Sled hauling bent tailgate
Discussion in 'Towing & Hauling' started by Maggy4x4, Apr 20, 2023.
  1. Apr 20, 2023 at 9:31 PM
    Maggy4x4
    Maggy4x4 [OP] N+1 mods
    Washington
    2008 SR5 Tundra
    35s on methods Icon lift 46 gal fuel tank
    Anyone else hauling a sled in their bed figured out how to keep from bending the tailgate when loading? I have a trailer I usually use but with spring riding I’ve been putting it in my bed so it’s easier to get up the roads. And now I’m getting a curved tailgate
    Hoping to flatbed it soon so won’t have to worry about this much longer
  2. Apr 20, 2023 at 9:49 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I use a piece of 5/8” plywood cut the size of my tailgate, plus enough to cover the gap to the bed. That edge is screwed to a length of 2x2, which drops into the gap, so the sled holds the plywood securely in place.
    The rear edge of the plywood is also notched so my aluminum tri-fold ramp sits down in it, so no issues with the carbides catching when unloading, and sliding the ramp under / out from under the track is easier.
    RichterScale and Cpl_Punishment like this.
  3. Apr 21, 2023 at 8:48 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    When I had a Crewmax and the mini bed, I would haul quite a bit with the tailgate down. I ran a sheet of plywwood the full length of the bed, out to the edge of the tailgate ( I believe it was a little over 7') for precisely this reason.
    Replace the tailgate and use a sheet of plywood for future use. I'd find a way to secure the plywood to the bed, too, so the sled doesn't shoot it out of the bed.
  4. Apr 24, 2023 at 3:05 PM
    Maggy4x4
    Washington
    2008 SR5 Tundra
    That sounds like a pretty good idea. Do you have a picture of it?
    and because threads are better with pictures here’s from loaded up last weekend, probably should up the icon leaf pack to “option 3” as I was rubbing my mudflats a lot
  5. Apr 24, 2023 at 3:08 PM
    Maggy4x4
    Washington
    2008 SR5 Tundra
    I like the simplicity, knowing myself I’d probably over do it and end up building it to the height of the wheel wells with storage underneath
