Rust above windshield... What to do?
Discussion in '1st Gen Tundras (2000-2006)' started by Jack87, Apr 29, 2023.
  1. Apr 29, 2023 at 1:36 PM
    Jack87
    Jack87 [OP] New Member
    Jack
    Denver, Co
    2001 White Tundra TRD AC Limited 4WD
    Pretty much stock
    I just noticed there's some rust forming just above the windshield.
    Is the anyway to fix this and/or keep it from getting any worse?
    w666 and Jack McCarthy like this.
  2. Apr 29, 2023 at 1:39 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’m in the same boat. You really have to remove the windshield to stop it. Hard to contain too. I don’t think there’s a easy answer.
  3. Apr 29, 2023 at 2:51 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    I had a 2003 Super Duty 7.3. Had the windshield replaced, when the guy popped out the windshield it was so rusted that there wasn't much good metal to glue the windshield to. There was no visible rust before pulling the windshield. I loved the "big truck" with the 7.3 but it was so bad that I sold it. That's when I got my gen 1 tundra. I love my tundra but I sure miss having a real HD truck. I suggest removing the windshield and see what you have to work with
    Jack87[OP], N84434 and scooterprint like this.
  4. Apr 29, 2023 at 3:39 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Good suggestion. See what you're up against and you'll be able to clean/treat/paint the areas much easier.
  5. Apr 29, 2023 at 4:21 PM
    Jack87
    Jack
    Denver, Co
    Pretty much stock
    Thanks all I guess removing the windshield is the first start.
    I'm assuming previous owner had windshield replaced at some point and perhaps person replacing it scratched up the pain when removing the old one.
    Kimosabe and N84434 like this.
  6. Apr 29, 2023 at 4:28 PM
    Jack McCarthy
    Bill
    North of Boston
    Post pics if you can of the carnage with the windshield removed. I’m curious how bad mine might be as well.
  7. Apr 29, 2023 at 5:33 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Use some white duct tape until you get round 2 it !
  8. Apr 29, 2023 at 5:46 PM
    Jack McCarthy
    Bill
    North of Boston
    That actually makes it worse corrosion wise since moisture gets trapped underneath.
    Jack87[OP] and BubbaW[QUOTED] like this.
  9. Apr 29, 2023 at 5:48 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Sorry, I forgot my tongue in cheek gif :rolleyes:
  10. May 2, 2023 at 7:50 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I think OPs post about a previous windshield job being responsible is correct. I had some of this happening on my old T4R. Unfortunately it will be hard to tell the extent until you pull the windshield.
    I think it’s hit or miss because the truth is, water is getting between them and is corroding the metal causing corrosion.
    You could get lucky like I did, and it was primarily surface rust and the guy wire wheeled it, coated it with some epoxy rust inhibitor and then replaced the windshield good as new. I hope that’s the case, but try and take it to a reputable shop or get lucky with someone from safelight that knows what they’re doing. Fingers crossed.
    Jack87[OP] and shifty` like this.
  11. May 3, 2023 at 5:07 AM
    Jack McCarthy
    Bill
    North of Boston
    I KNOW for a fact it's from a bad install. It's the ONLY place on my truck that rusted exterior wise and the windshield has been replaced 3 times. Once by a local place and twice by Giant which now no longer exists. I only wish I could prove that fact since it's costly to fix. Getting a known person to replace it seems like an act of God since they just appear to randomly dispatch people to fix it.
    Jack87[OP] likes this.
  12. May 3, 2023 at 5:25 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Have had mine replaced by Jack Morris 2 times in 14 yrs and fortunately neither jobs have resulted in rust of any kind.
  13. May 3, 2023 at 11:46 AM
    Jack McCarthy
    Bill
    North of Boston
    The rust on mine didn't show up until 13 years after it was last changed. I don't know if it's been that long for you. They however did use an el cheapo gasket to replace the existing OEM one at the top of the windshield. I'm not sure if that made a big difference or not.
  14. May 3, 2023 at 11:47 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    The first was soon after I got it in 2009 and the most recent was this past Nov.
    Don’t know if it matters but you and I live in totally different environments from each other
  15. May 3, 2023 at 4:39 PM
    Jack87
    Jack
    Denver, Co
    Pretty much stock
    Yeah! I'm almost tempted to take the job in myself as I don't trust anyone else. Besides the windshield is totally fine! Unless I break it attempting to remove it haha.
    I know nothing about auto body work but I guess this is an opportunity to learn a new skill.
  16. May 4, 2023 at 4:45 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Easy for me to say but it does not appear to be that diifcult, simply time consuming with a bit of patience.
    2004 Tundra should be close for a 2001....
    Unless you have already dealt with possible windshield cowl issues, I would suggest looking in that area for areas to address before you start windshield project in case you have to replace clips and what not.
    some items you may need....
    Cowl clips: 90080-18055
    Cowl push pin: 904670-704522
    White receiver: 90467-08184
  17. May 4, 2023 at 6:12 AM
    WalnutWest
    WalnutWest New Member
    2019 LIMITED CREWMAX MGM
    Have a professional remove the windshield and wire brush that lip IMMEDIATELY - do not let it progress any further - If it doesn't already, it'll be leaking water soon...
  18. May 4, 2023 at 7:01 AM
    Warreng
    Warreng New Member
    i repaired my gen1 windshield rust.
    Glass company came to my house and removed windshield in my garage.
    I then took my time taping everything closed, bit of grinding (know when to stop as you can thin the metal really fast), lots of sandblasting (cheap $20 blaster), some JB weld to fix the holes, por15 the bare metal, 2 part epoxy Endura colour matched paint to finish in a Preval sprayer (look it up they are awesome), then glass co came back and put shield back in. Probably cost me $300.
    Was my first real paint/rust repair and it turned out pretty damn good.
