Secondary air injector pump problem
Discussion in 'General Tundra Discussion' started by Achapman2662, Jun 6, 2024.
  1. Jun 6, 2024 at 8:18 AM
    Achapman2662
    Achapman2662 [OP] New Member
    Anna
    2010 Tundra
    I have a 2010 tundra the only code it's throwing is the secondary air injection pump so I replaced both. After I got done fixing it, I test drove it ran great, the check engine light was off everything was good. I got in it this morning and now the lights are back on and it's doing the same thing it was doing before I replaced them, im fairly certain it's put itself back into limp mode. What else could possibly be the problem? Any help would be appreciated.
    mtucker likes this.
  2. Jun 6, 2024 at 10:26 AM
    art64
    art64 New Member
    Did you replace the Air Switching Valve? This maybe the culprit. What are the codes?
    2mchfun likes this.
  3. Jun 6, 2024 at 10:45 AM
    Achapman2662
    Anna
    2010 Tundra
    Also it is a 4.0 v6
  4. Jun 6, 2024 at 11:30 AM
    Achapman2662
    Anna
    2010 Tundra
    I disconnected the battery so now the check engine light is off.
  5. Jun 6, 2024 at 5:13 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    What are the codes?
  6. Jun 6, 2024 at 5:15 PM
    Achapman2662
    Anna
    2010 Tundra
    I took the cable off the negative on the battery the lights went off. Hopefully by doing that it might have reset.
  7. Jun 6, 2024 at 5:35 PM
    Orions Dad
    2007 Tundra 4.7L
    Did you scan for codes before disconnecting the battery?
  8. Jun 6, 2024 at 5:36 PM
    Achapman2662
    Anna
    2010 Tundra
    No. I honestly didn't think that would work so unfortunately I did not scan before disconnecting.
  9. Jun 6, 2024 at 5:44 PM
    Orions Dad
    2007 Tundra 4.7L
    I am guessing you scanned the codes initially to know the air pumps were bad and you got a 2nd CEL that you assumed was the same problem there is a good chance you had a different problem ( possibly the valves). By disconnecting the battery it may have gotten rid the code temporarily I would expect the code to come back
    whenever I get a CEL I scan it every time don’t assume
  10. Jun 6, 2024 at 6:09 PM
    Achapman2662
    Anna
    2010 Tundra
    That's what I'm thinking also, as soon as it comes on I'll put my scanner on it. And I'll post here again. But when I first scanned it was only throwing that code for the pumps.
  11. Jun 7, 2024 at 8:38 AM
    Achapman2662
    Anna
    2010 Tundra
    CEL came on again now its saying 101, 441, and still 2440. And the 2440 are the pumps I just replaced.
  12. Jun 7, 2024 at 10:31 AM
    Orions Dad
    2007 Tundra 4.7L
    P2440 is the air injection valve bank 1 ( driver side). If you change 1 side I would do the other
    P101 is your Mass Air Flow sensor( check the connection and remove from air tube and clean with Mass Air Flow sensor cleaner if that doesn’t fix it you would need to replace
    P0441 is the evap system most common reason is your gas cap either replace or make sure it’s on tight
    Mdl likes this.
  13. Jun 8, 2024 at 9:12 AM
    Achapman2662
    Anna
    2010 Tundra
    I replaced both, and at first the 2440 was the only code being thrown and now the others are throwing on top of 2440. Is it possible the truck isn't reading that they are new?
  14. Jun 8, 2024 at 10:21 AM
    Orions Dad
    2007 Tundra 4.7L
    You had said you earlier that you replaced the pumps, the pumps and valves are 2 completely different parts. The other 2 codes are unrelated to the SAIS
  15. Jul 12, 2024 at 10:31 AM
    Achapman2662
    Anna
    2010 Tundra
    OK see, I didn't realize that. So the code is the exact same code. I think it's 2440. So when it threw that code, I replaced the secondary air injector pumps. Once that got done, it's still saying and doing the exact same thing, so with that being said. It says bank one is still stuck open. So did i replace the correct part? But I didn't replace everything dealing with that code.?
  16. Jul 12, 2024 at 11:17 AM
    Orions Dad
    2007 Tundra 4.7L
    Correct. You needed to replace the switching valve Bank 1 which is the drivers side. In your case the valve is stuck open
