Sequoia A/C Blower Motor Upgrade - 100% worth it
Discussion in '2.5 Gen Tundras (2014-2021)' started by BoatBroker, Oct 2, 2024.
  1. Oct 2, 2024 at 6:09 AM
    BoatBroker
    BoatBroker [OP] New Member
    Sarasota, Florida
    2016 Tundra SR5
    I did the Sequoia part number which is a brushless motor and puts out more volume at the highest setting. This will be my 4th blower motor in 8 years. The bearing starts to go and you get a tick. I'm hoping this upgrade fixes it for more than 2 years.
    Here is a short youtube video with details and part numbers. Highly recommend if you live in a hot/humid climate
    https://youtu.be/zQNXuWj44xw
  2. Oct 2, 2024 at 6:16 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Mine should be here any day now.
  3. Oct 2, 2024 at 7:29 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Rock Auto has a blower for 76 bones and the housing looks IDENTICAL to the black stock blower from your video. Ironically, they advertise this motor as brushless as well. I do agree the fan output in CFM in these Tundra sucks. Someone should do a cfm test before and after blower replacement
  4. Oct 2, 2024 at 7:34 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Circling back to this, the fan output in my 2001 Sequoia will blow your hair off. As will, the blower in the wife’s Lexus. She drives the Tundra and asks me how to turn the blower speed up and it already was maxed out.
  5. Oct 2, 2024 at 7:44 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Sequoia blower motor part number is 87103-0C051. The wiring connector would require mod if this motor used in a Tundra due to power wires being swapped. @e30cabrio documented this issue.
    87103-60481 and 87103-60560 are the Land Cruiser part numbers that are plug and play in a Tundra.
    Video refers to the blower upgrade as Sequoia, but he correctly uses the Land Cruiser blower motor instead (best option since no modification required).
  6. Oct 2, 2024 at 7:47 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Either way, if the new blower has the same CFM rating, I won’t waste my time changing it.
  7. Oct 2, 2024 at 7:50 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    There is another thread where some have found an increase in air flow.
    I think of these alternate parts as what to use when or if the original motor bites the dust.
  8. Oct 2, 2024 at 8:18 AM
    seydou
    seydou Distinguished Member
    I know someone else did a pre/post measurement but this is the most recent. Looks like at least +10% air flow.
    HVAC blower fan upgrade
  9. Oct 2, 2024 at 8:25 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Super cool. Thanks for the info. Looks like it would be worth it.
  10. Oct 2, 2024 at 8:28 AM
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    Alpharex tails, RC nerf steps, TRD Pro rear sway, Klearz 3rd brake smoked lense
    A 10% gain would be worth the swap
  11. Oct 2, 2024 at 8:31 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Absolutely
