Sill protection peeling off....how to fix?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by doughboysigep, Feb 14, 2024.
  1. Feb 14, 2024 at 12:28 PM
    doughboysigep
    doughboysigep [OP] New Member
    Delhi, NY
    '20 SR5 CM 4x4
    Noticed a bulge in the sill protection "decal" (not a decal really) and when I investigated, it had become unadhered. How would you recommend getting it stuck back on? Epoxy, super glued, silicone product???
  2. Feb 14, 2024 at 12:32 PM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    I’d probably just order a new one and replace it. Keep the old one on until the new one gets in and clean the area really well before you put the new one on.
  3. Feb 14, 2024 at 12:33 PM
    RobertD
    Robert
    DFW, Texas
    I'd fully remove it, clean the sill thoroughly and apply a new sill protector. Epoxy and super glue will damage the paint down the line, the silicone might hold but probably wouldn't sit as flat as the rest of the protector, and no guarantee the rest won't keep peeling.
  4. Feb 14, 2024 at 8:44 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    If you don’t want to buy new ones an good option is to clean the sill and adhesive really well for any debris and then you can use a heatgun to soften the adhesive and put it back together.
    RobertD likes this.
  5. Feb 15, 2024 at 4:15 AM
    bflooks
    bflooks New Member
    Metrowest MA
    While the heat gun would work, that sounds miserable. I managed to get a spec of sand under one of mine when I was installing and the bubble it creates is def noticeable (at least to me).
    For the price, I'd just start over with new and never look back. I just don't truly know how you'd ever get both surfaces clean without removing 3/4 of the adhesive.
  6. Feb 16, 2024 at 6:45 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    Yep, ordered a set ($41) and picking it up at dealer tomorrow. How do I get the old one off - will a hair drier work (don't have a heat gun)?
    RobertD likes this.
  7. Feb 16, 2024 at 6:50 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Hairdryer, park it in the sun with the door open, whatever works. If you are patient and peel slowly, i bet you'll get it off in one piece without much issue. It's already started. You can also try an IPA solution to help as you are peeling. It dissolves the glue.
    RobertD likes this.
  8. Feb 16, 2024 at 6:56 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    India Pale Ale solution?? ;-) Really, what is IPA solution (sorry for my ignorance).
  9. Feb 16, 2024 at 6:58 AM
    RobertD
    Robert
    DFW, Texas
    Isopropyl alcohol
  10. Feb 16, 2024 at 7:10 AM
    bflooks
    bflooks New Member
    Metrowest MA
    doughboysigep[OP] likes this.
  11. Feb 16, 2024 at 7:23 AM
    Rockwell
    Rockwell New Member
    New Jersey
    2021 Tundra Crew Max SR5
    Hair dryer will work. Goo Gone also works very well on adhesive, helped me much when I de-badged. After the Goo Gone, clean again with Isopropyl alcohol.
  12. Feb 16, 2024 at 8:47 AM
    2mchfun
    I replaced mine with a set of Bushwhacker rocker panel and door sill guards. HUGE improvement! Those "stickers" from Toyota are an expensive joke and nothing more.
    Ceezurin likes this.
  13. Feb 16, 2024 at 8:59 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    Looks like the Bushwhackers items are none to inexpensive!
  14. Feb 16, 2024 at 9:47 AM
    Ceezurin
    Ceezurin New Member
    Franco
    El Paso, Texas
    2019 Cavalry Blue Limited Crewmax
    Bilstien 5100 all 4 corners, Toytec shackles, mbrp full exhaust single exit, husky liners, diode dynamics interior and exterior lighting
    These sound awesome, where’d you get em? You have any pics?
  15. Feb 16, 2024 at 10:41 AM
    2mchfun
    Good things aren't cheap, cheap things aren't good!
  16. Feb 16, 2024 at 10:48 AM
    2mchfun
    Here's a general picture. Very similar for a Tundra. Don't exactly remember my source (been awhile), maybe directly from Bushwhacker. Just search the web a bit and you can see pics and find a source. It's a four piece set that attaches with 3M automotive mounting tape. The seam is concealed by the doors. I think I added a few inches of tape to their design, pretty simple and a huge improvement to the truck. Cost me about $150.
    Ceezurin[QUOTED] likes this.
