Sequoia front end? Has anyone on here ever did an 06-07 sequoia front end conversion?
Discussion in '1st Gen Tundras (2000-2006)' started by autosport209, Sep 6, 2017.
  1. Sep 6, 2017 at 6:26 AM
    autosport209
    autosport209 [OP] New Member
    2005 tundra limited crew cab
    I parked next to this sequoia today. Has anyone ever done an 06-07 sequoia front end swap?
  2. Oct 10, 2017 at 8:35 PM
    scruffy
    scruffy New Member
    Dmitriy
    2014 Toyota Tundra Double Cab Limited TRD 5.7 4X4
    Almost done doing mine. Kind of a pain...
    5N0W808, KarmaKannon, bmf4069 and 4 others like this.
  3. Oct 11, 2017 at 12:30 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Bill
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    how was it painful? What was the worst part? can you upload more pics? Really interested to see how this looks when its all done
  4. Oct 11, 2017 at 12:54 PM
    scruffy
    scruffy New Member
    Dmitriy
    Sorry for the un-detailed reply I don't have much to offer in terms of pictures but once I'm finished (hopefully soon) I should be able to offer more. To explain the difficulty one must really begin where I began with the truck. This was the state in which I purchased it...
    This is a 2006 Toyota Tundra Double Cab SR5 4.7 4x4. Now myself not being well versed in Tundras or first gens in general. I had to find out the hard way that a lot of panels for 05-06 are unique, Double Cab even more so unique, and SR5 even more so on top of that. Could be just the part number system set up to mess with me but that's what I've come across.
    Then came the task of trying to figure out what parts (if any) are shared between the Sequoia and Tundra, which the Sequoia also had it's fare share of design changes. Next is sourcing the parts, for example fender flares came in a few different flavors (so did fenders) which a lot of the time you have just a generic picture to go by. This for example is all I had to work with...
    (found on parts.toyota.com)
    As you can see a lot of the images are not very descriptive so it's hard to imagine what the part looks like and if it will serve your purpose especially when converting from one vehicle to another. You try to look up images by part number but seldom are proven successful to find anything beyond the crude drawings seen above.
    So initially I started out thinking...Great! This should be as easy as new bumper cover and grille with all else being the same. Proceed down the rabbit hole and you find out the bumper reinforcement is different, the one piece Tundra turns into three piece Sequoia. The bumper fillers are different (under headlights). Tundra's bolt to the fender, a bracket off-of the radiator support, and finally to the bumper reinforcement. The Sequoia fillers are plastic and bolt onto the bumper reinforcements on either side as well as requiring another set of mounts just to attach them to the fenders. If you've gotten this far, then you will find out the brackets coming off the radiator support are different, so now you will have to cut yours to the proper size and make holes so you can attach. Lastly, don't forget the hood opener on the grille. Different offset location and different length rod.
    There are other differences like the actual metal bumper, plastic bumper support pieces, and etc. This, I'll hopefully be able to get into more once I have a more complete parts list and process required.
    Hooptytrix, 5N0W808, MS22 and 3 others like this.
  5. Oct 11, 2017 at 1:40 PM
    tacoguybill
    Bill
    Saaaan Diaaago
    Hell yeah! The misfortune of your rabbit hole is most interesting and I’m excited to see the end state! Good luck!
  6. Oct 11, 2017 at 7:06 PM
    Phillipk98
    Phillipk98 05 sequoia
    2005 sr5 sequoia
    Lol sounds like any idea you had of swapping went down the drain. Just kidding. I wondered my self what it would look like.
    Thanks scruffy for the info. Looks good man waiting on the end product.
    tacoguybill[QUOTED] likes this.
  7. Oct 17, 2017 at 3:36 PM
    Black Rollover
    Black Rollover New Member
    David
    2004 Tundra Double Cab Ltd
    Added a Sequoia bumper to mine.
    KNABORES, Hooptytrix, 5N0W808 and 2 others like this.
  8. Oct 18, 2017 at 3:12 PM
    autosport209
    Thanks for sharing this.
  9. Oct 18, 2017 at 3:12 PM
    autosport209
    Looks good
  10. Oct 18, 2017 at 3:12 PM
    autosport209
    I dig it !!!
  11. Oct 22, 2017 at 10:18 PM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
    Subscribed
  12. Nov 11, 2017 at 8:46 PM
    scruffy
    scruffy New Member
    Dmitriy
    Ok update time....
    This is the absolutely required parts list for this conversion to work. There might be small pieces missing but that is details.
    As you can deduce the hood, headlights, fog lights (with plastic bumper), and fenders (late model SR5) remain the same. If you lack the fenders, I heard it may be possible to add the SR5 flares to standard fenders but I can't confirm that.
    Actual truck modification is minimal. You need to trim the bumper support brackets as shown below. Afterwards, another hole gets drilled up top to secure the new bumper support.
    Bumper side support pieces are different from the Tundra one's, but I'm not sure if they are 100% necessary so I bought them anyway.
    The bumper cover support is completely different including the fillers below the headlights. This is pictured below.
    The last picture shows the bumper fillers in place. They use their own retainers, pictured below.
