Side view mirrors tilting down when in reverse
Discussion in '2.5 Gen Tundras (2014-2021)' started by wsutundra, Jun 24, 2021.
  1. Jun 24, 2021 at 11:23 AM
    wsutundra
    wsutundra [OP] 2021 Smoked Mesquite 1794
    I have a new 1794 crewmax and I remember when I first got it, the side view mirrors would tilt down when reversing.
    I noticed they don’t do that anymore. Any reason? Is there a setting I maybe turned off?
  2. Jun 24, 2021 at 11:25 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I believe that happens when your mirror selector is on one of those mirrors and you put it in reverse, it will tilt down. If your mirror selector is in the middle, it doesn't tilt down in reverse.
    Byrdarian likes this.
  3. Jun 24, 2021 at 11:36 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Both of mine tilt down every time I put it in reverse. Most of the time it's helpful.
    jimbrophotodotcom likes this.
  4. Jun 24, 2021 at 11:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I don't remember a setting, but it makes sense that there would be a way to turn it off. I'll check next time I'm in my truck.
  5. Jun 24, 2021 at 12:16 PM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
  6. Jun 26, 2021 at 8:26 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    From the manual: Linked mirror function when reversing (if equipped) (*page 169)
    "When the mirror select switch is in the L or R position, the outside rear view mirrors will automatically angle downwards when the vehicle is reversing in order to give a better view of the ground. To disable this function, move the mirror select switch to the neutral position (between L and R).
    Adjusting the mirror angle when the vehicle is reversing
    With the shift lever in R, adjust the mirror angle at a desired position. The adjusted angle will be memorized and the mirror will automatically tilt to the memorized angle whenever the shift lever is shifted to R from next time. The memorized downward tilt position of the mirror is linked to the normal position (angle adjusted with the shift lever in other than R). Therefore, if the normal position is changed after adjustment, the tilt position will also change. When the normal position is changed, readjust the angle in reversing
  7. Jun 26, 2021 at 9:41 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks for posting that! I thought the reverse position was in relation to the position I set them to when not in reverse. Now I can fine tune them.
    Mountun Goat likes this.
  8. Jun 27, 2021 at 5:02 AM
    Bigkitchens
    Bigkitchens New Member
    Alabama
    2014 1794 crewmax 4x4
    Front and back trd sway bars, 14 inch magnaflow dual in dual out exhaust, undercover bedcover, rough country 2 inch leveling coilovers and rear shocks, 285/60/20 nitto ridge grapplers, wireless charger, driver grab handle, tech12volt 10 inch sub and enclosure upgrade , and stillen cold air intake .
    This didn't work on my 2014 1794
  9. Jun 27, 2021 at 8:46 AM
    wsutundra
    Awesome this worked. I guess I kept the L/R switch In the middle because of my OCD. so I guess I’ll have to break that habit to use the feature.
    NewImprovedRon likes this.
  10. Oct 28, 2024 at 1:02 PM
    Bubba Tacos
    Bubba Tacos New Member
    Blacked out, DD12" catback, Stillen CAI, CAN tune soon
    Thank goodness this is fixable. My mirrors were adjusting way up when in reverse instead of down which was ticking me off lol
  11. Oct 28, 2024 at 1:37 PM
    SD Surfer
    Bruce
    So Cal
    I had no idea!! I'll have to go try this.
  12. Oct 29, 2024 at 11:01 AM
    SD Surfer
    Bruce
    So Cal
    No Joy!! 2019 SR5
    Is this a '20+ or trim level thing?
  13. Oct 29, 2024 at 4:42 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    My guess would be it's one of those creature comforts only available on the Platinum/1794 trim levels.
    ejes likes this.
  14. Oct 29, 2024 at 7:08 PM
    SD Surfer
    Bruce
    So Cal
    Damn ghetto SR5 ☹️
