S mode
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ilovemytundra38901, May 31, 2019.
  1. May 31, 2019 at 6:32 PM
    Ilovemytundra38901
    Ilovemytundra38901 [OP] New Member
    I apologize in advance for probably asking really dumb questions here.
    So the S mode. I've searched around trying to find info on it and haven't really succeeded. What in the bloody heck is this for? Should I be using this when off road in muddy conditions and keeping it in low gear? Should I be using it while towing etc? I assume it doesn't stand for standard because there's no clutch for shifting up and down? So that tells me that I should be able to shift up and down gears while driving on the highway without destroying my transmission (I'm terrified of trying this lol)
    Again sorry for what is probably really dumb questions but I like to learn and ask questions so thanks for your time!
  2. May 31, 2019 at 6:34 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It’s generally used for towing. It is sequential shifting. You don’t want to drive over 5th gear while towing heavy loads, so using this shifter prevents the transmission from going into 5th and 6th.
    OhEmmBee, Newm and CaptSpaulding like this.
  3. May 31, 2019 at 6:36 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s for whatever you want! All it does is limit your transmission to the gear you selected. It always starts off at 4. It will work like a regular automatic transmission but limit itself to whatever gear you selected. I like to use it out on the highway if I’m going up a long grade and the transmission is hunting to stay in the proper gear. That way I’m not heating up the clutches in the transmission. It’s also nice for going downhill so you can use the brakes less. Really nothing scary about it.
    Also for towing.
  4. May 31, 2019 at 6:38 PM
    Ilovemytundra38901
    Ok so I can shift between gears while the truck is moving and not damage anything right. Obviously switching it to first while going 65 is a terrible idea.
  5. May 31, 2019 at 6:39 PM
    Ilovemytundra38901
    What would you consider a "heavy load"
  6. May 31, 2019 at 6:40 PM
    Danman34
    Danman34 New Member
    Danny
    Yes. You can upshift and downshift while normal driving. But holding lower gears will cause excessive heat to build up
  7. May 31, 2019 at 6:41 PM
    Danman34
    Danman34 New Member
    Danny
    Ide say anything over 3-4K lbs. you’ll feel it if it’s hunting gears while cruising at speed.
  8. May 31, 2019 at 6:41 PM
    15whtrd
    15whtrd Mr. Blonde
    It won’t let you. It will beep at you lol. As soon as you slow down enough it will go into it though LOL. Try it next time you go for a drive go directly to S. Drive as normal. If you put it in sixth it will act exactly the way it does in D.
  9. May 31, 2019 at 6:42 PM
    Ilovemytundra38901
    Ok thanks for the info! I feel a little more comfortable about it now.
    15whtrd[QUOTED] likes this.
  10. May 31, 2019 at 6:46 PM
    Marty McFly
    Morty McBoonJug
    So where did we stand on shifting to reverse on the hwy to kick on the back up camera LOL
    I still don’t have the balls to try that :rofl:
  11. May 31, 2019 at 6:47 PM
    Ilovemytundra38901
    Lolololol gotta slap it into race
    Marty McFly[QUOTED] likes this.
  12. May 31, 2019 at 6:52 PM
    15whtrd
    15whtrd Mr. Blonde
    https://youtu.be/Nj9Gpu_SUpY
    This video is pretty informing for someone who doesn’t know what’s going on. He reviews it as a person who doesn’t know himself. He actually irritates the crap out of me but you should learn something from it. LOL
    KnuckleHD and Marty McFly like this.
  13. May 31, 2019 at 6:52 PM
    15whtrd
    15whtrd Mr. Blonde
    No thanks haha!
  14. May 31, 2019 at 6:53 PM
    Ilovemytundra38901
    He looks just like the guy I just checked in at my hotel that raged at me for asking to see his id lol....
  15. May 31, 2019 at 6:54 PM
    15whtrd
    15whtrd Mr. Blonde
  16. May 31, 2019 at 6:56 PM
    Danman34
    Danman34 New Member
    Danny
    Slaps it in “Sport” mode and doesn’t understand why it starts him in 4th? Obviously this guy has no clue what he’s talking about when he thinks it’s a “Sport” mode in a 6000lb truck lol.
