Skid plates
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wilcox1219, Nov 29, 2016.
  1. Nov 29, 2016 at 12:44 AM
    Wilcox1219
    Wilcox1219 [OP] New Member
    2017 SR5 Tundra
    looking for skids for a 2017 Tundra, can only seem to find a TRD from Toyota. Was hoping someone could point me in the right direction?
  2. Nov 29, 2016 at 6:53 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    RCI Metal works
  3. Nov 29, 2016 at 6:53 AM
    Wilcox1219
    2017 SR5 Tundra
    Great thank you
  4. Nov 29, 2016 at 6:56 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  5. Nov 29, 2016 at 7:22 AM
    T-Rex266 SpaceX Director Staff Member
  6. Nov 29, 2016 at 11:29 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Sean those look awesome man. @Sean266
    T-Rex266 likes this.
  7. Nov 29, 2016 at 12:18 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Ordered RCI during Black Friday. Can't wait to get mine.
    Wilcox1219[OP] and T-Rex266 like this.
  8. Dec 15, 2016 at 6:03 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Sean266 , do u know what bolts to use when using the rci skid with a diff drop?
  9. Dec 15, 2016 at 6:16 AM
    Not off hand, no. RCI wrote them doelwn though.
  10. Dec 15, 2016 at 6:40 AM
    khunk
    khunk Tundra Fan
    Marty
    Leland, NC
    2017 CM Limited 4x4
    Question for anyone, How many skid plates are there or can there be for a 3rd Gen Tundra? I've seen them for the gas tank, and one for under the main part of the engine and towards the front of the truck. Can someone make me smart on skids such as how many, what are the names of them, what do they protect, which ones are the most important one to have?
    I don't need to know for any real reason other to make myself smarter about my truck.
    Thanks in advance for all your wise A$$ Remarks as well as answers.....
    Sunnier likes this.
  11. Dec 15, 2016 at 6:41 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    K. Is there a way you can find out? I'll be getting mine soon and want to be prepared.
  12. Dec 15, 2016 at 7:01 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    ditto, Still waiting for mine to arrive.
    BlueBottle[QUOTED] likes this.
  13. Dec 15, 2016 at 7:05 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think there are 3, that I know of. Check the RCI site for better info though.
  14. Dec 15, 2016 at 7:57 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    This forum is a blessing and a curse.....
    Love the knowledge, love getting a ton of great info on things I can do to make my truck the way I want it, but.. ..
    TheBeast, CaptTyler, joonbug and 2 others like this.
  15. Dec 15, 2016 at 8:30 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    DiamondBack SE, AMP PowerSteps,
    I think the answer to your question is in post #4 and pictures are in $5 above. From RCI, there is the Engine Skid Plate, the Transmission/Transfer Case skid plate and the Fuel Tank skid plate. The Toyota TRD Pro Skid Plate is basically to cover the engine area; stock OEM is engine cover and the rest of Toyota OEM are plastic covers that most of us do not consider to be skid plates. ;) I hope this helps
  16. Dec 15, 2016 at 11:22 AM
    I sent him a message. Will let you know when I hear back.
  17. Dec 15, 2016 at 12:24 PM
    RCIoffroad
    RCIoffroad New Member Vendor
    Josh
    You don't need any different bolts, however you will need 5 spacers (3/8" to 1/2" is perfect) that will simply go between the existing M8 bolts that mount the skid plate and the frame. If we haven't shipped your yet let me know and I can include some for you.
    BlueBottle and T-Rex266 like this.
  18. Dec 15, 2016 at 12:25 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Is there a forum discount?
  19. Dec 15, 2016 at 1:14 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    As an alternative, BudBuilt also makes skid plates for the Tundra with some different options (such as extra thickness or stainless steel). Them and RCI are the only shops that make skids for our trucks to my knowledge.
    RCI
    - Skids: engine, transmission and transfer are combined, gas.
    - Sleeker design.
    BudBuilt
    - Skids: engine, transmission and transfer are separate, gas
    - Provides more coverage between the transfer case and gas tank areas.
    - Comes with additional frame crossmember after the transfer case that the transfer skid mounts to (also functions as frame support for various directions of stress).
    For what it's worth, I have the BudBuilt transfer and gas skids. I can't use the engine or transmission skids because I have a drop bracket lift.
    smslavin, Sunnier and khunk like this.
  20. Dec 15, 2016 at 1:44 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    sweet. I pm'd you my order number. Thanks @RCIoffroad & @Sean266
  21. Dec 15, 2016 at 1:52 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Which ones did you get?
  22. Dec 15, 2016 at 3:04 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    :woot:
    Aluminum engine skid.
  23. Sep 11, 2017 at 3:06 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Rci
    It's like 3 times thicker than what came stock with the trd non pro package. It's also longer :thumbsup:
  24. Sep 11, 2017 at 4:12 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Buds are what I have. Front to back. Little bit heavier than the RCIs even though I opted for the "lite" steel option. All 6 pieces weigh in at about 135ish. One of the things that is different between his and RCI, is that all of the bolts are flush with the skids. A bit of a puzzle to get them all in there and I would suggest another set of hands or a jack rather than doing it yourself with an 8 yr old giving you directions... :confused: o_O :D
  25. Sep 11, 2017 at 7:02 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    "TRD from Toyota" is the right direction.
  26. Oct 27, 2017 at 8:19 AM
    RCIoffroad
    Josh
    We do not use flush mount screws because if you ever do manage to bump allen head bolts they are IMPOSSIBLE to remove. Our tundra skid plates use carriage bolts anywhere exposed so you physically cannot damage them in a way that would hinder removing them later ;)
  27. Oct 7, 2018 at 12:03 PM
    Rica25
    Ricardo
    Tulare
    Can you guys send those bolts in black also?
  28. Oct 7, 2018 at 12:14 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Literally, I'm about ready to go out to the garage to install my RCI skid plates in a few hours...after my nap.
    My primary motivation for getting the plates was the little trap door that will give me access to the oil filter.
    Recently though I have started to grease my drive shafts when ever I change my oil.
    So now I'm thinking I'm still going to have to remove my skid plates every time I want to grease my front drive shaft.
    Or am I making too big a deal out of greasing my front drive shaft and it doesn't have to be done every 10,000 miles?
  29. Oct 7, 2018 at 12:27 PM
    Rica25
    Ricardo
    Tulare
    I never have the patience to wait to install what ever I order........needs to be done that same day or following day
    myt1[QUOTED] likes this.
  30. Oct 7, 2018 at 4:24 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    I just finished the install.
    It went fine, except I have a few washers and a few nuts left over. I hope this isn't a problem.:)
    If you have wrenches that have a ratchet mechanism they are very handy.
    I don't have any and I had to tighten some nuts in very awkward locations with a standard wrench. I felt like an animal.
    These skid plates are very heavy duty and now I'm beginning to think they are way more than I will ever need driving down rough four wheel drive dirt roads when I go fishing.
    They will definitely make oil changes much easier, but if I need to get under my truck for anything other than an oil change it is going to be a real pain to remove these things...way harder than the stock skid plate.
    The quality seems to be first rate.
    I just hope I actually need them at some point.
