Sequoia auto rear window switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by Toe404, Dec 8, 2022.
  1. Dec 8, 2022 at 11:13 PM
    Toe404
    Toe404 [OP] just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    Has anyone swapped in an auto up/down rear window switch out of a sequoia? I’d be curious to know if it’s compatible with gen 2.5 tundra
    Tundra2Yak likes this.
  2. Dec 9, 2022 at 10:01 AM
    Toe404
    Tomas
    Concord ,CA
    Just ordered one off eBay so I’ll let you guys know…
  3. Dec 9, 2022 at 10:27 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    :popcorn:
  4. Dec 9, 2022 at 2:02 PM
    Toe404
    Tomas
    Concord ,CA
    Looked up the wiring diagram for the connector for the 21 tundra and the 2013 sequoia that this switch came out of and the connector is the same, hopefully it’s plug and play, so as long as the pin orientation didn’t change then we should be in business!
    AGSport likes this.
  5. Dec 9, 2022 at 2:22 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My 2010 SR5 Tundra has the same switch as my 2013 Sequoia.
  6. Dec 9, 2022 at 6:29 PM
    Billy Swamp
    Billy Swamp New Member
    Ben
    Seminole County, FL
    2014 CM Magnetic Platinum 4x4 Tundra
    7" pro-comp, 35" tires, fuel assault rims, Amp Research power steps, JRT system
    I've been curious about this as well. My wife's 13 platinum Sequoia has this switch and wondered if it would work in my 14 tundra. Please let us know!
  7. Dec 9, 2022 at 7:44 PM
    Toe404
    Tomas
    Concord ,CA
    I was chatting with my foreman and he was looking over the wiring diagram and he said it might not work because the sequoia has a body control ecu in the rear hatch that the rear window switch communicates with. We talked about how the body control ecu is in the hatch more than likely to handle the rear wiper, lift actuators for the hatch and the key control for the rear window roll down feature. The more we looked at the wiring diagram the less sure we were about the Body control handling the auto up/down feature.
    I showed him the aftermarket auto window switches that you can get which eludes to the fact that the auto up/down is a feature of the switch and not the body control ecu.
    not to mention the sequoia auto up/down switch cost damn near 300 dollars, while the tundra switch cost about 70 bucks. I’m assuming the sequoia switch has some sort of two-stage button and or an integrated relay.
    I have high hopes this will work, 65 dollar used switch from eBay should arrive next week so stay tuned!
    Billy Swamp likes this.
  8. Dec 9, 2022 at 7:48 PM
    biebs96
    PA
    Following
  9. Dec 9, 2022 at 7:51 PM
    Tundra1D6
    Go swap’em and report back! I have to spend money on truck things…..
  10. Dec 15, 2022 at 10:57 AM
    Toe404
    Tomas
    Concord ,CA
    New switch showed up today, I’ll swap them on my lunch break, stay tuned!
    Pillslinger and MedCityMoto like this.
  11. Dec 15, 2022 at 11:09 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Seriously though, the thought never crossed my mind for my 2016 but if this works, when I'm relocating it to the center console, I'll swap mine too!
    wiltech likes this.
  12. Dec 15, 2022 at 11:16 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
  13. Dec 15, 2022 at 11:45 AM
    Toe404
    Tomas
    Concord ,CA
    Well… it fits, the switch works, but no auto functionality… damnit.
    MedCityMoto likes this.
  14. Dec 15, 2022 at 11:50 AM
    MedCityMoto
    Damn shame! But thanks for testing it out for the rest of us.
  15. Dec 15, 2022 at 12:04 PM
    Pillslinger
    Rollin
    SWMO
    Well crap. That mod woulda gone viral.
    Toe404[QUOTED][OP] likes this.
  16. Dec 15, 2022 at 12:35 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Probably handled by a control module. May be able to use a timed latch circuit to add the functionality without reprogramming the CM.
  17. Dec 16, 2022 at 9:45 AM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    @2020Platinum has already done this mod using the Autoloc module:
    2020Platinum and MedCityMoto like this.
  18. Dec 16, 2022 at 11:15 AM
    MedCityMoto
    I should wire this into my rear window extension cabling when I relocate the rear window button to center console! I'm loathe to cut any stock harness wiring like this seems to ask for, but damn if I won't customize a plug-and-play harness all day any day.
  19. Dec 16, 2022 at 8:00 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thanks for sharing, it worked perfectly!...and easy to do, I'll be adding it to my '22 Pro rear window as well!
  20. Dec 17, 2022 at 4:27 PM
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    2020 Platinum - Super White
    Elka DSC Suspension, Ray-10s, MaxTrax, Dirt King UCA, 295/70/18 Toyo AT3, TRD Skid + Intake, .25 Bumper Shim, UnderCover UltraFlex Tonneau, RoadActive Suspension, Tuffskinz, etc.
    A bit of a shot in the dark, but if you have not already, you might try the power window normalization routine that Toyota auto windows require after swapping the battery. If the logic is in the switch, it may just need the normalization performed first. Here is a 4Runner, but same routine: (63) Normalizing Toyota Automatic Power Windows - YouTube
    HulkSmurf14 and biebs96 like this.