  17. May 31, 2019 at 6:59 PM
    15whtrd
    15whtrd Mr. Blonde
    Inkr!!! Hahaha
    Danman34[QUOTED] likes this.
  18. May 31, 2019 at 6:59 PM
    Danman34
    Danman34 New Member
    Danny
    It’s actually Sequential shifting mode and it’s intended purpose is for heavy towing when you do not want the transmission going into 5th and 6th which are less than 1:1 gears and will cause excessive heat in the clutch and fluid from gear hunting
    15whtrd likes this.
  19. May 31, 2019 at 7:07 PM
    Ilovemytundra38901
    So I guess the guy in the video doesn't understand that the feature is not to turn your truck into a manual but instead meant to keep you from going over the gear you are currently have it set in.
  20. May 31, 2019 at 7:09 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Alright then I took my post down
    I stand corrected!
    Are u telling me I should only use when towing?
    I came from an 7.3 F250 with 37’s before my Tundra- I thought using “S” mode was like/ same as using the overdrive “off” button around town on that truck?
    It keep tranny from excessive shifting in and out of overdrive around town!
  21. May 31, 2019 at 7:17 PM
    Danman34
    Danman34 New Member
    Danny
    No, you can use it whenever you want. It’s just like you said, a mode for you to select what final gear you want the transmission to shift too. You can use it around town. But it’s sequential, which by definition means “forming or following in a logical order or sequence” since you can only go up or down one gear from where you select, speed and rpm dependent. Guys with bigger tires use it for the same purpose since you lose gear with the bigger tires and the transmission wants to start hunting on the freeway. I like to use it when I’m in heavy traffic. That way if I need to get in and out or merge I can basically keep it in the powerband.
    buckeye74 likes this.
  22. May 31, 2019 at 7:21 PM
    Midnite72
    Bill
    Northern MD
    18 SR 5.7 4x4
    Gotcha- all good
  23. May 31, 2019 at 7:46 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    So besides using tow mode I should be using the S mode to haul a 5000-5500 boat?
  24. Jun 3, 2019 at 9:35 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    I am in "S" mode and TOW/HAUL 99% of the time I drive my Tundra. It is excellent for managing the pace in stop-and-go traffic and is very effective in using engine braking when descending a slight downgrade. One can downshift when the cruise is on (especially during adaptive cruise when the traffic slows a bit and you are in 6th at about 1,500 rpm, downshift to 5th and bring the revs up to quiet things down in the cab). I typically drive looking way ahead and when I see the traffic slowing up ahead, I begin downshifting to slow down. Driving in this manner in traffic, I hardly use my brakes unless something changes more rapidly (not very common on my commute).
    I can't remember the last time I used "D" mode.
    CMB, DM 2018 Tundra and Black Wolf like this.
  25. Jun 3, 2019 at 9:44 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Every time I hear "Sport Mode" :smack::facepalm::laugh:
    Newm and Black Wolf like this.
  26. Jun 3, 2019 at 9:59 AM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    It stands for sport mode when you drive a super white tundra ;)
    RBDTx and Black Wolf like this.
  27. Jun 3, 2019 at 10:00 AM
    I call it "I'm in control again shift mode".
    :burnrubber:
  28. Jun 3, 2019 at 10:07 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I have actually never really used this even when towing the Jeep. Maybe I should but I haven't found that need yet.
    TacoWuzzaTurd likes this.
  29. Jun 6, 2019 at 7:37 AM
    Geeoff
    Geeoff New Member
    NH
    2016 CrewMax SR5 TRD
    I have been trying S mode on my commute and have a question. Is driving in S mode 6th gear equivalent to driving in D?
  30. Jun 6, 2019 at 7:40 AM
    15whtrd
    15whtrd Mr. Blonde
    To me it feels exactly the same
