Sequoia Wheels
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Bulldog1776, Nov 18, 2020.
  1. Nov 18, 2020 at 7:24 AM
    Bulldog1776
    Bulldog1776 [OP] New Member
    2008 Sequoia
    Hello, I'm new here
    I have an 08 sequoia 4wd, I read you can fit 275 70 18 on stock suspension. The tires i'm looking at are falken at3w it says for wheels from 7-9 inches wide. There are a lot more wheel options in 9 than 8.5 are the any reasons not to go with 9? Would that cause any rubbing issues?
    Thanks guys.
    YardBird likes this.
  2. Nov 18, 2020 at 7:56 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Will be fine as long as the offset is not crazy. The more the rims/tires stick out the more clearance issues you can have. I run 275/70-18 on stock suspension, stock TRD OR wheels and there is plenty of room so I do not think 1/2 inch extra rim on each side would cause any issue. Again, it is all about the wheel offset.
  3. Nov 18, 2020 at 8:50 AM
    Bulldog1776
    2008 Sequoia
    Thanks, according to the website customoffsets I need a -22mm to 65mm. So, should I opt for closer to -22 or 65? I don't understand exactly how that stuff works.
  4. Nov 18, 2020 at 8:52 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Nov 18, 2020 at 9:11 AM
    Bulldog1776
    2008 Sequoia
    a couple more questions. Would I be ok to run a 17x8.5 inch wheel? Any concern with rubbing brake calipers?
  6. Nov 18, 2020 at 10:12 AM
    frichco228
    Well for reference, stock 18inch TRD OR wheels are +60mm and that size tire fits perfect on those wheels with stock suspension.
  7. Nov 18, 2020 at 12:00 PM
    Bulldog1776
    2008 Sequoia
  8. Nov 18, 2020 at 5:19 PM
    Bulldog1776
    2008 Sequoia
    Any idea what offset I need to avoid rubbing the UCA's?
    I'm thinking I can fit 285/75/17 on my stock suspension, if i get the correct wheel?
  9. Nov 19, 2020 at 5:53 PM
    Bulldog1776
    2008 Sequoia
    I'm going to get 275 70 18 tires. I'm looking at a 18x8.5 wheel with a +18 offset. Is that a good offset on a 8.5 width wheel?
