Snorkel Kit and Air Intake question
Discussion in '2.5 Gen Tundras (2014-2021)' started by OhEmmBee, Apr 24, 2021.
  1. Apr 24, 2021 at 3:55 AM
    OhEmmBee
    OhEmmBee [OP] Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Has anyone here done both the air intake and snorkel kit upgrade? Maybe both products that cohesively goes actually hand in hand? I'm curious cause I saw that Injen has an air intake for the Tacoma that inducts air from the snorkel kit and from the passenger front engine compartment. I wanna increase my HP and fuel economy hopefully so anything retaining to both helps.
  2. Apr 24, 2021 at 7:04 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    You’re not going to get any significant benefit with a snorkel and/or intake. It’s your money though so spend it as you please.
  3. Apr 24, 2021 at 7:08 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    A snorkel is mostly for looks on a Tundra. It can cause a lot of MAF issues for some trucks. Quite honestly, if you have a lifted tundra and plan on doing river/stream crossings, know that the airbox on a Tundra is very high up (pretty much against the hood) and is typically not in a spot that can get water into unless you're doing crossings that go above your hood for extended periods. Even so, I've had luck just tightly tying a garbage bag around the airbox just for the crossing then taking it off once across.
    The snorkel should never be thought of as an upgrade in engine performance, unless you get a pre-filter style head which does get you a smidge more clean air into the engine but even then it's negligible.
    AggiePhil, clarkritchie and 300BLK like this.
