Service Campaign Premature Tire Wear
Discussion in '3rd Gen Tundras (2022+)' started by Burnt, Feb 29, 2024.
  1. Feb 29, 2024 at 4:39 PM
    Burnt
    Burnt [OP] New Member
    Midnight TRD PRO
    I just commented on this a couple of days ago about how I had all four of my tires replaced by Toyota only a couple of weeks ago due to premature wear. I know this subject is not new but TRD PRO owners be aware it’s now official.
    Troyboy84 likes this.
  2. Feb 29, 2024 at 7:32 PM
    Burnt
    Midnight TRD PRO
    Congratulations
  3. Jul 22, 2024 at 6:35 AM
    warfare
    warfare New Member
    2012 Platinum and now 2023 Limited Hybrid TRD OffRoad
    Does anyone have the Specs that this service campaign details? Going to purchase new tires soon and want to ensure that the alignment is not set to this factory setting causing the tire wear.
  4. Jul 22, 2024 at 1:06 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    So what are the "Subject vehicles?" I see you reference TRD Pro owners but does it include any other trim levels?
  5. Jul 22, 2024 at 1:07 PM
    warfare
    warfare New Member
    When I spoke to Toyota about my 2023 Limited-HV TRD OffRoad they claimed the service campaign was not applicable to my VIN
  6. Jul 22, 2024 at 1:13 PM
    Knifeguy
    Knifeguy New Member
    Erik
    Oklahoma
    22 SR5 4x4 Crew-Max Short bed
    Didn't even get 20,000 out of the wild peaks that came on my SR5. Not applicable to me either.
  7. Jul 22, 2024 at 1:14 PM
    warfare
    warfare New Member
    From what I have found it's the toe setting from the factory is the issue. I just want to know what the good specs for alignment are to ensure my new tires don't get shredded.
    Tundrastruck91 likes this.
  8. Jul 22, 2024 at 1:14 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    You guys need to probably file a complaint on the National Highway site, maybe can get it expanded.
  9. Jul 23, 2024 at 9:12 AM
    ttthorn
    ttthorn New Member
    Took my 2024 Platinum/Off Road Package to dealer and the Toe and Camber were out of specifications. They adjusted and noted "feathering" on the tires, ie premature wear. My Vin was NOT part of the tire recall so I have called Toyota Care. Toyota care told me to call Tire manufacturer. I have since contacted the dealer again as well as Toyota Corporate for resolution. Will keep everyone posted. I have the alignment before and after as well as notes from technician. Toyota needs to do the right thing here as the vehicle only has 5000 miles on it.
    Upfront1 and woods like this.
  10. Jul 24, 2024 at 7:16 AM
    Hugh_Jaynus
    Hugh_Jaynus New Member
    2023 Silver Tundra Platinum 4x4 Crewmax
    My '23 Platinum has the same wear on the outsides. When I mentioned to the service department they said "That's only a problem on the TRD Pros".
    You can see for yourself the wear is there but they act like it's not a problem.
    Besides the stack of recall letters I've got, I guess I'll just add it to the squeaky brakes, air conditioner that's not cold, wind noise from the inadequate seals, and the numerous other things that are not recalls but are wrong with this disaster of a truck.
    woods likes this.
  11. Jul 24, 2024 at 7:44 AM
    freaksavior
    freaksavior New Member
    Richmond, Tx
    '22 AG 1794
    Dechromed
    my '22 1794 is wearing the outer too and it was noted by the tech the last time I was in.
    Hugh_Jaynus likes this.
  12. Jul 24, 2024 at 8:54 AM
    Knifeguy
    Knifeguy New Member
    Erik
    Oklahoma
    I noticed a lot of brake squeak as well, they discovered faulty brake pads and replaced them. Cleared right up.
  13. Jul 24, 2024 at 8:56 AM
    sudobash
    sudobash New Member
  14. Jul 24, 2024 at 2:07 PM
    ttthorn
    ttthorn New Member
    I have filed a complaint on the National Highway site.
    woods and Hugh_Jaynus like this.
  15. Jul 24, 2024 at 2:23 PM
    warfare
    warfare New Member
    New Tires on today. Toyo Open Country AT3 285-55-20
  16. Aug 4, 2024 at 4:14 PM
    MateoAirborne
    MateoAirborne New Member
    Mateo
    2023 iForce Max 1794 TRD Off Road Package
    Same here. I got 25k out of mine. Had to buy some Coopers. I plan on taking the truck in to have them fix the alignment. I have a 1794, but I got the TRD 3” lift, so hoping they will honor the 3 year 36,000 mile warranty on the lift.
  17. Aug 4, 2024 at 4:19 PM
    Breathing Borla
    Northern Illinois
    Are you guys with feathering keeping the stock psi on the door?
  18. Aug 4, 2024 at 7:10 PM
    warfare
    warfare New Member
    Wearing out the outside edge of the front tires due to the Toe setting from the factory.
  19. Aug 5, 2024 at 4:22 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I can see why the Pros are killing tires fast. Here are the Toyota specs for 2022.
    https://static.nhtsa.gov/odi/tsbs/2022/MC-10210384-9999.pdf
    The Pro has a very aggressive Toe at almost 0.6 degrees. The 4x4 are only 0.3 degrees.
    Combine this with some positive camber and you have a recipe for worn tires.
  20. Aug 5, 2024 at 4:25 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Toyota must have bought in on a rubber manufacturer. Record profits on the way.:burnrubber:
  21. Aug 5, 2024 at 4:41 AM
    warfare
    warfare New Member
    My 4x4 was at -.07 reset with new tires to -.01
