Skid plates and air dam on SR5
Discussion in '3rd Gen Tundras (2022+)' started by Kirron, Aug 14, 2022.
  1. Aug 14, 2022 at 6:23 PM
    Kirron
    Kirron [OP] New Member
    22 Tundra SR5 CrewCab TRD Off-road 4x4 in Lunar Rock!
    Vanilla
    Hello!
    I was looking under my ‘22 Tundra SR5 TRD Off-road 4x4 and was looking to see the air dam and TRD skid plate but didn’t see either. There is a small all-black black skid plate in the front; I was expecting something larger and TRD badged.
    Should there be a TRD-branded skid plate and an air dam? This is the off-road package in the spec sheet for my vehicle:
    TRD-Off-Road Premium Package
    TRD-Off-Road Premium Package—includes 18-in. TRD Off-Road alloy wheels with all-terrain tires, TRD grille, "TRD OFF-ROAD" bedside decal, off-road suspension with Bilstein® shocks, skid plates, mudguards, red TRD engine start button, TRD leather shift knob, aluminum sport pedals, electronically controlled locking rear differential, Multi- Terrain Select (MTS), Crawl Control (CRAWL), Downhill Assist Control (DAC), SofTex®-trimmed seats, 8-way power- adjustable heated front seats with 2-way power lumbar, dual zone automatic climate control, and color-keyed outer door handles.
    Thanks!
  2. Aug 14, 2022 at 6:28 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    The good skid plate is an accessory you need to buy separate. The air dam is removed on Canadian TRD OR packages.
    GODZILLA likes this.
  3. Aug 14, 2022 at 6:48 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    P
    It’s removed on the US TRD OR packages as well. We also get the black ballistic nylon “skid plate”.
    Yaboy[QUOTED] likes this.
  4. Aug 14, 2022 at 7:19 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    If you are speaking of the air dam being removed on US TRD OR, that is incorrect for Limited TRD OR, as mine has the air dam.
    Only Non-TRD trucks seem to be getting the aluminum TRD skid plate too, which makes now sense, while the TRD OR trucks get the ballistic nylon.
    FI460 and jeosbor1 like this.
  5. Aug 14, 2022 at 7:47 PM
    Kirron
    Vanilla
    So my SR5 TRD OR black skid plate in the front should “plastic thud” and not “metal clink” when hit with a wrench?
    Yaboy likes this.
  6. Aug 14, 2022 at 8:01 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Correct!
  7. Aug 15, 2022 at 5:11 AM
    4genRunner
    Southwestern MO
    Sorry, you are correct. Mine is an SR5 TRD OR. Those do not have the front air dam.
  8. Aug 15, 2022 at 10:07 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    It can get super confusing and I might have this wrong...
    Active Air Dam: Only the Limited trims & up will have the active air dam. I believe, that is regardless of the TRD OR package or not....it's standard on all trims above the SR5. The SR5 and SR do not have the active air dam at all, regardless of how the truck is optioned (?).
    Skid Plate(s): All trucks (minus the TRD Pro) come standard with some type of fabric, maybe fiberglass reinforced, cloth "splash skirt" where a skid plate would be. If you upgrade to the TRD Off-Road package, then that fabric "splash skirt" is replaced with a hard "ballistic" nylon/plastic type of "plate." The only way to get the TRD metal skid plate is to buy it separately as an accessory or, I believe, it comes standard on the TRD Pro.
    Side note: This info is US focused. I know the Canadian market is different.
    Second Side Note: As I think about the whole "Active Air Dam" thing...since it's put on as a way to improve fuel economy...shouldn't they have different MPG ratings for trucks with it and without it? I believe the MPGs listed on the window sticker of my SR5 are the same as a Limited with the active air dam (non-hybrid of course). Is that right? Fueleconomy.gov doesn't breakout MPGs by trim (i.e. Limited, SR5, Platinum, etc). It only separates 2WD, 4WD, Hybrid, Non-Hybrid, and TRD Pro.
    AND likes this.
  9. Aug 15, 2022 at 10:51 AM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    Maybe it is added to offset the extra weight of various accessories in higher trims? Like sunroofs, premium speakers, etc. I could be making that up
  10. Aug 15, 2022 at 11:10 AM
    4genRunner
    Southwestern MO
    See, just when I thought I had it all figured out....... nope.
    Good info there KroppDuster. It is confusing. Almost as confusing as Toyota's choice of mixed materials for the different trims.
    KroppDuster[QUOTED] likes this.
  11. Aug 15, 2022 at 11:11 AM
    4genRunner
    Southwestern MO
    Interesting. Hasn't thought about it like that, but may very well be the case.
  12. Aug 15, 2022 at 11:19 AM
    KroppDuster
    Bilstein 5100s
    Yeah. That's totally possible. I know sunroofs add a fair amount of weight. Individually, speakers and seat ventilators are negligible, but added up might affect MPGs in a measurable way. Your line of thinking makes sense to me. Certainly as much or more as anything Toyota has done lately. haha.
    Very true. I love Toyota, but some of their choices lately have left me wondering what's going on. Odd things like the removal of HomeLink on the SR5 or the lack of a locking gas door on lower trims. Just small things. Mainly QOL items that used to be available on the SR5. I'm sure all done in the grand scheme of cost savings and trying to push people up into higher trims. Seems like the Limited is now what the SR5 used to be 10 years ago.
