Shocks for a 4" lift?
Discussion in 'Suspension' started by rafoolgotchu, Dec 23, 2023.
  1. Dec 23, 2023 at 9:14 PM
    rafoolgotchu
    rafoolgotchu [OP] New Member
    2015 Grey Tundra
    what’s the best shocks for a 4inch lift. was looking at some from pro comp but i’m not sure.
  2. Dec 23, 2023 at 9:32 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You need to custom make something
    rafoolgotchu[OP] likes this.
  3. Dec 23, 2023 at 11:17 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Drop down to 2 to 3 inch lift and your options become endless and it's better for the longevity of the truck too
    rafoolgotchu[OP] and T-Rex266 like this.
  4. Dec 24, 2023 at 7:49 PM
    rafoolgotchu
    2015 Grey Tundra
    thanks. i appreciate it
  5. Dec 24, 2023 at 8:10 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    Fox makes shocks that will accommodate your said lift height.
  6. Dec 25, 2023 at 8:20 PM
    rafoolgotchu
    2015 Grey Tundra
    okay thanks. i’ll look into it.
  7. Dec 25, 2023 at 8:21 PM
    rafoolgotchu
    2015 Grey Tundra
    do king shocks also have that option ?
  8. Dec 26, 2023 at 4:36 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    +4” is just a weird lift for Tundras. Not a lot of shock options that fit perfectly at that height.
    Are you already lifted 4”, or are you shooting for that and compiling your parts list?
    What are your goals for the truck, after you find the shocks you want?
    What size tires?
    What wheel size and offset?
    Are you looking front and rear?
    What’s your budget? You asked what is the best…. We will not be afraid to spend your money, so you’ll need to set a realistic budget for your goals. A single shock can cost anywhere between $120 and $3,120. Luckily, there are a ton of options on the lower end!
  9. Dec 26, 2023 at 7:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Op, i assumed you already had a 4 inch bracket lift? If you dont, then just do 2 inches of lift with shocks, thats plenty
