I got tired of the post-storm no power/AC and just wanted a decent sleep. Spent two nights sleeping in the backseat, and aside from using up gas and cratering my mpg average, it worked fine.
    Raven67 likes this.
  15. Oct 28, 2024 at 6:59 AM
    Fatone
    Fatone New Member
    If you want zero chance of fire don't own any vehicle. The risk of fire when running, idling or parked in your garage is never zero . Never has been and given lithium batteries propensity to fire it may never be
  16. Oct 28, 2024 at 7:02 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    It shouldn't be a problem to idle for days if you want it to.
    Maybe not the best thing for the engine longevity, but it should be no issue whatsoever.
  17. Oct 28, 2024 at 7:10 AM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    Camburg 4-Link, Bed Molle panels, Pelican cargo bin, TRD drop-in Filters
    Check with the Overlanding community. They may have an answer or solution....
  18. Oct 28, 2024 at 7:16 AM
    Fatone
    Fatone New Member
    They make portable smoke and carbon monoxide detectors. That would be advised in any scenario where sleeping while burning any fuel is involved.
    Ericsopa likes this.
  19. Oct 28, 2024 at 10:55 AM
    Hella Krusty
    Hella Krusty New Member
    Buy a sleeping bag .......
    RCwyoming likes this.
  20. Oct 28, 2024 at 11:00 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    pop the hood to help dissipate heat, but you'll be fine. I idle in 115* summer days for hours and its no problem.
  21. Oct 28, 2024 at 11:34 AM
    nodak67
    nodak67 New Member
    JR
    no its not, but between the psa on tv, radio and people telling me to not run a vehicle in extended situations during winters up here in ND cause they can catch fire even though its -20F outside.
    i always tell newbies to never let your engine run longer than 30 min sitting especially older cars.
    unless its colder than -50F ambient (like in russia where you cant shut a car off, otherwise they wont restart in -70F ambient), you can cycle a cold vehicle every hour or so for like 10-20mins.
  22. Oct 28, 2024 at 11:49 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Get a warmer sleeping bag or get a Mr buddy propane heater & crack a window.
    wxman91 likes this.
  23. Oct 28, 2024 at 11:59 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Don't do that. CO poisoning may be not strong enough to kill you, but it would still get a chunk of your health away. No catalytic converter is 100% efficient.
  24. Oct 28, 2024 at 12:17 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    OP said it's the AC he's looking for. Not Heat. heaters and sleeping bags aren't helping much.
    MaineTundy likes this.
  25. Oct 28, 2024 at 12:37 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    I accidentaly let my 2018 run all night a few years ago in the summer. Driver door open, AC on, idled all night in the driveway, garage door open. Discovered it the next morning, I forget the circumstances but I do remember getting distracted.
    Nothing happened except a bunch of wasted gas. Felt pretty stupid.
  26. Oct 28, 2024 at 12:45 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    A oil analysis will tell you if it’s good or not.
    Randy Morton likes this.
  27. Oct 28, 2024 at 12:51 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    @DRP can you clarify that last bullet and where it came from? :D
  28. Oct 28, 2024 at 1:12 PM
    DRP
    DRP Old Member
    Dave
    I'm pretty sure it came from the manual. Can't be 100% sure since it's been over an hour since I looked it up and my memory sucks these days. Clarification will require a deposit to my Venmo account. :Do_O:thumbsup:
    :spending:
  29. Oct 29, 2024 at 10:50 AM
    nodak67
    nodak67 New Member
    JR
    did find a cheap alt heater that sits outside the vehicle. just have to make a platform mount for the tire maybe?
    found them on vevor diesel heater
    vtl[QUOTED] likes this.
