Sequoia Rear Brake pads wearing unusually fast.
Discussion in 'Sequoia 1st Gen (2001-2007)' started by Roberts99Sequoia01, Dec 18, 2023.
  1. Dec 18, 2023 at 1:04 PM
    Roberts99Sequoia01
    Roberts99Sequoia01 [OP] New Member
    Need some help here.
    Bought a 2001 Sequoia. I love it….except for one thing. I’m going through brake pads on the rear like they’re butter. No you don’t understand…..I’m talking a set of pads every 2-4 weeks. I put new calipers on thinking they were seizing up but the problem didn’t go away. In fact, it seemed to get worse. All parts coming from NAPA. I would love to keep the truck but I’m not putting pads on this thing 1-2 times per month. Obviously something is wrong. Any ideas?
  2. Dec 21, 2023 at 6:58 AM
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    That's an odd one. I would be looking at things that can cause pressure to stay in the system in the rear. Maybe a clogged brake line? Or a bad master cylinder? Not sure if a bad ABS pump/module could cause this too?
    Also while it seems counter intuitive, you might get more feedback in the 1st gen tundra forum. They are way more active. Just be sure to let them know you have a sequoia because there are some differences in the brake system compared to the tundra.
  3. Dec 21, 2023 at 8:38 AM
    Roberts99Sequoia01
    Good call. Thanks for that!!!
  4. Dec 23, 2023 at 5:25 AM
    axtawesomizer
    axtawesomizer ABG
    Alec
    Pullman, WA
    2001 Sequoia SR5 4x4
    Holy cow, are they not glowing red hot when you get done with a long drive? How's your gas mileage with stuck brakes?
