Secondary Air Pump Relay Failure
Discussion in '2nd Gen Tundras (2007-2013)' started by 2011_Tundra, Aug 18, 2022.
  1. Aug 18, 2022 at 2:31 PM
    2011_Tundra
    2011_Tundra [OP] New Member
    So, I got the secondary Air Pump Relay Failure error on my 2011 4.6L truck yesterday. I hooked up my reader and I had two codes, P0418 and P2445. The first one was that the relay had failed. I started my search for the relay and information on here. What I found here is not encouraging as far getting Toyota to cover the expense. Before I start replacing the Air Pumps, I figured replace the relays first. So, after searching here, the manual, looking at the fuse box under the hood I cannot locate a relay. Where I find that it is supposed to be is empty or not there inside the fuse box.
    I am hoping that someone on here can help me find the relay and get some suggestions on replacing the air pumps.
    TIA.
  2. Aug 18, 2022 at 2:34 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    look into Hewitt Tech Gen 2 Secondary Air injection Bypass kit
    HewittTech01 and Jeff_1974 like this.
  3. Aug 18, 2022 at 2:43 PM
    2011_Tundra
    Thanks, I will take a look at that. My understanding is that if the truck has been flashed, don't recall the correct term, that I cannot do this. I am not sure how to find out if the truck has been flashed or not. Thanks though I will check that out.
  4. Sep 28, 2022 at 8:13 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @frichco228 We appreciate your recommendation. @2011_Tundra I wanted to provide some information about the Gen 2 Bypass Kit. Please note that it is compatible with with Toyota's Most recent flashes.
    Gen 2 kit emulates the operation of the SAIS and ECM reads as Ready/Completed. It also eliminates all trouble codes dealing with the SAIS with the exception of the pressure sensor. Installs at the Air Injection Driver and Air Switching Valves.
    + Covers both mechanical and Electrical SAIS error codes
    + Compatible with Toyota's current ECM Computer flash
    + Compatible with Flex Fuel Modes
    + Clears permanent codes
    The only codes it would not address is any related to damaged pressures sensor. If you had a damaged pressure sensor then a kit addon would be required. That said, the Gen 2 Bypass Kit and two Pressure Sensor addon would be a full delete kit of the SAIS. The only thing we require in good working condition after installation of the full delete kit is the Vehicle’s Factory Wiring and ECM. I have also included a link to a thread providing more details about the Gen 1 & Gen 2 Bypass kits.
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
