Should your phone auto connect to the Tundra?
Discussion in 'Audio & Video' started by Minarets, Mar 2, 2021.
  1. Mar 2, 2021 at 8:41 AM
    Minarets
    Minarets [OP] New Member
    Nashville
    2021 TRD PRO
    When starting up and already synced should the phone auto connect? I have to manually do it. Weird.
  2. Mar 2, 2021 at 8:46 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Yes.
    It should remember your phone and if bluetooth are on in the Vehicle (may be in settings) and your phone.
    Bluetooth must be set to "ON" in your phone.
  3. Mar 2, 2021 at 8:51 AM
    Minarets
    Nashville
    2021 TRD PRO
    It is on. It’s like the truck doesn’t remember to connect. It’s there when I hit add a device on Home Screen. Like when I select add a device it shows mine and I have to connect it. Weird
  4. Mar 2, 2021 at 8:55 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    It might be a bluetooth security setting in your phone that is keeping it from auto connecting. Make sure the truck is set as trusted.
    BravoDeltaRomeo likes this.
  5. Mar 2, 2021 at 8:58 AM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    What phone are you using?
    One thing to try is to delete the phone from the headset and re-pair it. You may have already tried this though.
    WILLINH and Minarets[OP] like this.
  6. Mar 2, 2021 at 9:03 AM
    Alphamale
    Alphamale New Member
    Todd
    Michigan
    2018 SR5 TRD off-road dbl cab Tundra aka: Black Ops
    Mostly stock, for now
    Mine does as soon as I turn on the key. Do you see your phone battery etc. in the upper right hand screen? If not I’d check in your settings to make sure everything is copacetic.
  7. Mar 2, 2021 at 9:04 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I have to connect 4 or 5 times for my phone list to load into kenwood headunit, but it always connects if I have bluetooth enabled on phone.
  8. Mar 2, 2021 at 9:06 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Connection can be funky at times. I have also had issues when my phone gets updates. Whenever there is any issue, deleted the phone from the truck and re-pairing gets things back to working as they should.
    Astom22 likes this.
  9. Mar 2, 2021 at 9:09 AM
    Minarets
    Nashville
    2021 TRD PRO
    I took to the dealer yesterday about this and they said there is a TSB for those with an iPhone 12 but I have a XR so there was nothing they could do and to checks back.
    They reset the unit (not just holding done the power button) and still doing it. But I have a funky HU anyway. I get weird CarPlay issues at times.
  10. Mar 2, 2021 at 9:21 AM
    crewmaxlmt
    scott
    The CarPlay issues as of recently can be attributed to Apple's last two updates. My CarPlay has been horrible ever since they forced the update on my iphone 10 about a month ago. It got a little better with the following update, but it still acts up all of the time. Before that I would just have to reset the HU if I had a glitch.
  11. Mar 2, 2021 at 10:04 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Why the hell do people still use an iPhone?
  12. Mar 2, 2021 at 10:20 AM
    Minarets
    Nashville
    2021 TRD PRO
    Because my work gives me one.
  13. Mar 2, 2021 at 10:36 AM
    crewmaxlmt
    scott
    Because I got sick of my android being obsolete after a year. Hearing the provider giggle because it is "too old". But yet I see people with iphones that are 6 years old and they still work fine. I am no fan of Apple, but their platform just works and they have great customer service. Besides, they used to be much more expensive than androids; not so much anymore.
    The Californian likes this.
  14. Mar 2, 2021 at 11:02 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Because they’re a lot like Tundras, they just work. (And Android sucks)
  15. Mar 2, 2021 at 1:00 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I have an iPhone SE (the 2020 version) and every once in a while, it won't automatically connect to the truck. Sometimes it's when I use remote start from inside the house and others it's just random. Doesn't happen enough for me to do much about it though. My old iPhone 7 did the exact same thing.
    It's bluetooth. I think it's just clunky.
    You could try deleting the phone off of the truck and clearing the truck off of your phone and then repairing it together and see if that helps.
  16. Mar 2, 2021 at 1:07 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    My son's iPhone was set up in the truck. One day when I pulled in the driveway, all of a sudden I was hearing one side of a phone call (I don't have a phone, so it clearly wasn't my call). It had hijacked my son's side of a call from his room (just above where I park) and I was hearing his girlfriend's side of the conversation. I ended the call and promptly deleted my son's phone from the list.
    BlackSheep likes this.
  17. Mar 2, 2021 at 1:20 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Honestly, when it comes to AirPlay the problem is that Apple, and Toyota don't communicate effectively when it comes to updates.
  18. Mar 2, 2021 at 1:21 PM
    The Californian
    Eric
    But did you hear anything good?
  19. Mar 2, 2021 at 1:28 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I got tired of being Google's unwilling beta tester for the recent shitty updates they push in-app. I was a big fan of the Pixel line for a while, but the last year and half has been a shitstorm of glitches and feature removal. Android Auto had an atrocious UX and poor app support. I don't like Apple for a lot of things, but their app ecosystem and CarPlay are leaps and bounds above Android. Hopefully Google will get their shit together and get caught up someday.
    But back to OP, your phone should automatically connect. Your head unit sends out a connection request for about 30 seconds or so after you turn the key. If your phone misses it, you'll need to manually connect or sometimes restart the truck. If it's not connecting automatically, you should delete the connection on both your phone and the head unit and pair it again.
  20. Mar 3, 2021 at 8:37 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's the same reason my wife has one.
  21. Mar 3, 2021 at 8:41 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That happens all the time when you pull in a customer's vehicle for service. They are sitting in the waiting room you get to hear the call while servicing the vehicle.
    Astom22 likes this.
  22. Aug 12, 2021 at 6:12 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I used to have an old iphone SE, the one from like 2016. I had to manually sync it every single time I started the truck, using that damn microphone button on the steering wheel. So aggravating, and my kids would just laugh and laugh, listening to me repeat my commands at the truck. Then last fall I got the iphone 12. I paired it with the head unit shortly after getting it, but because of my headaches with the SE, I never tried to stream music through my phone until a camping trip this past weekend. My first attempt was to use the USB cord to channel music to my phone. The head unit recognized the songs I was playing on my phone, but there was no audio. Not through the truck. Not through the phone. So I disconnected the USB to reconnect it, and as soon as I unplugged it, voila! Audio through bluetooth. How the hell did this happen?? I never went through the voice activated syncing process on this trip. And what's more, my phone synced automatically several more times on the trip, but I have no idea what I did to make this happen. You're telling me it's supposed to work this way?
