Seeing Spots
Discussion in 'Detailing' started by TILLY, Jun 2, 2020.
  1. Jun 2, 2020 at 7:07 PM
    TILLY
    TILLY [OP] Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Did a quick rinse on the truck today and noticed some nasty water spots i never noticed before under the wax/Beadmaker. Whats the best way to safely remove what i have on there, so i can remove the spots? Would a clay-mitten remove all the wax without harming the factory clear-coat, or is there a better way?....Thanks.
    You can see the spots in the mid to lower right side of my pic, if you squint just right. :)IMG_0878.jpg
  2. Jun 3, 2020 at 10:23 AM
    TILLY
    Massachusetts
    Anyone? :notsure:
  3. Jun 3, 2020 at 11:32 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Sorry, I thought that was the glass at first so I wrote something dumb.
    I'm not big into detailing but I did want to strip my Tundra before polishing and waxing.
    In the past I always used Dawn dish soap. People told me it's too harsh, though I never saw a problem with it.
    I bought some of this, works about the same.
    https://www.amazon.com/Adams-Strip-Wash-16oz-Contaminants/dp/B077KDC4D6
    TILLY[OP] likes this.
  4. Jun 3, 2020 at 11:34 AM
    19TurdPro
    2019 Tundra TRD Pro
    But yes, a clay bar is designed to do just that, strip the surface without harming the clear coat.
  5. Jun 3, 2020 at 11:48 AM
    Grumpy Uncle
    Pat
    CO
    Meguiars Scratch X 2.0. I used this a couple of weeks ago for bird poo stains/marks and water stains. Worked pretty good for me.
  6. Jun 3, 2020 at 6:16 PM
    TILLY
    Massachusetts
    Thanks for the suggestions, it really helped. :hattip: Wanted to try to get this done today since i had the day off, and it wasn't going to rain. My local hardware store had very little product to choose from, but it did have the Meguiar's Grumpy suggested. After washing the hood off with some hot water and Dawn, i think it may have removed some/most of the bead maker i had on there. A little buffing took the stains right out and now looks brand new....Thanks again. :thumbsup:
  7. Jun 4, 2020 at 11:27 AM
    ccheezy
    ccheezy New Member
    North Carolina
    2020 CrewMax Limited
    "What are you hauling there son?" "ass"
    I'd go clay bar as well. It's the only way to get the windows perfect and I assume that would apply to the paint as well.
  8. Jun 4, 2020 at 1:04 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Belt Sander.
  9. Jun 5, 2020 at 5:29 AM
    War Machine
    War Machine SSEM # 5 3MW
    A clay mitt will usually get it off, but I’ve had to step it up on occasion. I haven’t tried Scratch X for that purpose, but it’s definitely a good product. Glad it worked! You’ll need to reapply your Beadmaker though. I’ve heard Dawn will strip pretty much any protection off, and the Scratch X definitely did.
    TILLY[QUOTED][OP] likes this.
  10. Jun 5, 2020 at 7:58 PM
    briarpatch
    briarpatch New Member
    Never used Scatch-X. What I'm seeing in those pics are the first level of water spots....largely topical and have not etched at all. I'm a big BeadMaker fan, largely for the stupd gloss and slickness it gives you. I am, however, starting to question it's ability to protect.
  11. Jun 5, 2020 at 8:10 PM
    TILLY
    Massachusetts
    I'm thinking this was my fault and not the bead makers. I didn't have this problem on any of the other paint except for the hood, and a little on the cab roof. It was definitely underneath because i couldn't just clean it off the Bead Maker. I think i might have rushed the application before i had the truck completely dry?..:facepalm:Not sure.
  12. Jun 5, 2020 at 8:28 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I just use wax if I notice to many spots. If there isn’t many the Bead Maker gets what we miss when drying, after we dry we go back and use the BMaker. Or I reckon you can Use a very fine rubbing compound then wax then use bead maker. On small scratches and water spots I have also used rubbing compound on a damp micro towel then the wax and then bead maker
