Shift solenoid c code 0761
Discussion in 'New Member Introductions' started by Leeban56, Dec 26, 2021.
  1. Dec 26, 2021 at 9:11 AM
    Leeban56
    Leeban56 [OP] New Member
    Leroy
    2007 Toyota Tundra 5.7 crew max
    Air assist on rear suspension.
    Recently started having issue with fault codes coming from transmission operation. Specifically, when first starting out from a cold truck, transmission will delay shifting from 3rd to 4th, 5th, and 6th gears. I will get a CE 0761 shift solenoid “c” performance or stuck. After resetting computer, truck runs great and no issues for several days. Does anyone know the part number for the transmission shift solenoid “c”. I have changed shift solenoid “d” two months ago. No issues until recently. Fluid is clean and no debris in pan.
    Thanks in advance for any shared knowledge on this subject.
  2. Dec 26, 2021 at 2:04 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
