Side Mirrors w/ OEM Puddle Lights on a Truck w/o Puddle Lights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Getoffmylawn, Dec 23, 2022.
  1. Dec 23, 2022 at 9:54 AM
    Getoffmylawn
    Getoffmylawn [OP] New Member
    Taylor
    I did a search but only seemed to find posts about splicing in non OEM puddle lights. Anyone tried putting side mirrors with OEM puddle lights on a truck that didn't come with them from the factory? Wondering if they would still work? Sorta hopeful that Toyota just pre-wired all the trucks that way from the factory...
    HulkSmurf14 likes this.
  2. Dec 23, 2022 at 10:59 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    They didn't, some have it and some don't.
    My 2014 SR5 mirror plug has no power for the turn signal or puddle lights.
    I had to run my own wiring.
    Here is the schematic for the puddle lights.
    You can test your plug with a DMM to see if it's hot.
    You just need to figure out what turns it on, usually unlocking the doors with the key fob turns puddle lights on, then they go off with a closed door or they time out.
    M5 and N6 are the mirror plugs in the door.
    Test pin 6 and pin 5 to see if it's hot.
    There are a few threads on installing puddle lights in non-puddle light housings and running your own wires.
  3. Dec 23, 2022 at 11:01 AM
    Getoffmylawn
    Taylor
    This is awesome, thanks for the info! Definitely gonna pull a mirror and throw a tester on those pins to see if I'm lucky enough to have the wiring already there.
    1lowlife likes this.
  4. Dec 23, 2022 at 11:04 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I don't think my truck even has those wires in it..:eek2::cool:
  5. Dec 23, 2022 at 11:05 AM
    Getoffmylawn
    Taylor
    Yeah, I guess looking to see if they even exist on mine would be a good place to start...
  6. Dec 23, 2022 at 12:12 PM
    What year is your Tundra? Mine is a 2018 and my door side harness is wired for turn signals. You just need to add a pin to the mirror side and change the mirror glass. Don't know about puddle lights.
    Cthulhu likes this.
  7. Dec 23, 2022 at 12:17 PM
    Getoffmylawn
    Taylor
    Mine's a 2015 SR5/TRD Offroad. That would be sweet if I could also add turn signals!
  8. Dec 23, 2022 at 12:33 PM
    This is the + pin for the blinker on a 2018. That plug is from the door side. You just need to add the pin on the mirror plug and the new glass.
  9. Dec 23, 2022 at 12:35 PM
    Getoffmylawn
    Taylor
    Awesome...guess it's time for me to pull a mirror and see what I've got!
  10. Dec 23, 2022 at 2:39 PM
    Cthulhu
    My 2018 Limited’s OEM mirrors did NOT come with turn signals, but when I bought my tow mirrors, lo and behold the turn signals on them worked, so at least the turn signals came prewired from the factory. Never been able to find if they were also prewired for the puddle lights…
  11. Dec 23, 2022 at 3:29 PM
    Getoffmylawn
    Taylor
    Mine originally had OEM tow mirrors on it when I purchased it, and the turn signals worked, so I guess mine was pre-wired for that as well. Guess I could buy some puddle light mirrors and see if they work, you know, in the name of science.
  12. Dec 23, 2022 at 3:37 PM
    Tundra1D6
    Where’s everyone buying oem mirrors from?
  13. Dec 23, 2022 at 3:39 PM
    Getoffmylawn
    Taylor
    I lucked into a paint matched set on FB marketplace.
