Slow shift from first to second intermittently hard shift first to second when accelerating fast
Discussion in '1st Gen Tundras (2000-2006)' started by Lalo805, May 13, 2023.
  1. May 13, 2023 at 5:13 AM
    Lalo805
    Lalo805 [OP] New Member
    Eduardo Torres
    2006 Tundra
    I have a 2006 tundra double cab 2wd, a year ago I blew up the diff doing donuts in the dunes and I just recently replaced it with a new one it was sitting in the same spot the entire time, I would turn it on bi weekly to keep the fluids circulating. After test driving it I noticed the shifting issue so now I don’t accelerate hard from first to second. How long do I have until it completely fails and would a drain and fill with Toyota world standard and a liter of the Lucas transmission fix help at all or just use straight world standard
  2. May 13, 2023 at 5:19 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Hard to say. I’ve always had the delayed 1st to 2nd shift issue for years but not the hard shift when accelerating. I’d still think it was a solenoid issue but I’m no expert. I’d be tempted to open it up and replace the solenoids myself but that isn’t a trivial task.
  3. May 13, 2023 at 5:23 AM
    Lalo805
    Eduardo Torres
    2006 Tundra
    It has 160k I believe I did a flush around 90k but I treated the truck badly I was 19 when I bought it with 59k miles but now I’m mature and I’ve been babying in for the past 5 years should I try the drain and fill with the additive?
  4. May 13, 2023 at 5:31 AM
    Jack McCarthy
    Bill
    North of Boston
    IDK, I’ve tried AutoRx for my tranny to try and fix the delayed shift and it did nothing. I couldn’t tell you about the Lucas stuff since I haven’t used it. I would definitely recommend another drain and fill if it hasn’t been done in a while.
    FrenchToasty likes this.
  5. May 13, 2023 at 5:35 AM
    Lalo805
    Eduardo Torres
    2006 Tundra
    I think I’m going to do that and hope for the best
    Jack McCarthy likes this.
  6. May 13, 2023 at 5:36 AM
    Jack McCarthy
    Bill
    North of Boston
    From what I’m reading, Lucas is just a temporary fix and won’t work for major seal leaks so it’s not a cure all.
  7. May 13, 2023 at 6:28 AM
    Lalo805
    Eduardo Torres
    2006 Tundra
    It’s not leaking… yet but I’ll try that and then the next step would be repairing it
    Should I have it rebuilt at a transmission shop or swap it out with a used one that has warranty in case it fails or just get a remanufactured one
  8. May 13, 2023 at 6:31 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You need to do a drain and fill or full fluid swap, but you need to check the level properly. Use WS or amsoil fuel efficient atf, don’t bother with any additives
    tvpierce likes this.
  9. May 13, 2023 at 6:41 AM
    Lalo805
    Eduardo Torres
    2006 Tundra
    I’m afraid a full fluid flush I don’t know if it’ll react well to all that new fluid or is that only for cvt transmission?
  10. May 13, 2023 at 6:48 AM
    Jack McCarthy
    Bill
    North of Boston
    Yeah, I missed the part on where it helps with stuck solenoids. I’d be inclined to goto a reputable transmission shop (no chain places) and price it out against a used one. You usually get a 1 year warranty with a rebuilt tranny and it’s got new instead of used parts.
  11. May 13, 2023 at 6:48 AM
    FrenchToasty
    Mo
    Bone stock
    I wouldn’t “flush” it, but a full fluid swap using the trans internal pump shouldn’t cause any harm. Lots of write ups, but the fluid level check is important since our shift boxes don’t have a dip stick
  12. May 13, 2023 at 7:15 AM
    Lalo805
    Eduardo Torres
    2006 Tundra
    So should I have it diagnosed professionally if the fluid flush doesn’t help? I can definitely remove and replace the transmission myself I would just make sure to buy a tranny with warranty
    I’m just seeing prices of 5-7k for a shop to rebuild my transmission I’d rather buy a new for 2k
  13. May 13, 2023 at 7:17 AM
    Lalo805
    Eduardo Torres
    2006 Tundra
    Yeah I saw a video on a transmission drain and fill and how to set the truck into transmission temperature sense mode to add the right amount of fluid since they decided to remove the dipstick
  14. May 13, 2023 at 7:47 AM
    Jack McCarthy
    Bill
    North of Boston
    That’s up to you. I think a diagnostic might be anywhere from free to a couple hundred bucks. I’m not sure if they do partial rebuilds or if it’s always complete. Might be worth investigating if they have any tools you don’t.
  15. May 13, 2023 at 9:01 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Does the 06 have a dip stick?
    what does the fluid look like?
  16. May 13, 2023 at 10:29 AM
    No dip stick, sealed transmission for '05-06.
    I've always had a slow shift 1->2. So many others have reported this with the 5spd that I think I even put a note about it in the knowledge dump thread.
    It tends to be more noticeable on my '06 when cold. Or if warm and I turn it off long enough for all fluids to settle.
    But if you're worried, carry it in to a Toyota shop and have the transmission serviced (fluid flush + level check). Just don't take to a non-Toyota shop where they may use pressurized pump to push the fluid.
  17. May 14, 2023 at 9:10 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Wonder if it's anything like this? This is an earlier truck and my truck suffers the same problem.
    If you put the shifter in "2" from a stop and let it shift into 2nd on its own does the shift feel smoother?
  18. May 15, 2023 at 2:31 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    When cold I have a delayed 2-3 shift. This is the ECU trying to bring the trans fluid up to temp (ie: normal afaik).
  19. May 15, 2023 at 7:10 PM
    jberkut4
    jberkut4 Shake and Bake
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    I can second this, I would say my 05 has a slower shift from 1 to 2. However, it doesn't do it when accelerating heavy. Every other shift is quick and smooth, smoother than most newer cars I have driven. I have always just assumed the "slower" shift is normal for the 1-2 shift, its always consistent.
    shifty`[QUOTED] likes this.
  20. May 17, 2023 at 9:14 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Our trucks and their personalities! For me, when cold, 1-2 shifts early and 2-3 shifts late.
    OP, if it's not "slamming" into gear, you're probably ok, but do what others suggested and do a drain and fill. My condolences to your lack of a dip-stick.
  21. May 17, 2023 at 11:12 AM
    You've got 4spd AT, Jordan and I have 5spd AT.
    It's possible I've been unaware of the 1-2 shift if it's early, but there will be times when I turn out of my driveway and start to accelerate where the truck will climb up around 3k before finally upshifting when cold. It's always been that way.
  22. May 17, 2023 at 11:29 AM
    metalpete
    ID
    Ah, valid point, but it's a similar situation. There are times where I hit around 3k before it shifts, too, and I also recall the 1-2 being late and 2-3 being early until after I did a couple drain & fills and changed the filter.
  23. May 17, 2023 at 6:51 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    I feel like when mine is cold, it always shifts a little different, but feel like that's how any car is pulling out of the driveway. I have never worried about it, but have seen many choose to do drain and fills. At 165k miles, I doubt mine has ever been changed. Havent made up my mind if I will drain and fill eventually lol
