Separating the under hood Fuse/Relay Box - Add Relay or___?
Discussion in '2nd Gen Tundras (2007-2013)' started by Dalandshark, Nov 19, 2020.
  1. Nov 19, 2020 at 8:42 PM
    Dalandshark
    Dalandshark [OP] Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    My goal was to have my Air Injection Pump bypass relay integrated into the factory box.
    **Note: that taking apart this box can cause wiring issues if you are not careful and it will be noticeable to a tech if your under warranty.**
    I made the referenced metal clip of 26 gauge sheet metal, folded in half.
    You will need to insert the metal clips into each of the plastic clip connectors which will allow you to keep them released and separate the top of the box from the bottom of it. I cut the wires off of an unused relay socket and shrink wrapped them together for storage.
    Obviously, you will need an unused relay socket to do this. It might be easier to procure one of these sockets and insert the appropriate wire sizes into the terminals beforehand, rather than cutting existing wires from an unused socket.
    Its difficult, but you can get new cable ties on once it's put back together.
    The End.
  2. Oct 12, 2023 at 2:17 PM
    tillerman23
    tillerman23 New Member
    Gabe
    2007 Tundra 5.7L
    Very helpful photos. How did you get to the back cable tie? I can't reach it and not sure how to cut it.
    I am attempting to replace the fuse link block and have to get the box seperated to access the second 10mm bolt. Any ideas?
  3. Jan 4, 2024 at 9:58 PM
    EasyMoney
    EasyMoney New Member
    Jared
    2021 Tundra Platinum - Build in process
    5.29 gears. E-lockers front/rear
    Awesome idea to run aux circuits through the OEM box. Didnt realize until today that there were so many unused slots.
    Were you able to find part numbers for the micro relay socket and mini relay sockets? What terminal type do the backside of the sockets have?
  4. Jan 6, 2024 at 9:02 AM
    Dalandshark
    Northwest
    Eibach Level LIft
  5. Jan 6, 2024 at 10:59 AM
    EasyMoney
    Jared
    Sorry by “terminals” I mean the plastic retainer thing that houses the spades. It looks like those retainers are modular: my fuse box has both Bosch and micro relay retainers with the same outline. If I knew what those part numbers are, I could simply order more and create additional circuits. Do you have those PNs?
    Also, few days ago I purchased a junk yard matching fuse box. I’m going to pull parts from that fuse box and install onto mine (or attempt it) when it arrives next week. Could make for the cleanest tundra wire job
  6. Jan 6, 2024 at 11:43 AM
    Dalandshark
    Northwest
    Eibach Level LIft
    I don’t know because I just reused an existing one, sorry. I think you are right though, they appear to be pretty generic.
