Secondary Air pump - 2013 4.6L
Discussion in '2nd Gen Tundras (2007-2013)' started by B_Wall, Feb 16, 2022.
  1. Feb 16, 2022 at 8:45 AM
    B_Wall
    B_Wall [OP] New Member
    Brendan
    2013 Tundra 4.6
    About 4 weeks ago I had my check engine, Traction control, and 4LO lights come on. The truck threw code p2440. I replaced the Bank 1 check valve and truck has run fine since. Yesterday we had a really cold day and while idling the check engine came back on. Code p2445 popped saying Bank1 Sec Air pump stuck
    Are bank1 and bank2 the same pumps? I was planning to just replace both while I’m down there. Also, can someone recommend a brand to get? Toyota has the pumps for like $400/each but I see different brands online with prices all over the map. Thanks
    Silverghost and Cg13055 like this.
  2. Feb 16, 2022 at 12:25 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    If you can install a bypass and be done with it, do it. No use in fooling around with these janky systems. I understand emissions testing may exclude it but.....
  3. Feb 16, 2022 at 12:34 PM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    this^^^, also the pumps are known for failing more than once in short time.
  4. Feb 18, 2022 at 7:41 PM
    B_Wall
    Brendan
    2013 Tundra 4.6
    I think I’m sold on the Hewitt Tech Bypass. I live in the northeast and it gets pretty cold up here in the winter. Any known issues with the bypass with the freezing temps?
    HewittTech01 likes this.
  5. Feb 23, 2022 at 8:46 AM
    Jaymohn
    Jaymohn New Member
    I have the Bypass and it works pretty good. I do get the secondary code and have to clear the check engine light so I keep a scanner handing in the glovebox. No problems due to cold weather.
  6. Oct 5, 2022 at 7:11 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @Jaymohn We appreciate you recommending the HT SAIS Bypass Kit. @B_Wall If you have any question do not hesitate to DM or give us a call. Also wanted to provide some additional resource.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
  7. Dec 30, 2024 at 9:32 PM
    TundrAZ86
    TundrAZ86 New Member
    2010 Tundra 4.6 SR5 4x4
    @Jaymohn moto I'm looking into the Hewitt, did you install a seperate Pressure sensor option with your hewitt? It's an extra $200 but might take care of that code if the switch was damaged before the install.
  8. Dec 31, 2024 at 12:59 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I installed the 2.0 kit and the extra dongles to replicate the connection to the engine. No issues in 18 months. When I am checking error codes there is occasionally a pending code for the AIP but it clears before it becomes a permanent code. I also removed all the actual AIP equipment and the ECU doesn't care due to the Hewitt kit. The thing I noticed right away is how quiet the Tundra is after you turn it off or on (since there are no vacuum pumps running).
