Slight ticking sound coming from engine on 06 V8 4.7L
Discussion in '1st Gen Tundras (2000-2006)' started by eth727, Nov 2, 2021.
  1. Nov 2, 2021 at 2:24 PM
    eth727
    eth727 [OP] New Member
    hey guys I'm getting a slight ticking noise from my 06 V8 Tundra with 187K miles. I did a timing belt job in June of this year and it didn't have this sound. It seems to run fine and after it's been running for a while the noise starts to go away. Any ideas?
    Thanks
  2. Nov 2, 2021 at 2:42 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Either a exhaust leak, or our engines can sound pretty tippity tappy on startup.
  3. Nov 2, 2021 at 3:03 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Toyoda Tundra and FrenchToasty like this.
  4. Nov 2, 2021 at 3:16 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Mine makes a knocking tapping metal sound sometimes when I first start it up during cold weather only, goes away after a few seconds, I’ve always wondered what it could be.
  5. Nov 3, 2021 at 6:55 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    What weight and brand oil you running? Change brands or anything recently? Was the oil changed in the last 5k miles?
  6. Nov 3, 2021 at 7:07 AM
    03SR5
    03SR5 New Member
    03 SR5 ACC
    All Stock
    Same here. Sounds kind of like a noisy lifter for a couple seconds on a cold start. Hydraulic lifters on these trucks?
  7. Nov 3, 2021 at 7:24 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Sounds like lifter chatter? I used to have this on my old ford ranger 4.0 after she hit 150k+ miles. Try using heavier weight oil on your next oil change. This worked perfectly for me.
    Toyoda Tundra likes this.
  8. Nov 3, 2021 at 7:32 AM
    Toyoda Tundra
    Do y’all’s sound like this one? https://www.dropbox.com/sh/h8quksfkws9kla3/AAAxvsp_-lheYTwcJ7JucJ-9a?dl=0
  9. Nov 3, 2021 at 7:36 AM
    MadMaxCanon
    Toyoda Tundra[QUOTED] likes this.
  10. Nov 3, 2021 at 8:24 AM
    Toyoda Tundra
    No hydraulic lifters on the 4.7. Our trucks use a shim-over bucket type valve train.
  11. Nov 3, 2021 at 9:19 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Sounds like mine with a minor exhaust leak. Typically only shows up when the engine is cold.
  12. Nov 3, 2021 at 9:32 AM
    eth727
    Yeah it sounds like that audio clip but not as loud. It doesn't sound like an exhaust leak. I know those first hand. Yeah the oil has been changed in last couple hundred miles don't remember the weight or brand. I gotta record it and let you guys hear it. Can we upload short videos on here or does it have to be via YouTube or Dropbox.
    Thanks for your help everyone
  13. Nov 3, 2021 at 11:56 AM
    Toyoda Tundra
    That be great if we can hear it. Unfortunately you can’t upload videos here directly, you can use YouTube or Dropbox then send the link here.
  14. Nov 3, 2021 at 7:41 PM
    Hey FWIW, I have a similar rhythmic tap like that on my sub-100k mile truck. Mine sounds light, like a slight bit of lifter tapping.
    Can't say the OP's or Toyoda's sample are, it's 10x louder than my '06 w/VVT, but ...
  15. Nov 3, 2021 at 8:34 PM
    Toyoda Tundra
    Does yours sound at certain times? Or all the time?
  16. Nov 3, 2021 at 8:37 PM
    I dunno. I remembered hearing what sounded like mild lifter tick when I recently cleaned my engine and bay. So it definitely happens when the engine is cool. I'll hafta check it next time I need to drive somewhere, which may not be a couple days. Will get back to you if it doesn't escape my mind. I'm not often outside the truck while it's running, for whatever reason.
  17. Nov 3, 2021 at 8:48 PM
    Toyoda Tundra
    Gotcha! Seems like a lot of us are having that issue, if it’s even an issue that is, maybe our engines are just noisy during colder temps sometimes.
  18. Nov 4, 2021 at 9:28 AM
    It may not even be an 'issue' necessarily, I dunno. I just had to take a short 1-2mi trip. I confirm I have a very faint rhythmic tapping at startup. By the time I drove the couple miles and back, if it was still there, I couldn't hear it very well.
  19. Nov 4, 2021 at 11:28 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    What weight oil are you using? Could be cold start piston slap.
    I know the 5.7 ( :puke: ) has a piston slap issue if you go heavier than recommended oil weight.
  20. Nov 4, 2021 at 12:18 PM
    (Quoting yourself from other threads is kinda like talking about yourself in the 3rd person, eh??)
  21. Nov 4, 2021 at 12:50 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    (Something like that. ;) )
    I don't think I have the noise being asked about. I also went to a 20 weight.
  22. Nov 4, 2021 at 3:03 PM
    Toyoda Tundra
    Seems to only happen in colder climates, atleast mine does, I never hear it in the summer