    Lastly, the "almost" finished product and a bumper comparison shot.
    Overall I think the process is well worth it and the appearance change is drastic. Things to note would be... fender liners need changed since the Sequoia liners are wider due to the fact that flares are actually part of the bumper cover. The hood latch can be made to work with the Sequoia grille but the rod will need bent/modified and the lever will be pushed in on the left instead of right. The Sequoia grille location is slightly shifted when compared to the Tundra. Fog lights are 100% plug and play so no worries there.
  13. Nov 11, 2017 at 10:03 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    That looks great! Nice work!
  14. Nov 13, 2017 at 5:32 AM
    tacoguybill
    Bill
    Saaaan Diaaago
    Looks awesome! I like the headlights you went with too, who makes those?
  15. Nov 13, 2017 at 10:20 AM
    scruffy
    scruffy New Member
    Dmitriy
    Thanks, she's almost there.
    The headlights came from eBay from the seller "oemassive". I wanted black housing Depo's but no such luck, they don't exist. In either case, I'm not a fan of chrome so I went with the one's linked below. Not the best quality but I think they will do the job just fine. I didn't expect the light output to be as good as the OE so I also installed a hi/lo 55W HID kit.
    http://r.ebay.com/I3282m
  16. Nov 13, 2017 at 8:21 PM
    autosport209
    That came out amazing !!!! It gives the Tundra an updated look. My truck looks lile a pug dog compared to yours..haha
  17. Nov 14, 2017 at 5:16 AM
    scruffy
    scruffy New Member
    Dmitriy
    Thanks for the kind words, make me feel good knowing my efforts are appreciated. I'd be lying if I said that your initial post didn't both serve as encouragement and guide through this process. As I mentioned above, there isn't a direct comparison anywhere and the technical diagrams do a poor job showing the differences. So for that, thank you!
  18. Nov 14, 2017 at 7:46 AM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Mixflip on youtube went the the sema show and there was a sequoia with a 3rd gen tundra front end, it looked B.A.
    scruffy likes this.
  19. Nov 14, 2017 at 8:36 AM
    scruffy
    scruffy New Member
    Dmitriy
    I think this is what you're referring to... https://youtu.be/N7oCGi666Tk?t=677
    Part of me feels as though there had to be some extensive custom work to pull it off though. If you look at the width, there's about 6 inches difference. It could mean the panels are just wider or the hood itself is wider. Either way I don't think it was just a simple bolt on feat.
  20. Sep 24, 2021 at 4:39 PM
    Jflor484
    Jflor484 New Member
    James
    01 3.4 5 speed 2wd rclb
    Sorry for being a Necro
    But when you did this did you also change out the whole inner fender structure too? Or just the sheet metal on top
  21. Sep 24, 2021 at 9:51 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I’m going to say no. I have an 06’ Tundra and 07’ Sequoia and I want to Tundra swap the Sequoia lol.
    5N0W808 likes this.
  22. Sep 24, 2021 at 10:45 PM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    Excuse my ignorance and thread jack,
    What is the appeal to using a Sequoia front end? I’m curious.
  23. Sep 25, 2021 at 9:04 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    What is the appeal of a red truck?
    5N0W808 likes this.
  24. Sep 25, 2021 at 9:42 AM
    Nic146
    Nic146 New Member
    Well yes, I know that it is subjective. No need to get defensive ;)
    Like I said, I am just curious what about the sequoia front end draws attention? Is it the lines? The bumper? The clearance? A better grill? A more updated look? A more striking profile? I love how it looks but am curious if there is further reasoning behind it?
  25. Sep 25, 2021 at 1:50 PM
    KarmaKannon
    Utah
    Some junk
    If asking a question is defensive then I guess I was justified after your offensive use of a question.
    It's just preference. That was the point. It's like describing the color green to a person blind from birth. The reality is that it looks different and sometimes that's enough for some people.
    shifty` likes this.
  26. Sep 25, 2021 at 2:18 PM
    Nic146
    Nic146 New Member
    No hard feelings.
    Fair enough.
    I helped a friend Tundra swap an 03 Sequoia a couple years back so it’s very interesting to see it go back the other way. It does look nice though.
  27. Sep 25, 2021 at 4:15 PM
    KarmaKannon
    Utah
    Some junk
    I think I might like you. When a smartass meets a smartass haha
  28. Sep 25, 2021 at 5:26 PM
    Jflor484
    Jflor484 New Member
    James
    Availability at the junkyard
  29. Aug 2, 2022 at 9:00 AM
    PCBGlenn1$tgen
    PCBGlenn1$tgen New Member
    Christopher
    04 tundra old 316k and can still hit 100
    Hardly any
  30. Aug 2, 2022 at 9:02 AM
    PCBGlenn1$tgen
    Christopher
    Hardly any
    Could you email.me at christopherglenn511@gmail.com..
    I have a sr5 tundra and sr5 Sequoia I am wanting just to switch. The fronts total already have grill and hood switched and modified the release so it works now got the other pieces off the SUV and I'm ready to fulfill my Destiny.. if you could send the pictures man that would be great and also any helpful tip thank you
    5N0W808 likes this.
