Sagging door
Discussion in '1st Gen Tundras (2000-2006)' started by growit, Oct 17, 2023.
  1. Oct 17, 2023 at 12:18 PM
    growit
    growit [OP] New Member
    2006 Dbcb SR5
    I have a 2006 dbc with 340k miles on it. The driver side door is slightly sagging, not sure if it’s the body mounts or if there’s a hinge adjustment. Any suggestions is appreciated. Thanks IMG_1685.jpg
  2. Oct 17, 2023 at 12:21 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I need to do this too, there are a couple of YouTube videos using new pins and bushings from doorman I believe. It requires you to cut the tops off your current pins to pound them out/thru
  3. Oct 17, 2023 at 1:00 PM
    growit
    2006 Dbcb SR5
    French Toasty are you referring to the body mounts?
  4. Oct 17, 2023 at 1:44 PM
    FrenchToasty
    Mo
    Bone stock
  5. Oct 17, 2023 at 1:54 PM
    growit
    2006 Dbcb SR5
    Thanks Frenchy
    FrenchToasty likes this.
  6. Oct 18, 2023 at 7:39 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    Mine is doing this too. Is it easier to just replace the hinges?
  7. Oct 18, 2023 at 8:45 AM
    Hinges are welded on @ the body.
    1st thing to do is see if it's actually your problem. Open the door and have a helper lift up at the bottom corner of the door (latch side) while you watch for play in the hinge. After the GMT400s and GMT800 pickups I owned, which have absurdly heavy doors (esp. the GMT400/'88-'98!), I can tell you, you'll know immediately if the hinge pins are your problem when doing this. You'll have at least 3/4" - 1-1/2" of play in the door up-down.
    If it's not the hinge pins, some body shops - right or wrong! - will use a 2x4 to bend/tweak the door into the correct line. This is not uncommon after wrecks, or incidents with a "dooring" incident, like, opening a door into oncoming cyclist/vehiclular traffic/wind event/non-moving objects, like the unfortunate crap @empty_lord had happen a while back. Some dudes I've seen will throw a floor jack under the door with a cradle and progressively jack the door up until it's right, but ... I wouldn't personally go with either route.
    I don't agree with this dude's methods either, just sayin'. Surely there's a better way.
    This is also a good time to check your door checks up front to make sure they haven't ripped thru the metal at the door shell itself (This is NOT a video!):
  8. Oct 18, 2023 at 8:51 AM
    Actually, looks like this guy shows the same method, generally. Maybe that is easiest. I like his approach better.
    However, I'd just add: Remove the door totally. The door wire harness should unplug (via 2 connectors) behind the kick panel. Pop those two connectors off, detach the grommet, and with someone (or a jack) holding the door up, unbolt the door from the hinge, put it to the side. Then pop the pins out.
    Dorman has a couple of kits across the years; I'd search up the compatible part at their site.
    MacNhangin likes this.
  9. Oct 18, 2023 at 8:54 AM
  10. Oct 18, 2023 at 9:03 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