    FI460 likes this.
  13. Aug 15, 2022 at 11:32 AM
    FI460
    FI460 New Member
    Rick
    2022 Limited CM/6.5' TRD OR 4x4
    To confound this even more: My brothers limited TRD OR does not have the air dam. He has the hybrid and I don't. Other than that our trucks are almost identical, but I have the air dam...
  14. Aug 15, 2022 at 11:36 AM
    KroppDuster
    Bilstein 5100s
    Oh yeah...the hybrid throws a whole different wrench into things. Some of the hybrid stuff is odd. I've heard some hybrids also eliminate the active grill shutters as well. Does your brother's truck have the grill shutters?
  15. Aug 15, 2022 at 12:23 PM
    Supertech1
    Supertech1 New Member
    My SR5 has the air dam and digital mirror with home link. I know the mirror is part of one of the packages, not sure about the air dam.
  16. Aug 15, 2022 at 12:35 PM
    KroppDuster
    Bilstein 5100s
    Interesting. What packages was your truck spec'd with? I'm guessing it's part of the "Advanced Technology" package that includes the PVM since that's the only package on the SR5 that includes the digital mirror. HomeLink isn't listed as a detail on any any package so it must just be naturally part of the digital mirror.
    What skid plate do you have?
  17. Aug 15, 2022 at 12:58 PM
    flatlandclimber
    flatlandclimber New Member
    2022 DC
    For what it's worth, I have an SR5 with the active air dam, but no home link or digital rearview.
  18. Aug 15, 2022 at 1:43 PM
    Maharisc
    Maharisc w/Patty
    Karl
    The digital mirror is needed for the SPA (straight path assist).
  19. Aug 15, 2022 at 2:29 PM
    Supertech1
    Correct, I do have the Advanced Technology package.
    Skid plate is the fabric. Wish there was an economical metal option. I’d be fine with metal skids similar to my 4runners.
  20. Aug 15, 2022 at 3:10 PM
    4genRunner
    Southwestern MO
    Yeah my SR5 TRD OR has HomeLink (as part of the digital rearview mirror). The digital rearview mirror is part of the Advanced Off-Road Technology Package which includes the Straight Path Assist.
  21. Aug 15, 2022 at 3:30 PM
    4genRunner
    Southwestern MO
    Tell me about it. There were a couple of things I wanted that are only available on Limited and higher trims. The main one is seat memory. Not available on SR5 even as an option. This is 2022, come on. Cooled seats would have been nice as well. An almost $60k truck and you can't have seat memory......
    It's obviously done to push buyers to the higher trims, but seat memory??? C'mon Toyota. Can you tell I'm a bit butt hurt about the seat memory thing? LOL.
    raylo likes this.
  22. Aug 15, 2022 at 3:37 PM
    KroppDuster
    Bilstein 5100s
    Haha. So true.
    My wife purchased a 2022 Bolt EUV in June and for $35k brand new...I'm shocked at the amount of features it has that my $55k Tundra doesn't. Heated & Cooled Seats, Power adjustable seats, heated steering wheel, digital review mirror with 360 degree cameras, etc. It's got loads of tech and creature comforts.
    Side note: I know those two vehicles are an Apples to Oranges comparison. Just thought the feature set was interesting given the $20k difference.
  23. Jan 23, 2023 at 8:39 AM
    raylo
    raylo not so new member
    Frederick, MD
    I just had a look at my SR5 with OR premium and advanced tech packages and it does not have the air dam. As for the MPG ratings being the same without it, it could be that the skid plates provide some benefit by smoothing the airflow underneath and keeping it from becoming turbulent around the covered engine components. My accessory TRD skid plate sure seems to cover up a lot of extraneous parts that could create turbulence. In any case, the air dam and skid plate effects on MPG have got to be very small.
    Sacul likes this.
  24. Feb 26, 2024 at 9:02 AM
    Sacul
    Sacul New Member
    2024 Tundra Limited TRD
    Nothing yet
    Is the oil drain plug and filter accessible with this skid plate? I know on my old 2021 it wasn’t.
  25. Feb 26, 2024 at 10:28 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Nope. Some cut a hole in it for access to the drain and use a valve instead of a plug. But IMO the filter needs to be changed too so what's the point.
    That plate comes off easily on a floor jack in 5 mins.
    Also gives you a good eyeball on any other trouble that could be brewing down there.
    Sacul[QUOTED] likes this.
  26. Feb 26, 2024 at 10:35 AM
    Yeah, and chevy loses money on the EVs. The price isn't reflective of the cost to add the features. It's not even apples and oranges, it's apples and dental floss. Sure, both go in your mouth, but they aren't even remotely the same in purpose.
  27. Feb 26, 2024 at 10:44 AM
    KroppDuster
    Bilstein 5100s
    Whatever you say, boss. :bowdown:
  28. Feb 26, 2024 at 12:02 PM
    Not me saying it, "boss."
  29. Feb 26, 2024 at 12:07 PM
    KroppDuster
    Bilstein 5100s
    Ok man.
    Not arguing with you about Chevy losing money on EV sales. I disagree with your other statement about it being totally different uses cases, but I don't have the energy to debate a post that is nearly a year old. Edit: Not almost a year old. Over 18 months old. :)
