Serpentine Kit - Toyota, Gates, Other?
Discussion in '2nd Gen Tundras (2007-2013)' started by rustytoys, Feb 4, 2020.
  1. Feb 4, 2020 at 8:54 PM
    rustytoys
    rustytoys [OP] New Member
    For the 5.7 V8 what is a quality serpentine belt kit (belt, idler and tensioner pulley) - the factory Toyota parts run $200, or Gates has a high performance kit for $130, opinions?
  2. Feb 4, 2020 at 10:43 PM
    SouthWestGA
    SouthWestGA New Member
    Vince and chugs like this.
  3. Feb 4, 2020 at 10:50 PM
    SouthWestGA
  4. Feb 5, 2020 at 2:18 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    I bought the Dayco tensioner and belt, my tensioner was rusted and I could not remove it, thankfully the original seemed fine, the Dayco belt squeals at startup every time I start the truck, very annoying, should have left the stock belt on, it looked fine just thought after 10 years and 65k miles I should replace it. I would not buy Dayco again.
  5. Feb 5, 2020 at 3:58 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
  6. Feb 5, 2020 at 4:18 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I used Dayco pulley's per research/forum indicating they are OEM and the parts confirmed it ... But I always put a Bando serpentine belt on my asian makes and models. Just never failed me so I stick to them.
  7. Feb 5, 2020 at 4:33 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    New to me......Dayco makes all the belt drives for General Motors.....and they suck. WHY. Go with the Gates, they have a long good history. The Gates kit is even cheaper......but I would go with the GREEN belt. You will never go back.
  8. Feb 5, 2020 at 4:45 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I use Bando on my Asian cars. I use Gates for everything else. Seems to me that the Bando belts are less likely to squeak. The surface finish of the belt where it rides against the pulley looks different on a Bando vs Gates belt.
    RitcheyRch likes this.
  9. Feb 5, 2020 at 8:52 AM
    rustytoys
    Yes, the Gates kit I was looking at is the "Fleetrunner" which has the green belt, its only twenty more than the base Gates kit.
  10. Feb 5, 2020 at 8:55 AM
    rustytoys
    But if you didn't replace the tensioner or idler - then couldn't that be whats causing the squeak?
  11. Feb 6, 2020 at 2:21 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    It could be but it is not, I can spray belt dressing on it and it doesn't squeal for a couple starts, also it squeals more depending on how humid it is out, the tensioner would not do that.
  12. Feb 6, 2020 at 2:44 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    It's worth the money to replace the tensioner and idler, but if not bad you can always re-grease the bearings. Dont let the term sealed bearing stop you, it can be done. (especially when you have an antique and just cant find them) A weak tensioner could cause some noise.
  13. Feb 6, 2020 at 6:28 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    What about the Goodyear gatorback belt? Are they available for our motor? I've had good result using them on my previous toyota celica 1.8L.. quiet and doesnt squeak.
  14. Feb 6, 2020 at 7:44 PM
    rustytoys
    Not sure I understand your point; if your are spraying belt dressing on - then you are giving it artificial grip - thats extra grip it would need to stop squeeking if the tensioner is bad... belt dressing would simply be temporarily masking a bad tensioner. Humidity would also - again affect grip. Or am I missing something?
  15. Feb 6, 2020 at 7:48 PM
    BrandonL812
    Brandon
    Spraying belt dressing is another way to check if your belt is squeaking or your tensioner is dying.
    You would spray the ribs side of the belt, away from the tensioner. Noise stop, it's the belt. Noise still there, your tensioner. Then again you could also pb blaster and it will produce the same result.
  16. Mar 6, 2020 at 4:14 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Update to my belt situation, I replaced my 10 year old original belt that was not making any noise but thought it would be a good idea as preventative maintenance. Replaced the original with a Dayco 5080950DR, it was tight to put on and squealed every time I started the truck, after a couple months I couldn't take it anymore and replaced it with a Gates K080948, now it is completely silent, I think the Dayco was too tight.
    focal and chugs like this.
  17. Mar 6, 2020 at 4:18 PM
    Went with gates
  18. Mar 6, 2020 at 4:41 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    Goodyear sold it's belt making division to Continental. Gates does make good belts.
  19. Mar 12, 2020 at 5:44 AM
    Billy Bob Tundra
    Billy Bob Tundra New Member
  20. Mar 12, 2020 at 6:55 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I installed a new belt tensioner less than a year ago and that bad boy is already back to squeeking. It was a Dayco replacement..
  21. Mar 14, 2020 at 5:24 PM
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    Is going with a new oem belt not a good idea?
  22. Mar 14, 2020 at 5:36 PM
    docfnky
    docfnky New Member
    Nowadays the factory wear and tear items are pretty cheap on Amazon.
  23. Mar 14, 2020 at 6:22 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Naa. It’s the interwebs. Same people who swear by cheaper belts, change their $10/qt synthetic oil every 1500 miles cause it’s “cheap insurance”.
    OEM is as solid as anything out there.
    Skew12[QUOTED] likes this.
  24. Mar 14, 2020 at 6:33 PM
    Skew12
    Skew12 New Member
    Thanks. I’ll be changing mine soon.
