Scout Slide In Camper Suspension Recommend
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jvk, Sep 20, 2021.
  1. Sep 20, 2021 at 12:29 PM
    Jvk
    Jvk [OP] New Member
    Jvk
    2017 tundra limited
    I just put a down payment on a Scout Olympic slide in camper.
    Unfortunately, it wont be ready till next spring due to demand.
    Fortunately, that gives me enough time to upgrade my suspension to manage the weight.
    I estimate our total gear + camper to land a little shy of 2000 lbs.
    Any recommends on how best to manage this weight for Maine's north woods?
    My Tundra's a 2017 Limited 5.7 with tow package and 6.5 bed.
    Thanks JVK
  2. Sep 20, 2021 at 12:52 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    E rated tires and either air bags or a new leaf pack. If your limited has 20s I’d suggest down sizing to 18s and going with an LT275/70R18 tire.
  3. Sep 20, 2021 at 2:50 PM
    clarkritchie
    clarkritchie New Member
    Starting to see those more and more around town. They look dope! Congrats on the... downpayment.
  4. Sep 20, 2021 at 2:54 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome...
  5. Sep 20, 2021 at 4:58 PM
    2mchfun
    Dobinson's HD leaf packs, yellow sumo springs for bump stops, and HD roadmaster active suspension. I have this trio and it simply works well with 2400 lbs in the bed. Also have BDS traction bars to control axle wrap. Bilstein 5160 shocks w/ res. E Rated yokohama geo 15 tires.
  6. Nov 19, 2021 at 12:14 PM
    siestasnmotos
    siestasnmotos New Member
    2014 Tundra w/ Fox 2.5 Coilovers + Total Chaos UCAs
    Congratulations! We just picked up our Scout in OR a few weeks ago and love it. To answer your suspension question - it will really depend on how you are going to use it. At a minimum 10 ply, E Rated tires and some Ride-Rite Airbags (or something similar - E.g. 2mchfun has Sumo Springs). If the Scout is for occasional use + it's not too loaded down you might be happy w/ just that.
    I have a 2014 double cab 4x4 (under 1,400 lb payload) w/ BFG All Terrains, Total Chaos UCA's and Fox 2.5 coilovers w/ reservoirs (front), and Fox 2.0 w/ reservoirs + Ride-Rites & Daystar cradles (rear). The Tundra did fine from Portland to Southern CA w/ this combo. We did some light off-road the first week and again it handled fine.
    We just took the Tundra to Atlas Springs in LA and they added two leaf springs to each side... This was a game-changer. It went from handling "fine" to handling really well....silky. We have two speed bumps + a big drainage dip on our street. Going down our road before and after the new springs was REALLY noticeable. The trade-off is I imagine when I take the Scout off and hit those same speed bumps the rear end of my truck is going to handle like a brick! Jolt!!
    Pick up the Scout w/ good E-rated tires and some Airbags (easy to install yourself relatively cheap if you are a little mechanically inclined>>YouTube vids)... See how it handles. Think about taking it to a spring shop (e.g. Deaver, Atlas, etc) if you are going to leave the Scout on your truck full time. Just my $$.02 and experience so far - there are lots of ways to approach it.
    Let us know how it goes when you get it!
    HulkSmurf14 and mountainpete like this.
  7. Nov 20, 2021 at 6:47 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    e tires an Timbren on truck! hawk on back about 22,000 an smiles. lots of off roading! death valley,Mojave desert road Nez PIECE from Montana to IDAHO an much much more
  8. Nov 20, 2021 at 6:53 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Get your deposit back and put it down on a FWC. Unless you like being super top heavy and not actually capable...
    Sonicbluerider likes this.
