Scangauge II vs III
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, May 6, 2024.
  1. May 6, 2024 at 8:41 AM
    SDHNTR
    SDHNTR [OP] New Member
    Anybody used both on a 3rd gen? I have found out the hard way I need to be monitoring my trans temps. It looks like the version II will do it, but with some annoying looking numeric code input and some potential trial and error to find a code that works. The version 3 appears to be truly plug and play, plug it in and the trans temp will come up with no tinkering, but the screen is so much bigger and obtrusive, and it's more expensive. Is that essentially the long and short of it? Has anybody had both? Preferences? Has anybody found a place to mount the III without obstructing the view out the window or mounted it anywhere else it doesn't get in the way? Thanks.
  2. May 6, 2024 at 10:10 AM
    raylo
    raylo not so new member
    Frederick, MD
    I haven't used the SG3 but the 2 works perfectly and mounts right on top of the steering column. I have been using one for years to monitor trans temp on my Tacoma and now Tundra. Entering the xgauge code for TFT isn't that hard and we know what the correct one is (need to find the other thread) and is only a one-time thing. That works like way old school texting from a phone number pad. Awkward, but takes only a few minutes.
    Edit: there is only one trans PID in our Tundras, and IIRC the code that works is the first one in this table:
    » TOYOTA – LEXUS – SCION (scangauge.com)
  3. May 6, 2024 at 10:20 AM
    mass-hole
    mass-hole New Member
    Why not just get a bluetooth adapter and OBDFusion or Torque Pro on your phone?
    Toyota people are the only people I have seen that run ScanGauges lol.
  4. May 6, 2024 at 10:23 AM
    raylo
    Frederick, MD
    Because it reads in real time, comes on with the ignition, and you don't need to futz with your phone or an app.
  5. May 6, 2024 at 10:24 AM
    SDHNTR
    You'll have to decode that for me. I rode the shortbus to technology school. What Bluetooth adapter and what's OBD Fusion or Torque Pro? Some app? I need simple steps in simple English, please.
    When it comes to vehicles, I struggle with tech. It' a tool, I just want it to work and do the job. I don't want to fight techy stuff.
  6. May 6, 2024 at 10:34 AM
    mass-hole
    Just get a scan gauge I guess then.
  7. May 6, 2024 at 10:36 AM
    mass-hole
    Dang, and for only $270!
  8. May 6, 2024 at 10:38 AM
    raylo
    Frederick, MD
    Nope, ~$150. And my SG2 is 10 years old so that cost has been well amortized. ;-)
    2mchfun likes this.
  9. May 6, 2024 at 11:00 AM
    SDHNTR
    Hold on here, if there's an app or something that doesn't involve a separate screen or gadget I have to mount somewhere, I want to know about it. I'm sincere when I say I'd appreciate a dumbed down how-to on this.
  10. May 6, 2024 at 11:26 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Go big or go home. It just works.
    BDATundra, CringyDad and 2mchfun like this.
  11. May 6, 2024 at 11:44 AM
    SDHNTR
    Can Carista read trans temp? Or use it somehow with some other app? I already have that thingy (to disable the seatbelt chime and fake engine noise)
    xwarcat likes this.
  12. May 6, 2024 at 12:21 PM
    DRP
    DRP Old Member
    Dave
    Carista cannot read the trans Temps from their app but I do use their dongle with the Car Scanner app and that does work.
  13. May 6, 2024 at 12:45 PM
    SDHNTR
    Pardon my ignorance. So you plug the dongle in, and have to leave it plugged in, and then use the Car Scanner app on your phone to read the temps? And specifically which “Car Scanner” app? I see several.
  14. May 6, 2024 at 12:48 PM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Just know that ScanGague II if you need to have a firmware update flash, you have to send it back to them and pay a fee $25 (not sure if need to include return postage)
    ScanGague is OTA update, so no issues there, but price is steep.
  15. May 6, 2024 at 12:57 PM
    SD Surfer
    Bruce
    So Cal
    https://veepeak.com/
    OBD2 reader plugs in the OBD port under your dash.
    Fusion and Torque are apps that will display the gauges on your phone.
    I was going to get the Scangauge as I wanted a dedicated readout and didn't want to have to mess with my phone.
    I decided instead to upgrade the head unit in my truck to the big bitchen Kenwood that will display the gauges on the giant 10" screen.
    Not the most cost effective way to get the info, but certainly the coolest. :rofl:How's that one grab ya' Mass-Hole?
    oddhours and rideandfly like this.
  16. May 6, 2024 at 1:22 PM
    SDHNTR
    Thanks but since I already have a Carista, would like to figure out how to use it for this purpose.
  17. May 6, 2024 at 5:37 PM
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    I have the SGIII mounted just above the left vent equal with the grab handle. It's not in the view or obtrusive, but I am short so the seat is pretty far forward. I got it specifically for watching transmission temperature and completed a 5000 mile trip through the mountains in Idaho, Wyoming, Utah, and New Mexico and never saw transmission temperature higher than the coolant temp and the coolant was never above 200 and was generally between 185 and 195. Last fall we didn't some exploring in the central Idaho mountains, climbing on a gravel road 2000 feet in about 4 miles finishing with about a mile that required 4lo. Unfortunately I didn't have the SGIII at that time, but got no high transmission temp alarms.
    mrlittlejohn and raylo like this.
  18. Aug 6, 2024 at 9:15 PM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    I'm interested in seeing hybrid battery charging rates and when the friction brakes kick in. I can kind of sense a jump in intensity when I think the friction brakes kick in, but not sure. I'd like to maximize my recharging when slowing. Is there a unit that will do that?
    Tundrastruck91 likes this.
  19. Nov 20, 2024 at 8:53 PM
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    Any pictures of the install of the SG3? And what you used to mount it there with cable routing info?
    I got my gauge yesterday and am looking at how I am going to place it in my 22 Limited.
    Thanks in advance,
  20. Feb 22, 2025 at 9:22 PM
    Mr Rick
    Mr Rick New Member
    Anyone out there know if you can add engine oil temp to the Scangauge ll?
  21. Feb 23, 2025 at 5:35 AM
    raylo
    Frederick, MD
    Yes, you can. I have both trans and oil temps set up as 2 of the 4 primary monitors.
    Mr Rick[QUOTED] likes this.
