Slop between lugs and front rotor - Normal?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BoatBroker, Feb 5, 2023.
  1. Feb 5, 2023 at 8:46 AM
    BoatBroker
    BoatBroker [OP] New Member
    Sarasota, Florida
    2016 Tundra SR5
    What is the reasoning for the slop around the lugs and the front brake rotors? I've never seen this much space between lugs on a car before. The rotors usually fit the lugs snug. I think the noise I have when coming to a stop is due to the rotor shifting on the lugs. See pictures.
  2. Feb 5, 2023 at 9:25 AM
    2mchfun
    Expansion and contraction occur as temperature changes.
  3. Feb 5, 2023 at 9:52 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I’ve always seen it.
  4. Feb 5, 2023 at 10:01 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    It's normal. What needs to be tight is the centre of the rotor to the hub. Once the lug nuts are torqued the rotors should stay put.
  5. Feb 5, 2023 at 10:48 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    If your rotors were moving under braking you would see some damage or wear on the lugs and the rotor holes.
  6. Feb 5, 2023 at 10:53 AM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    If the rotor is sliding, you can confirm by looking at the backside for slide marks. If they did slide, the fronts will stay in place after the first stop since the truck is not front wheel drive.
  7. Feb 6, 2023 at 10:06 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Each stud tightens down with ten thousand pounds of force. It shouldn't move much. Even if it did, virtually all the time the rotational force is in one direction only (drag of the brake pad) except when backing up.
